2841|5
57
wince5.0启动到不了了,看启动信息对比 [复制链接]
我的平台是pxa270+wince5.0,下面是wince的启动信息,启动到一半就没反应了,不知道问题是在哪个地方,请高手指点。后面我给出了以前曾经正常启动的信息。可以做个对比。
出错的启动信息:
OEMInitDebugSerial using UART1
Windows CE Kernel for ARM (Thumb Enabled) Built on Jun 24 2004 at 18:25:00
ProcessorType=0411  Revision=7
sp_abt=ffff5000 sp_irq=ffff2800 sp_undef=ffffc800 OEMAddressTable = 800b97d4
XSCDBG:Trace initialized: CFG:81c80b9c  Buffer: 81c7f648, 14f0
Sp=ffffc7cc
dm9000 init.
[dm9]: Chip signature is 00200021
camera entry attach.
Camera stream init.
BPC Modified File: uhcddrv.cpp.
Modified File: ohcd.c.
HcdPdd_Init: Checking SW18 - controls OHCI loading.
OhcdPddInitializeAddresses: v_pDCCLKReg:      00660000 = a5800000.
OhcdPddInitializeAddresses: v_pDCGPIOReg:     00670000 = a5300000.
OhcdPddInitializeAddresses: v_pOHCIDMABuffer: 00690000 = a3e70000.
OhcdPddInitializeAddresses: v_pDCUSBOHCIReg:      00680000 = a4200000.
InitPddInterrupts RhPortStatus: 0x0.
OHCI_Reset: Resetting Bulverde OHCI.
OHCI_Reset: done.
!UHCD:GetRegistryConfig OK!!!         IRQ:28.
+CDevice::Initialize
-CDevice::Initialize, success!
HW_XSC1_INIT: BTUART, 0x45B90
DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Drivers\BuiltIn\AFD). Driver cannot be unloaded.
GDE_Init In = 602ed64, 0...
GDE_Init Done...
Enable GP1 Irq
UDC sw connect.
DeviceFolder::LoadDevice!Enumerate Found deprecated load instructions at (Drivers\BuiltIn\PPP). Driver cannot be unloaded.
以前正确的启动信息:
Sp=ffffc7cc
dm9000 init.
[dm9]: Chip signature is 00202021
Camera stream init.
OHCI_Reset: done.
GDE_Init Done...
Enable GP1 Irq
UDC sw connect.
Done getting Registry values:
bpp: 0x10
CxScreen: 0xf0
CyScreen: 0x140
Display Type: LTM035A776C
Found Descriptor: Address= fffd20f4
Found Descriptor: Address= fffd28f4
LTM035A776C init.
Display Driver Initialization Complete
Maximum Allowed Error 5:
SetShape FileMapping Name not Same.
MSIM: IM_ReadRegistry read KB 5
Explorer(V2.0) taskbar thread started.
此帖出自WindowsCE论坛
一个模块一个模块的屏蔽,这样很快就会定位问题所在了。  详情 回复 发表于 2008-11-11 20:49
82
奇怪,就剩下液晶不能了?
此帖出自WindowsCE论坛
"Drivers\BuiltIn\PPP"
这里面是个什么驱动?自己有改动过哪些地方不知道吗?
此帖出自WindowsCE论坛
66
具体修改了什么就查什么
此帖出自WindowsCE论坛
我记得没有修改什么啊,也有可能是我修改了某个地方不记得了。现在的关键是如何找到问题。
此帖出自WindowsCE论坛
59
此帖出自WindowsCE论坛
