2760|0
79
[#TK1117] 4x4 4x4键盘问题,有四个键值始终不对,请大家帮帮忙 [复制链接]
用89c2051做了一个键盘,P1.0-P1.3接上拉电阻,程序如下:
uchar getkey()
    uchar recode,key;
    uchar sccode;
    P1=0xF0;
    if((P1&0xF0)!=0xF0)
            delay(200);                 //延时1MS
        if((P1&0xF0)!=0xF0)
            sccode=0xFE;
        while((sccode&0x10)!=0)
        {                                 P1=sccode;
                 if((P1&0xF0)!=0xF0)
                                     recode=(P1&0xF0)|0x0F;
         keydd=0;                         key=(~sccode)+(~recode);
         key=changekey(key);
         return (key);                        }
    else sccode=(sccode<<1)|0x01;
    if((P1&0xF0)==0xF0)
        delay(200);
        if((P1&0xF0)==0xF0)
             keydd=1;
             return 0;
uchar changekey(uchar keystate)
    switch(keystate)
            case 0x41: keystate=0x47;break;
            case 0x42: keystate=0x49;break;
            case 0x44: keystate=0x45;break;
            case 0x48: keystate=0x42;break;
            case 0x22: keystate=0x48;break;
            case 0x24: keystate=0x46;break;
            case 0x28: keystate=0x43;break;
            case 0x11: keystate=0x51;break;
            case 0x12: keystate=0x16;break;
            case 0x14: keystate=0x11;break;
            case 0x18: keystate=0x41;break;
            *case 0x01: keystate=0x50;break;
            *case 0x02: keystate=0x15;break;
            *case 0x04: keystate=0x12;break;
            *case 0x08: keystate=0x44;break;
            default: break;
    DOG=!DOG;
    return (keystate);
其中打*的四句不对,始终得不到我想要的值(如:keystate=0x50等),其他的都没有问题。一直没有找到原因!请大家帮帮忙看一下,谢谢!
