6103|2
75
请问如何对BusHound中的URB数据进行分析? [复制链接]
Bus Hound 5.00 capture. Complements of www.perisoft.net
  Device - Device ID (followed by the endpoint for USB devices)
            (34) USB Composite Device
            (35) PHILOG USB Serial CDC Trace (COM2)
            (36) PHILOG USB Serial CDC Modem (COM19)
            (37) USB Mass Storage Device
            (38) TI [ROM= ]
            (39) TI [ROM= ]
            (40) TI [ROM= ]
  Phase  - Phase Type
            ATO   ATA task file command      DO    Data out
            CDB   Command descriptor block   LEN   Data length
            CTL   USB control transfer       SSTS  SCSI request block status
            DI    Data in                    URB   USB request block
  Data   - Hex dump of the data transferred
  Descr  - Description of the phase
  Cmd... - Position in the captured data
  Delta  - Elapsed time from the previous phase to the current phase
  Date   - Date the phase occurred in year/month/day form
  Time   - Time the phase occurred in hour:minute:second.millisec form
比如我有如下数据,该如何对URB部分进行分析呢?我只看到URB最后一行是CTL,其他数据是什么意思就不明白了!
Device  Phase  Data                      Description       Cmd.Phase.Ofs(rep)  Delta  Date        Time
  34.0  CTL    80 06 00 01  00 00 12 00  GET DESCRIPTOR           1.1.0        3.0mn  2008/09/29  03:11:30.666
  34.0  LEN    12 00 00 00               18                       1.2.0        3.2ms  2008/09/29  03:11:30.670
  34.0  DI     12 01 10 01  00 00 00 40  .......@                 1.3.0          3us  2008/09/29  03:11:30.670
               ce fa 3b 12  01 00 02 01  ..;.....                 1.3.8
               03 01                     ..                       1.3.16
  34.0  URB    50 00 08 00  00 00 00 00  CONTROL TRANSFER         1.4.0          4us  2008/09/29  03:11:30.670
               18 3e 78 83  22 00 00 00                           1.4.8
               30 3e 78 83  ab 80 7b 83                           1.4.16
               12 00 00 00  58 fe 16 82                           1.4.24
               60 83 af 86  00 00 00 00                           1.4.32
               ff ff ff ff  0d f0 ad de                           1.4.40
               00 ae 04 80  01 00 00 00                           1.4.48
               58 09 a6 f7  58 09 a6 f7                           1.4.56
               00 00 00 00  00 00 00 00                           1.4.64
               80 06 00 01  00 00 12 00                           1.4.72
为了恢复 我找了半天以前的eeworld账号,没找到 又注册一个 ,结果是这样的结果   详情 回复 发表于 2010-4-5 14:47
我也想知道URB的分析~~~~~~网上找了好久没找到~~~~~~请前辈指点
83
