3041|4
75
请好心人帮忙解答 高分求助 [复制链接]
entity frequencydivider is
    Port ( clk : in  STD_LOGIC;
           clk_div2 : out  STD_LOGIC;
           clk_div4 : out  STD_LOGIC;
           clk_div8 : out  STD_LOGIC);
end frequencydivider;
architecture Behavioral of frequencydivider is
signal count : std_logic_vector(3 downto 0) ;--= "0000";
begin
          process(clk)
                begin
                     if(clk'event and clk ='1')then
                              if(count = "1111") then
                                            count <= (others => '0');
                                   else
                                            count <= count + 1;
                                        end if;
                          end if;
                end process;
                clk_div2 <= count(0)after 20ns;
                clk_div4 <= count(1) after 20ns;
                clk_div8 <= count(2) after 20ns;
end Behavioral;
请问在用波形测试的时候为什么结果为U 和X 呢
warning信息:Warning: There is an 'U'|'X'|'W'|'Z'|'-'
   in an arithmetic operand, the result will be 'X'(es).
谢谢了~
支持一下  详情 回复 发表于 2010-5-19 17:53
95
没人解答一下吗
82
没有初始化,加一个reset信号初始化
82
关注 接分
64
支持一下
