2777|2
84
evc4.0调试出错 [复制链接]
初学嵌入式开发
使用的环境是evc4.0+evc4.0 sp4
运行一个实例程序时出现以下错误提示:
"An Application targeting a standard SDK for windows CE .Net and built for the X86 CPU can't be run on the Emulator device.In order to run this application on any cpu other than the Emulator,you will have to install an SDK that compatible with the standard SDK for Windows CE .Net,then target a shadow platform pertaining to that SDK."
请教高手该如何解决这个问题。谢谢!
高手一语点破 谢谢啊  详情 回复 发表于 2008-11-11 15:58
请在工具栏中选择正确的平台,不能先X86,需要选择Emulator
67
高手一语点破
谢谢啊
