3611|2
90
做USB驱动无法读回数据,请各位高手帮忙看下这段代码是不是有错....谢过 ! [复制链接]
  1. void THVMSDevice::SerialRead(KIrp I)
  2. {
  3.         T.Trace(TraceInfo, __FUNCTION__"++.  IRP %p\n", I);
  4.         T.Trace(TraceInfo, __FUNCTION__"gotoRead -----successful!\n");
  5.         NTSTATUS status = STATUS_SUCCESS;
  6.         KMemory Mem(I.Mdl());        // Declare a memory object
  7.         // Get a pointer to the caller's buffer.  Note that this
  8.         // routine is safe on all platforms.
  9.         PUCHAR pBuffer = (PUCHAR)Mem.MapToSystemSpace();
  10.         ULONG readSize = I.ReadSize();
  11.         ULONG bytesRead = 0;
  12.         BOOLEAN bshortOK = TRUE;
  13.         T.Trace(TraceInfo, __FUNCTION__"++.  READSIZE: %l \n",readSize);
  14.         // TODO: At this point, perform any processing for IRP_MJ_READ
  15.         //                 To satisfy the read now, transfer data from the driver
  16.         //                 to the caller's buffer at "pBuffer".  Then, indicate
  17.         //                 how much data was transferred:
  18.         //I.Information() = bytesRead;//临时注释掉
  19.         I.Status() = status;
  20.
  21.         // NextIrp completes this IRP and starts processing
  22.         // for the next IRP in the driver managed queue.
  23.         if ((readSize>PAGE_SIZE)||(readSize<64))
  24.         {
  25.                 T.Trace(TraceInfo, __FUNCTION__"@@@@@@@Readsizeout!\n");
  26.                 I.Status() = STATUS_INVALID_PARAMETER;
  27.                 ReadQueue.PnpNextIrp(I);
  28.         }
  29.         else
  30.         {
  31.                 // TODO: copy data
  32.                 //                 To satisfy the ioctl now, transfer data using the
  33.                 //                 caller's buffers at "inputBuffer" and/or "outputBuffer".
  34.                 //                 Then, indicate how much data was transferred:
  35.                 bshortOK = readSize
  36.
  37.                 PURB pUrb =Pipe0.BuildBulkTransfer(Mem,readSize,TRUE,NULL,bshortOK,NULL);
  38.                 if(NULL == pUrb)
  39.                 {
  40.                         T.Trace(TraceInfo, __FUNCTION__"URB IS NULL!!!!!!!!\n");
  41.                         I.Status() = STATUS_INSUFFICIENT_RESOURCES;
  42.                         ReadQueue.PnpNextIrp(I);
  43.                 }
  44.                 else
  45.                 {
  46.                         status = Pipe0.SubmitUrb(pUrb,LinkTo(OnTransferComplete),this,100);
  47.                         if ( !NT_SUCCESS(status) )
  48.                         {
  49.                                 T.Trace(TraceInfo, __FUNCTION__"SerialRead -----failed!\n");
  50.                                 I.Status() = status;
  51.                         }
  52.                         else
  53.                         {
  54.                                 T.Trace(TraceInfo, __FUNCTION__"SerialRead -----successful!\n");
  55.                         }
  56.                         ReadQueue.PnpNextIrp(I);
  57.
  58.                 }
  59.         }
  60.         T.Trace(TraceInfo, __FUNCTION__"--.  IRP %p, STATUS %x\n", I, status);
  61. }
复制代码
你多设几处trace,用来输出缓冲区的数据,在DriverMonitor中看看数据到哪就断了。  详情 回复 发表于 2008-1-11 15:40
86
DriveStudio下的?
75
