3217|2
53
sql ce 读取数据出现异常 [复制链接]
各位大虾:
   我的是数据库名字为test.sdf里面有一个user表,但是在SqlCeDataReader dr = cmd.ExecuteReader();时出现异常
   程序如下:
   string constr="Data Source="+Path.GetDirectoryName(Assembly.GetExecutingAssembly().GetName().CodeBase)+"\\test.sdf";
            SqlCeConnection conn=new SqlCeConnection(constr);
            conn.Open();
            SqlCeCommand cmd = conn.CreateCommand();
            cmd.CommandText = "select * from user";
            cmd.CommandType = CommandType.Text;
            dr.Close();
            conn.Close();
   异常描述为:
  未处理 System.Data.SqlServerCe.SqlCeException
  Message=" [ 1,15,user ]"
  HResult=-2147217900
  NativeError=25501
  Source="SQL Server 2005 Mobile Edition ADO.NET Data Provider"
  StackTrace:
    at System.Data.SqlServerCe.SqlCeCommand.ProcessResults()
    at System.Data.SqlServerCe.SqlCeCommand.CompileQueryPlan()
    at System.Data.SqlServerCe.SqlCeCommand.ExecuteCommand()
    at System.Data.SqlServerCe.SqlCeCommand.ExecuteReader()
    at pocketpc_1.Form1.databind()
    at pocketpc_1.Form1.Form1_Load()
    at System.Windows.Forms.Form.OnLoad()
    at System.Windows.Forms.Form._SetVisibleNotify()
    at System.Windows.Forms.Control.set_Visible()
    at System.Windows.Forms.Application.Run()
    at pocketpc_1.Program.Main()
    希望各位大虾能帮帮我
怎么解决的啊~~?我也是这个错误~~!恳请赐教,谢谢!  详情 回复 发表于 2009-7-13 16:29
问题已解决
