2315|0
63
MSDN <>中的问题: [复制链接]
Super servers address all of these issues. Rather than have each service accept connections on its own thread, services.exe spins one thread on system startup and listens on a number of sockets, up to 64, for services that request it. When an incoming request arrives, services.exe determines the service associated with the incoming connection and notifies the service. The mapping between TCP ports and services is configured through the registry, under the base service key. In the Finger server example, the registry looks like this:
HKEY_LOCAL_MACHINE\Services\FINGERSERVER\Accept\TCP-79
"SockAddr"=hex:02,00,00,4F,00,00,00,00,00,00,00,00,00,00,00,00
Accept 和 SockAddr 的这些值都是什么意思?在哪可以查到 CE 注册表的资料?
