3075|4
84
有老鸟帮我看看这个定时器中断写的有问题吗? [复制链接]
#include
#include
#include
#include
#include
#include
#define uchar unsigned char
#define uint unsigned int
sfr WDTRST = 0xA6;
  sbit RW    = P1^5;
  sbit         Elcm=P1^4;
   sbit         ad0=P0^7;
        sbit         p03=P0^3;
   sbit         tt=P2^0;
   sbit         t0=P3^4;
    sbit     PINEOC=P1^2;
sbit DR=P1^0;
sbit MDR=P1^1;
#define DataPort P0
#define ADDRPort P2
#define Busy                 0x80
#define Work_M                0x38//n=1,f=0
#define Cls                        0x01
#define Input_M         0x06//i/d=1  ac++  s=0 screen move=off
#define Screen_Off         0x08
#define Disp_M                0x0c//d=1 disp=on c=0 cursor=off
#define Ddram_Al1        0x80;
#define Ddram_Al2        0xc0;//0x80+0x40
#define    Wait1us        _nop_();
#define    Wait2us        {_nop_();_nop_();}
#define    Wait4us        {Wait2us;Wait2us;}
#define    Wait8us        {Wait4us;Wait4us;}
#define    Wait10us      {Wait8us;Wait2us;}
   unsigned char  com,dat;
//           uchar xdata ramadd _at_ 0x0200;
unsigned char xdata h1add _at_ 0xff71;
unsigned char xdata h2add _at_ 0xff6f;
unsigned char xdata h3add _at_ 0xff8f;
unsigned char xdata le1 _at_ 0xff10;
unsigned char xdata le2 _at_ 0xff11;
unsigned char xdata opp _at_ 0x0088;
unsigned char xdata AD0 _at_ 0xff40;
unsigned char xdata AD1 _at_ 0xff42;
unsigned char xdata AD2 _at_ 0xff44;
unsigned char xdata AD3 _at_ 0xff46;
unsigned char xdata AD4 _at_ 0xff48;
unsigned char xdata AD5 _at_ 0xff4A;
unsigned char xdata AD6 _at_ 0xff4C;
unsigned char xdata AD7 _at_ 0xff4E;
unsigned char xdata c8251 _at_ 0xff50;
unsigned char xdata d8251 _at_ 0xff51;
unsigned char xdata COM8279 _at_ 0xff00;             //8279com
unsigned char xdata DATA8279 _at_ 0xff01;             //8279data
unsigned char count;
unsigned char  FREQ;
uchar temp;
unsigned char  temp2;
void  displcd(void);
uchar dispc[2][16]=
        ' ','W','E','L','C','O','M','E',' ','P','O','W','E','R',' ',' ',
        ' ',' ',' ',' ',' ',' ',' ',' ',' ',' ','d','B','m',' ',' ',' '
  code  unsigned char ctab[19]={'0','1','2','3','4','5','6','7','8','9','a','b','c','d','<','>','L','O','W'};
            void Delay(uint i)
        uint j;
    for(;i>0;i--)
            { for(j=1;j>0;j--);}
        void initlcd(void){
RW=0;
_nop_();
        le1=Work_M;
        Delay(50);
    le1=Screen_Off;
                  Delay(50);
    le1=Cls;
                  Delay(50);
    le1=Input_M;
                Delay(50);
           le1=Disp_M;
                Delay(50);
   RW=1;
void displcd(void){                               //LCD1602
uint i;
RW=0;
_nop_();
  le1=Ddram_Al1;
Delay(200);
  for (i=0;i<16;i++)
        le2=dispc[0];
        Delay(200);
le1=Ddram_Al2;
Delay(20);
  for (i=0;i<16;i++)
        le2=dispc[1];
        Delay(20);
         // 写字符
  //le2='0';
         // 写字符
   RW=1;
void main(void)
     uchar temp;
      uchar A,co;
      uchar B;
      uchar C;
      uchar D;
//以下设置中断和定时器;
EA=1; PT0=1;
ET0=1;
IT0=1;IT1=1;
EX0=1;EX1=1;
TCON=0x08;
TMOD=0x21;
//定时器0为产生1ms的中断,定时器1为9600b/s的波特率发生器;
TH0=-1000/256;
TL0=-1000%256;
TL1=0xfd;
TH1=0xfd;
SCON=0x50;
PCON=0x80;
//开定时器
TR1=1;
TR0=1;
TI=1;
IE1=0;
IE0=0;
EX1=1;
ES=1;
DR=1;
MDR=1;
RI=1;
while(1){
if(FREQ==80)
     FREQ=0;
     temp=AD0;
     A = temp/1000;
         B = temp%1000/100;
         C = temp%1000%100/10;
         D = temp%1000%100%10;
         co=A*1000+B*100+C*10+D;
         dispc[1][1]        =ctab[B];
         dispc[1][2]        =ctab[C];
     dispc[1][3]        =ctab[D];
     initlcd();
     displcd();
   Delay(30000);
   TH0=-1000/256;
   TL0=-1000%256;
void intsvr1(void) interrupt 1         //ADC0809
//重新装入定时器0的初值;
  TH0=-10000/256;
  TL0=-10000%256;
         FREQ=FREQ+1;
void com_interrupt () interrupt 4 using 1      //485
uchar temp2;
EA=0;
TI=0;
RI=0;
ES=0;
                           SBUF=0x1A;
                            DR = 0 ;
                           while(!TI);
              Delay(2000);
              REN=1;   //允许串口中断
              DR=1;
              while(!RI){};         //等待计算机发来消息
                   RI   =0;
              temp2=SBUF;       //读取消息
              dispc[1][7] =  ctab[temp2];
              displcd();
              SBUF=temp2;
                          TI=0;
              initlcd();
              displcd();//发送字符
                       Delay(2000);
  EA=1;
  TI=1;
  ES=1;
shuiyan,谢谢你了。 我是个新手,所以很多东西都不是很会的。麻烦了~  详情 回复 发表于 2008-7-15 09:27
我的问题是,我不知道定时器中断有没有执行,而且串口中断没办法实现。
而且我在main程序的while(1)里面加的程序,是不是错误的做法?
这个帖子也是你的吧。。。
http://topic.eeworld.net/u/20080708/10/9fd4b320-0a56-425e-a734-0c6a2dd3696d.html
TH0=-1000/256;
TL0=-1000%256;
你写这么复杂干吗?排错都不方便。
直接新建一个新的project,然后只使用定时器中断,在中断里面控制一个IO口取反,这样就看该IO口有没有方波,就能判断定时器中断有没有效果。
84
最方便的方法是使用有在线调试功能的单片机(如飞利浦的),通过断点调试很容易就知道了
78
shuiyan,谢谢你了。
快来报名!
