4281|0
cymwin _ NMAKE : fatal error U1045: spawn failed : Invalid argument 错误 [复制链接]
Setting environment for using Microsoft Visual Studio .NET 2003 tools.
(If you have another version of Visual Studio or Visual C++ installed and wish
to use its tools from the command line, run vcvars32.bat for that version.)
******************* Revised by peter in 2007-07-12 *******************
cxl@IA-CHENXULIN[1] %cd E:/Intergation/hmi/v184/toyota/05CYcore2_JP_AVN_0718_v06
26/
cxl@IA-CHENXULIN[2] %nmake -f makefile.mak CFG=P05CY_AVN_JP_CORE2 DEBUGMODE=1
Microsoft (R) Program Maintenance Utility Version 7.10.3077
Copyright (C) Microsoft Corporation.  All rights reserved.
CFG = P05CY_AVN_JP_CORE2
DEBUGMODE = 1
CHECKMODE = 0
MAKEFLAGS =
BuildProductVersion = P05CY_AVN_JP_CORE2
Stop.
cxl@IA-CHENXULIN[3] %
是哪儿出问题了呢?
刚开始装cymwin的几天用的好好的。
可过几天就出现上面显示的错误。现在不管我重装该软件多少次,总是这个问题。 我装了.net 2003 和VC 6.0。
记得装了cymwin后用VC 6.0就不好用,提示nmake等错误。等我把VC 6.0搞好,cymwin不好用了。
高手提个解决的方法吧!
