3267|0
75
关于intel ICH7文档中点东西看不懂,望高手指教 [复制链接]
Additionally, BIOS workarounds for power management can be supported by setting
MPC.PMME (D28:F0/F1/F2/F3/F4/F5:Offset D8h:bit 0). When this bit is set, power
management events will set SMSCS.PMMS (D28:F0/F1/F2/F3/F4/F5:Offset DCh:bit 0),
and SMI # will be generated. This bit will be set regardless of whether interrupts or SCI
is enabled. The SMI# may occur concurrently with an interrupt or SCI.
里边的
MPC.PMME (D28:F0/F1/F2/F3/F4/F5:Offset D8h:bit 0). SMSCS.PMMS (D28:F0/F1/F2/F3/F4/F5:Offset DCh:bit 0)都指的是什么,你要去更改或者访问应该用什么函数或者系统调用?(linux)
