3339|2
79
请问能在WDM驱动中使用GetTickCount吗 [复制链接]
如果想获得一个粗劣的计时器,可以用什么方法?
比如 QueryPerfermanceXXXX ?
在驱动中可以使用别的定时器函数。如下: IoInitializeTimer:   Associates a timer with the given device object and registers a driver-supplied    IoTimer routine for the device object. IoStartTimer:   Enables the timer for a given device object and calls the driver-supplied IoTimer routine once every second. IoStopTimer :   Disables the timer for a given device object so the driver-supplied IoTimer routine is not called unless the driver re-enables the timer. KeInitializeDpc:   Initializes a DPC object and sets up a driver-supplied CustomTimerDpc routine that can be called with a given context. KeInitializeTimer:   Initializes a notification timer object to the Not-Signaled state. KeInitializeTimerEx:   Initializes a notification or synchronization timer object to the Not-Signaled state. KeSetTimer:   Sets the absolute or relative interval at which a timer object will be set to the Signaled state; optionally supplies a timer DPC to be executed when the interval expires. KeSetTimerEx:   Sets the absolute or relative interval at which a timer object will be set to the Signaled state; optionally supplies a timer DPC to be executed when the interval expires; and optionally supplies a recurring interval for the timer. KeCancelTimer:   Cancels a timer object before the interval passed to KeSetTimer expires; dequeues a timer DPC before the timer interval, if any was set, expires. KeReadStateTimer:   Returns TRUE if a given timer object is set to the Signaled state. KeQuerySystemTime :   Returns the current system time. KeQueryTickCount:   Returns the number of interval-timer interrupts that have occurred since the system was booted. KeQueryTimeIncrement:   Returns the number of 100-nanosecond units that are added to the system time at each interval-timer interrupt. KeQueryInterruptTime:   Returns the current value of the system interrupt-time count in 100-nanosecond units. KeQueryPerformanceCounter:   Returns the system performance counter value in hertz. 如果想看更具体的,请参阅windowsddk  详情 回复 发表于 2007-1-13 20:56
95
不能用,以前的帖子中有介绍,函数名字记得不是很清楚了,可以去找找
在驱动中可以使用别的定时器函数。如下:
IoInitializeTimer:
IoStartTimer:
IoStopTimer :
KeInitializeDpc:
KeInitializeTimer:
KeSetTimer:
KeSetTimerEx:
KeCancelTimer:
KeReadStateTimer:
KeQuerySystemTime :
KeQueryTickCount:
【直播时间】5月28日(周三)上午10:00
