5186|11
56
图像旋转后显示乱码 [复制链接]
旋转前图像的宽高是4的倍数的矩形就没有问题;如果不是4的倍数,旋转就会显示出来乱码,我查了,说是扫描的行数要是4的倍数,要更改width的值,但更改了好几回,图片还是乱的。。。有人做过的,麻烦指点一下。多谢了
BITMAPINFO RGB24BitsBITMAPINFO;
                ZeroMemory(&RGB24BitsBITMAPINFO, sizeof(BITMAPINFO));
                RGB24BitsBITMAPINFO.bmiHeader.biSize = sizeof(BITMAPINFOHEADER);
                RGB24BitsBITMAPINFO.bmiHeader.biWidth = width;
                RGB24BitsBITMAPINFO.bmiHeader.biHeight = height;//
                RGB24BitsBITMAPINFO.bmiHeader.biPlanes = 1;
                RGB24BitsBITMAPINFO.bmiHeader.biBitCount = 24;
                //use the function CreateDIBSection and SelectObject
                //in order to get the bimap pointer : lpBitmapBits
                HBITMAP directBmp = CreateDIBSection(hMemDC, (BITMAPINFO*)&RGB24BitsBITMAPINFO,
                        DIB_RGB_COLORS, (void **)&lpBitmapBits, NULL, 0);
                     HGDIOBJ previousObject = SelectObject(hMemDC, directBmp);
                // copy the screen dc to the memory dc
                BitBlt(hMemDC, 0, 0, width, height, hScrDC, 0, 0, SRCCOPY);
                BITMAPFILEHEADER bmBITMAPFILEHEADER;
                ZeroMemory(&bmBITMAPFILEHEADER, sizeof(BITMAPFILEHEADER));
                bmBITMAPFILEHEADER.bfType = 0x4d42;  //bmp
                bmBITMAPFILEHEADER.bfOffBits = sizeof(BITMAPFILEHEADER) + sizeof(BITMAPINFOHEADER);
                bmBITMAPFILEHEADER.bfSize = bmBITMAPFILEHEADER.bfOffBits + ((width*height)*3); ///3=(24 / 8)
                typedef struct _MYRGB
                        char r;
                        char g;
                        char b;
                }MyRGB;
                ASSERT(sizeof(MyRGB) == 3);
                MyRGB* pDes = (MyRGB*)malloc(width * height * 3 + 1);
                if(pDes == NULL)
                        return;
                memset(pDes,0,width * height * 3 + 1);
                MyRGB* pSrc = (MyRGB* )lpBitmapBits;
                if(nRotateType==1)//顺时针
                        for(int l = 0;l < width * height;l++)
                                int i = l/width;
                                int j = l%width;
                                pDes[(width - 1 - j) * height + i] = pSrc[i * width + j];
                else  //逆时针
                                int i = l/width;
                                int j = l%width;
                                pDes[j * height + height - 1 - i] = pSrc[i * width + j];
                RGB24BitsBITMAPINFO.bmiHeader.biWidth = height;
                RGB24BitsBITMAPINFO.bmiHeader.biHeight = width;
sWbytes = (width + 31)/8 * 3;  //source width in bytes dWbytes = (height + 31)/8 * 3; //dest width in bytes BYTE* pDes = (BYTE*)malloc(width * dWbytes); if(pDes == NULL) { return; } memset(pDes,0,width * dWbytes); BYTE* pSrc = (BYTE* )lpBitmapBits; if(nRotateType==1)//顺时针 { for (i = 0; i < width; i++) { for (j = 0; j < height; j++) { pDest[i*dWbytes + j*3] = pSrc[(height-j-1)*sWbytes + i*3]; pDest[i*dWbytes + j*3 + 1] = pSrc[(height-j-1)*sWbytes + i*3 + 1]; pDest[i*dWbytes + j*3 + 2] = pSrc[(height-j-1)*sWbytes + i*3 + 2]; } } } else //逆时针 { for (i = 0; i < width; i++) { for (j = 0; j < height; j++) { pDest[i*dWbytes + j*3] = pSrc[j*width*3 - i*3]; pDest[i*dWbytes + j*3 + 1] = pSrc[j*width*3 - i*3 + 1]; pDest[i*dWbytes + j*3 + 2] = pSrc[j*width*3 - i*3 + 2]; } } } 这个感觉更好些。。。。不知你有没有这个的工程。。  详情 回复 发表于 2007-8-28 14:04
78
一个扫描行所占的字节数计算方法:
DataSizePerLine= (biWidth* biBitCount+31)/8;
// 一个扫描行所占的字节数
DataSizePerLine= DataSizePerLine/4*4; // 字节数必须是4的倍数
我在网上看到是这么说的,但不知在哪加上
78
if(pDes == NULL)
return;
else //逆时针
多谢,但好像并没有起作用,现在点了旋转按纽都没反应了
估计是不是数组溢出了
哎,还是没搞定。。。
sterrys(sterrys) 还在么
64
// BMP.cpp: implementation of the BMP class.
#include "stdafx.h"
#include "Image Processing.h"
#include "BMP.h"
#include "stdio.h"
#ifdef _DEBUG
#undef THIS_FILE
static char THIS_FILE[]=__FILE__;
#define new DEBUG_NEW
#endif
// Construction/Destruction
BMP::BMP()
BMP::~BMP()
BOOL BMP::Test()
        lpSrcFile = "c:\\temp\\1.bmp";
        lpDstFile = "c:\\temp\\2.bmp";
        bmDegree = 180;
        Read();
        bmDstWidth = bmWidth;
        bmDstHeight = bmHeight;
        hDst = GlobalAlloc(GPTR, (INT)((bmDstWidth + 15) / 16) * 2 * bmDstHeight);
        bmDstBits = (LPBYTE)GlobalLock(hDst);
        Rotate();
        Write();
        if (hDst)
                GlobalUnlock(hDst);
        if (bmDstBits)
                GlobalFree(bmDstBits);
        return TRUE;
BOOL BMP::Read()
        BITMAPFILEHEADER fileHead;
        BITMAPINFOHEADER infoHead;
        DWORD size;
        HANDLE hRead;
        if (!(hRead = CreateFile(lpSrcFile, GENERIC_READ, FILE_SHARE_READ, NULL, OPEN_EXISTING, 0, NULL)))
                MessageBox(NULL, "Open file failed", "Error", MB_OK);
                return FALSE;
        ReadFile(hRead, &fileHead, sizeof(BITMAPFILEHEADER), &size, NULL);
        if (fileHead.bfType != 0x4D42)
                MessageBox(NULL, "Not BMP file", "Error", MB_OK);
                CloseHandle(hRead);
                return FALSE;
        hSrc = GlobalAlloc(GPTR, (fileHead.bfSize - fileHead.bfOffBits));
        bmSrcBits = (LPBYTE)GlobalLock(hSrc);
        ReadFile(hRead, &infoHead, sizeof(BITMAPINFOHEADER), &size, NULL);
        bmWidth = infoHead.biWidth;
        bmWidthBytes = (INT)((bmWidth + 15) / 16) * 2;
        bmHeight = infoHead.biHeight;
        bmPlanes = infoHead.biPlanes;
        bmBitsPixel = infoHead.biBitCount;
        bmXReso = infoHead.biXPelsPerMeter;
        bmYReso = infoHead.biYPelsPerMeter;
        switch(infoHead.biBitCount)
                case 1:
                        size = 2;
                        break;
                case 4:
                        size = 16;
                        break;
                case 8:
                        size = 256;
                        break;
                default:
                        size = 0;
                        break;
        if (size > 0)
                hPal = GlobalAlloc(GPTR, size * sizeof(DWORD));
                bmPallete = (LPDWORD)GlobalLock(hPal);
                ReadFile(hRead, bmPallete, size * sizeof(DWORD), &size, NULL);
        SetFilePointer(hRead, fileHead.bfOffBits, NULL, FILE_BEGIN);
        ReadFile(hRead, bmSrcBits, (fileHead.bfSize - fileHead.bfOffBits), &size, NULL);
        CloseHandle(hRead);
        return TRUE;
BOOL BMP::Write()
        DWORD size, palSize;
        HANDLE hWrite;
        memset(&fileHead, 0, sizeof(BITMAPFILEHEADER));
        memset(&infoHead, 0, sizeof(BITMAPINFOHEADER));
        if (!(hWrite = CreateFile(lpDstFile, GENERIC_WRITE, 0, NULL, CREATE_ALWAYS, 0, NULL)))
                return FALSE;
        infoHead.biSize = sizeof(BITMAPINFOHEADER);
        infoHead.biWidth = bmDstWidth;
        infoHead.biHeight = bmDstHeight;
        infoHead.biPlanes = bmPlanes;
        infoHead.biBitCount = bmBitsPixel;
        infoHead.biClrImportant = 2;
        infoHead.biXPelsPerMeter = bmXReso;
        infoHead.biYPelsPerMeter = bmYReso;
        infoHead.biSizeImage = ((INT)((infoHead.biWidth * infoHead.biBitCount + 15) / 16) * 2 * infoHead.biHeight);
        fileHead.bfType = 0x4D42; //'BM'
        switch (infoHead.biBitCount)
                case 1:
                        palSize = 2;
                        break;
                case 4:
                        palSize = 16;
                        break;
                case 8:
                        palSize = 256;
                        break;
                default:
                        palSize = 0;
                        break;
        fileHead.bfOffBits = sizeof(BITMAPFILEHEADER) + sizeof (BITMAPINFOHEADER) + palSize * sizeof(DWORD);
        fileHead.bfSize = fileHead.bfOffBits; //head size
        fileHead.bfSize += infoHead.biSizeImage; //data size
        WriteFile(hWrite, &fileHead, sizeof(BITMAPFILEHEADER), &size, NULL);
        WriteFile(hWrite, &infoHead, sizeof(BITMAPINFOHEADER), &size, NULL);
        WriteFile(hWrite, bmPallete, palSize * sizeof(DWORD), &size, NULL);
        WriteFile(hWrite, bmDstBits, (fileHead.bfSize - fileHead.bfOffBits), &size, NULL);
        CloseHandle(hWrite);
        if (hPal)
                GlobalUnlock(hPal);
        if (bmPallete)
                GlobalFree(bmPallete);
        if (hSrc)
                GlobalUnlock(hSrc);
        if (bmSrcBits)
                GlobalFree(bmSrcBits);
        return TRUE;
bool BMP::Rotate()
        int i, j, k;
        int pos1, pos2;
        switch (bmDegree)
                case 180:
                        switch (bmBitsPixel)
                                case 1:
                                        for (j = 0; j < bmHeight; j++)
                                                if (bmWidthBytes == (bmWidth / 8))
                                                        for (i = 0; i < bmWidthBytes; i++)
        pos1 = (j * bmWidthBytes + i);
        pos2 = (bmHeight - j - 1) * bmWidthBytes + bmWidth / 8 - 1 - i;
        *(bmDstBits + pos1) = shift[*(bmSrcBits + pos2)];
                                                else
                                                        for (i = 0; i < bmWidth; i++)
        pos1 = (j * bmWidthBytes + i / 8);
        pos2 = (j * bmWidthBytes + (bmWidth - 1 - i) / 8);
                                        break;
                                case 4:
                                        break;
                                case 8:
                                case 16:
                                case 24:
                                case 32:
                                                        pos1 = j * bmWidthBytes + i * bmBitsPixel / 8;
                                                        pos2 = (bmHeight - j - 1) * bmWidthBytes + (bmWidth - i - 1) * bmBitsPixel / 8;
                                                        for (k = 0; k < bmBitsPixel / 8; k++)
        *(bmDstBits + pos1 + k) = *(bmSrcBits + pos2 + k);
                                        break;
                                default:
                                        memcpy(bmDstBits, bmSrcBits, bmHeight * bmWidthBytes);
                                        break;
                        break;
                case 90:
                                case 1:
                                        break;
                                case 4:
                                        break;
                                case 8:
                                case 16:
                                case 24:
                                case 32:
                                        LONG bmDstWidth, bmDstWidthBytes, bmDstHeight;
                                        int pos1, pos2;
                                        bmDstHeight = bmWidth;
                                        bmDstWidth = bmHeight;
                                        bmDstWidthBytes = (int)((bmDstWidth * bmBitsPixel + 15) / 16) * 2;
                                        for (j = 0; j < bmDstHeight; j++)
                                                for (i = 0; i < bmDstWidth; i++)
                                                        pos1 = j * bmDstWidthBytes + i * bmBitsPixel / 8;
                                                        pos2 = i * bmWidthBytes + (bmWidth - j - 1) * bmBitsPixel / 8;
                                        break;
                                default:
                                        break;
                        break;
                case 270:
                                case 1:
                                        break;
                                case 4:
                                        break;
                                case 8:
                                case 16:
                                case 24:
                                case 32:
                                        int pos1, pos2;
                                                        pos2 = (bmHeight - i - 1) * bmWidthBytes + j * bmBitsPixel / 8;
                                        break;
                                default:
                                        break;
                        break;
                case 0:
                        break;
                default:
                        break;
        return TRUE;
代码大意是看懂了。。。不过太多了。
像我发的那段代码怎么改呢。。
多谢
或者能把这个测试的整个工程文件发我一下么
happytrm@gmail.com
图片分辨率都是4的倍数哦。
82
是哈,知道是4的倍数,可就不知道怎么改了呵.....
sterrys(sterrys)给了不少帮助,可就是不起作用呵..
还不行?
如果是VC做的,把全套的代码发来给你调试一下
是eVC做的,我知道应该就在
int i = l/width;
int j = l%width;
这个地方进行扫描的控制,但不知道如何处理,手头也没有可参考的资料
if(pDes == NULL)
return;
else //逆时针
快来报名!
