2904|0
62
关于蓝牙dun认证的问题 [复制链接]
wince5.0,navready平台,csr bc04模块,使用wince自带蓝牙组件,应用程序已经完成,准备过sgs蓝牙认证。
现在dun认证卡在aps-02测试项目上,
测试要求如下:
TP/APS/BV-02-I [NT is busy]
To verify that the DT accepts that the NT (or a plain telephone) is busy.
? Initial Condition
Bonding is finished and the DT has connected to the GW using the manufacturer specific Bluetooth connection establishment procedure.
? Test Procedure
1. Make the NT busy, e.g. make sure that the modem of the NT (or a plain telephone) is busy (off hook).
2. On the DT, try to connect to the NT via the GW by dialing the number to the NT.
? Test Condition
N/A
? Expected Outcome
Pass verdict:
The DT must be alerted that the NT is busy.
Fail verdict:
There is no alert on the DT that the NT is busy.
? Notes
N/A
上文的DT:表示我们过认证的设备,NT端表示是认证机构的蓝牙设备。
目前我们可以成功连通手机拨号上网收发数据,也可以通过手机拨出一个市话,但认证机构还要求能通过他们的蓝牙设备(是一台可以模拟蓝牙设备的电脑)连接了电话线来拨出市话。现在这项测试无法通过,用他们的说法是“无法跑circuit connection进而拨出一般市话”
请问是否有人过过类似认证,如何通过这个子项测试,或有什么方法可以模拟出这个测试项目的环境?
