4981|15
56
大家好,请问一个关于串口的问题 [复制链接]
我现在写好了串口驱动,测试的时候发现问题,但是不知道是什么原因,串口只能写不能读
代码如下....
输出是
test uart
com1 open ok
in ComWrite()
com write ABCD.... ok
in ComRead()
大家能帮我找找问题吗??谢谢!!!
#include
#include "taskLib.h"
#include "locale.h"
#include "string.h"
#include "stdlib.h"
#include "Vxworks.h"
#include "configAll.h"
#include "dosFsLib.h"
#include "sioLib.h"
typedef unsigned char BYTE;
int comfd;
int ComPortInit(void)
        int sccfd;
        unsigned char str[10];
        ttyDrv();
        ttyDevCreate("/tyCo/1",sysSerialChanGet(l),512,512);
        sccfd="open"("/tyCo/1",O_RDWR);
        if(sccfd<0)
                logMsg("com 1 open        failed\n",0,0,0,0,0,0);
                return(ERROR);
        else
                logMsg("com 1 open        OK\n",0,0,0,0,0,0);
                ioctl(sccfd,FIOBAUDRATE,9600);
                ioctl(sccfd,FIOSETOPTIONS,OPT_RAW);
        return 0;
int ComWrite(int comid)
        unsigned char sendbuf[20];
        unsigned char sendlen=20;
        unsigned char tempi;
        logMsg("in ComWrite()\n",0,0,0,0,0,0);
        for(tempi=0;tempi<20;tempi++)sendbuf[tempi]=65+tempi;
        sendbuf[19]='\0';
        while(1)
                if((write(comid,sendbuf,sendlen))==ERROR)
                        logMsg("com write EEROR\n",0,0,0,0,0,0);
                else
                        logMsg("com write %s OK\n",sendbuf,0,0,0,0,0);
               taskDelay(60);
int ComRead(int comid)
        unsigned char readbuf[50];
        unsigned char readlen=0;
        unsigned char buf[10];
        fd_set rfds;
        logMsg("in ComRead()\n",0,0,0,0,0,0);
        /*for(tempi=0;tempi<20;tempi++)readbuf[tempi]=0x32;
        readbuf[19]='\0';*/
        while(1)
                FD_ZERO(&rfds);
                FD_SET(comid,&rfds);
                if(select(comid+1,&rfds,NULL,NULL,NULL)< 0 )
                        logMsg("select error,quit Writing\n",0,0,0,0,0,0);
                if( FD_ISSET(comid,&rfds))
                        if(read(comid,buf,1)==ERROR)
                                logMsg("com read EEROR\n",0,0,0,0,0,0);
                        else
                                readbuf[readlen]=buf[0];
                                readlen++;
                                readbuf[readlen]='\0';
                                logMsg("com read %s OK\n",readbuf,0,0,0,0,0);
                                readlen=0;
int testUart()
        logMsg("testUart\n");
        comfd=ComPortInit();
        if(comfd<0)
                logMsg("init comport error\n",0,0,0,0,0);
        else
                taskSpawn ("COMSend", 100, 0, 4096, (FUNCPTR)ComWrite,comfd, 0, 0, 0, 0, 0, 0, 0, 0, 0);
                taskSpawn ("COMRecv", 100, 0, 4096, (FUNCPTR) ComRead,comfd, 0, 0, 0, 0, 0, 0, 0, 0, 0);
select 那几句的问题,我也正弄呢... 还没搞定呢   详情 回复 发表于 2008-8-1 10:31
83
        int sccfd;
        ttyDrv();
        if(sccfd <0)
                return(ERROR);
        else
        return 0;                   // 这个地方错了,应该return sccfd不是return 0
66
呵呵 sorry 那是笔误
原来的程序 比较罗嗦 比如有设置停止位之类的
我把那些功能删除了再发上来
可能是删除的时候 不小心删除了
sorry
原来的程序是正确的,不是return 0,是return sccfd
84
自己顶
75
串口读写应该是双工的吧,写满BUFFER之后就读出来,判断标志位,是否读完,再继续往里面写.
这样一直循环到把你的所有数据都写完.不可以一直不停的只管往里面写数据.
引用 4 楼 yujianhuabcde 的回复:
那么请问已经如何修改代码呢?
75
楼主其他的代码都正确吗??
如果没问题的话,给个最简单的测试方法。。。
  1. int ComRead(int comid)
  2. {
  3.         unsigned char readbuf[50];
  4.         unsigned char readlen=0;
  5.         unsigned char tempi;
  6.         unsigned char buf[10];
  7.
  8.         fd_set rfds;
  9.         logMsg("in ComRead()\n",0,0,0,0,0,0);    // 这句打印了,说明有运行这段代码
  10.         /*for(tempi=0;tempi <20;tempi++)readbuf[tempi]=0x32;
  11.         readbuf[19]='\0';*/
  12.
  13.         while(1)
  14.         {
  15.                 FD_ZERO(&rfds);
  16.                 FD_SET(comid,&rfds);
  17.                 logMsg("111111111111\n",0,0,0,0,0,0);          // 增加此处打印语句
  18.                 if(select(comid+1,&rfds,NULL,NULL,NULL) < 0 )
  19.                 {
  20.                         logMsg("select error,quit Writing\n",0,0,0,0,0,0); // 这句没打,待定
  21.                 }
  22.                 if( FD_ISSET(comid,&rfds))
  23.                 {
  24.                         if(read(comid,buf,1)==ERROR)
  25.                         {
  26.                                 logMsg("com read EEROR\n",0,0,0,0,0,0);    // 这句没打,待定
  27.                         }
  28.                         else
  29.                         {
  30.                                 readbuf[readlen]=buf[0];
  31.                                 readlen++;
  32.                                 readbuf[readlen]='\0';
  33.                                 logMsg("com read %s OK\n",readbuf,0,0,0,0,0);  // 这句没打,待定
  34.                                 readlen=0;
  35.                         }
  36.                 }
  37.                 else
  38.                 {
  39.                         logMsg("2222222\n",0,0,0,0,0,0);          // 增加此处打印语句
  40.                 }
  41.         }
  42. }
复制代码
运行一下看打印结果就知道了
估计就是select前后的那几句代码有问题
83
你的select的参数timeout写完整一点,直接写NULL可能有问题的
57
最好把真实用的代码帖出来,否则谁知道哪个小地方错了呢
79
引用 8 楼 frank_zhou 的回复:
ok
#include
#include "locale.h"
#include "string.h"
#include "stdlib.h"
#include "sioLib.h"
/*UART mode set*/
#define SIO_STOPBIT_SET   0x1020
#define SIO_CHARLGH_SET   0x1021
#define SIO_PTYODD_SET    0x1024
#define SIO_PTYEVE_SET    0x1025
int comfd;
int ComPortInit(int portid,int baudrate,int stopBitLength,int dataLength,int odd_even_none)
        int sccfd;
        int errorflag = 0;
        if(portid<1||portid>4)
                logMsg("Com%d is not existed\n",portid,0,0,0,0,0);
                return(ERROR);
        if(baudrate!=300&&baudrate!=600&&baudrate!=1200&&
                baudrate!=2400&&baudrate!=4800&&baudrate!=9600&&
                baudrate!=19200&&baudrate!=38400&&baudrate!=43000&&
                baudrate!=56000&&baudrate!=57600&&baudrate!=115200&&baudrate!=0)
                logMsg("invalid baudrate\n",0,0,0,0,0,0);
                return(ERROR);
        if(stopBitLength!=1&&stopBitLength!=2&&stopBitLength!=0)
                logMsg("invalid stopbit length\n",0,0,0,0,0,0);
                return(ERROR);
        if(dataLength!=6&&dataLength!=7&&dataLength!=8&&dataLength!=0)
                logMsg("invalid data length\n",0,0,0,0,0,0);
                return(ERROR);
        if(odd_even_none!=1&&odd_even_none!=2&&odd_even_none!=0)
                logMsg("invalid odd even or none verify\n",0,0,0,0,0,0);
                return(ERROR);
        m8270_sccuart_drv(portid);
        errorflag=m8270_sccuart_create(portid) ;
        把串口驱动程序添加到系统中
        ttyDrv();
        下面语句把串口 com2添加到系统中," tyC0/l"是设备名,sysSerialChanGet(1)
        用来获得指向串口描述符的指针,后面两个参数定义了读缓冲区和写缓冲区的大小
        ttyDevCreate("/tyCo/1",sysSerialChanGet(1),100,100);
        if(errorflag== 0)
                logMsg("Com%d init OK\n",portid,0,0,0,0,0);
                sccfd=open("/tyCo/1",O_RDWR,0);
                if(sccfd<0)
                        logMsg("com%d open        failed\n",portid,0,0,0,0,0);
                        return(ERROR);
                else
                        logMsg("com%d open        OK\n",portid,0,0,0,0,0);
                        ioctl(sccfd,FIOFLUSH,0);
                        if(baudrate!=0)
                                ioctl(sccfd,SIO_BAUD_SET,baudrate);
                        if(stopBitLength!=0)
                                ioctl(sccfd,SIO_STOPBIT_SET,stopBitLength);
                        if(dataLength!=0)
                                ioctl(sccfd,SIO_CHARLGH_SET,dataLength);
                        switch(odd_even_none)
                                case 1:
                                        ioctl(sccfd,SIO_PTYODD_SET,0);
                                        break;
                                case 2:
                                        ioctl(sccfd,SIO_PTYEVE_SET,0);
                                        break;
                                default:
                                        break;
                        return(sccfd);
        else
                logMsg("Com%d init failed\n",portid,0,0,0,0,0);
                return(ERROR);
        sendbuf[19]='\0';
        while(1)
                else
                taskDelay(60);
        fd_set rfds;
        readbuf[19]='\0';*/
        while(1)
                FD_ZERO(&rfds);
                logMsg("in ComRead 1\n",0,0,0,0,0,0);
                        else
                                logMsg("in ComRead 2\n",0,0,0,0,0,0);
                                readlen++;
                                if(buf[0]=='A')
                                        readlen=0;
                else
                        logMsg("in ComRead 0\n",0,0,0,0,0,0);
int testUart()
        comfd=ComPortInit(1,19200,1, 8, 0);
        if(comfd<0)
        else
75
--! 怎么用写字板没有了缩进那么恶心啊
唉 这台机子没有VIM 大家将就点吧
87
贴代码的时候用“插入源码”功能(回复)就可以格式化代码了。
62
你的BUFFER有多大?你就先发送这么大小的字节数,再读一次这么大小的字节数.再循环N次,直到发送完你需要的大小.
我不会上层的函数,我看过的是最基本的函数,所以不会改代码.我也不清楚这样可不可以,你试试好了.
for(i=0,i {
taskSpawn ("COMSend", ?, 0, ?, (FUNCPTR)ComWrite,comfd, 0, 0, 0, 0, 0, 0, 0, 0, 0);
taskSpawn ("COMRecv", ?, 0, ?, (FUNCPTR) ComRead,comfd, 0, 0, 0, 0, 0, 0, 0, 0, 0);
有问题请先GOOGLE,BAIDU
82
等待牛人来答.
91
还没搞定呢
