5002|13
55
CE5.0下如何生成.cod文件? [复制链接]
如题,如何生成.cod文件?
在通过PB帮助和上网查资料,都说是Set WINCECOD=1之后重新Build。
可是我按这个方法Build驱动,为什么没法生成.cod文件。
那位生成过的介绍一下方法啊。
我和楼主犯了错误了,哈哈。 我是编译出的是release, 肯定没有这个东西了。 不知道楼主是否也是编译出的是release  详情 回复 发表于 2008-10-22 16:21
84
有没有人生成过啊?
75
没有生成过
最好:clear and build
65
set WINCECOD=1, build –c, and then open the COD file from obj\%_TGTCPU%\%WINCEDEBUG%. It’ll be named after the C or CPP file – in this case devpnp.cod.  The function name will appear several times in the COD file, but in only one case will the function name be followed by the word “PROC,” and this is the beginning of the assembly code for that function.  Here’s a sample that’s munged a little from reality.
_I_AdvertiseDeviceInterface PROC NEAR                 ; COMDAT
; 348  : {
  001e8     55          push ebp
  001e9     8b ec       mov  ebp, esp
  001eb     81 ec 14 02 00
      00          sub  esp, 532         ; 00000214H
  001f1     a1 00 00 00 00    mov  eax, DWORD PTR ___cke
  001f6     53          push ebx
  001f7     56          push esi
; 349  :     ULONG result = ERROR_SUCCESS;
  001f8     33 f6       xor  esi, esi
As you can see, the source code and line numbers are included in the COD file next to the assembly code that implements the source.  Each assembly instruction is labeled with an address.  So the COD file provides the mapping from function offset to source line.  Sometimes the assembly for the function is labeled starting with 0, and sometimes not.  (I believe it may depend on which compiler is being used – meaning it varies by CPU type.)  If not, you have to take the function start label into account.  So in this example the function starts at label 0x001E8.
---------------没有生成过,这是我在一个老外博客上看到的。
75
Platform Builder: Find the Source of a Data Abort; an Example http://geekswithblogs.net/BruceEitman/archive/2008/06/02/platform-builder-find-the-source-of-a-data-abort-an.aspxPreviously I posted instructions for finding the source of a data abort, see  Windows CE: Finding the cause of a Data Abort.  This will walk through those steps to find the source in a real application for.  This is specific to Windows CE and later.
I have this data abort:
AKY=00000005 PC=02c138ac(lan91c111.dll+0x000038ac) RA=02c138a8(lan91c111.dll+0x000038a8) BVA=06000000 FSR=00000007
From this, I can see that it is in lan91c111.dll.  Lan91c111.dll is my Ethernet driver.  I was just making changes to it, so I could go back and review my changes for hints.  But let's find it from the Data Abort output.
We can also see that the Return Address (RA) is at 0x000038a8
Subtract 0x1000 to find the Module Offset(MO) of 0x000028a8
We can now look up the Module Offset in lan91c111.map.  Here is a small section of lan91c111.map:
Address         Publics by Value              Rva+Base     Lib:Object
0001:00002780       READ_ETH_USHORT_32BIT_MODE 10003780 f   LAN91C111_Init.obj
0001:00002798       WRITE_ETH_USHORT_32BIT_MODE 10003798 f   LAN91C111_Init.obj
0001:000027cc       WRITE_ETH_CUSTOMIZE_USHORT 100037cc f   LAN91C111_Init.obj
0001:00002820       LAN91C_Write16             10003820 f   LAN91C111_Init.obj
0001:00002884       LAN91C111_MiniportInitialize 10003884 f   LAN91C111_Init.obj
0001:00002fc4       LAN91C111_MiniportISR      10003fc4 f   LAN91C111_Intr.obj
Looking at the addresses we find that the MO is between 00002884 LAN91C111_MiniportInitialize and 00002fc4 LAN91C111_MiniportISR.  That tells us that the Data Abort occurred in LAN91C111_MiniportInitialize.  To calculate the Instruction Offset(IO) subtract the Function Offset(FO) from the Module Offset:  0x00002858 - 0x00002884 = 0x28.
The file that contains LAN91C111_MiniportInitialize is Lan91C111.c, which we know because of the name of the object file that the function is in.  But, what we need is the COD file, which contains the C code as comments mixed with the assembly code that was created when the file was compiled.  The COD files are in the same folder that the OBJ files are in.  If you don't have the COD files, set WINCECOD=1 and rebuild.
Looking in the COD file, find the function; in this case LAN91C111_MiniportInitialize.  This is what mine looks like:
00000    AREA  |.rdata| { |??_C@_1BC@ECFINIDN@?$AA?$CK?$AAp?$AAt?$AAr?$AA?5?$AA?$CF?$AAX?$AA?6?$AA?$AA@| }, DATA, READONLY, SELECTION=2 ; comdat any
|??_C@_1BC@ECFINIDN@?$AA?$CK?$AAp?$AAt?$AAr?$AA?5?$AA?$CF?$AAX?$AA?6?$AA?$AA@| DCB "*"
DCB 0x0, "p", 0x0, "t", 0x0, "r", 0x0, " ", 0x0, "%", 0x0, "X"
DCB 0x0, 0xa, 0x0, 0x0, 0x0   ; `string'
; Function compile flags: /Ogsy
  00000    AREA  |.text| { |LAN91C111_MiniportInitialize| }, CODE, ARM, SELECTION=1 ; comdat noduplicate
  00000   |LAN91C111_MiniportInitialize| PROC
; 144  : {
  00000   |$L48878|
  00000 e92d47f0  stmdb       sp!, {r4 - r10, lr}
  00004 e24dd054  sub         sp, sp, #0x54
  00008   |$M48876|
  00008 e1a06003  mov         r6, r3
  0000c e1a04002  mov         r4, r2
  00010 e1a07001  mov         r7, r1
; 145  :     NDIS_STATUS         Status = NDIS_STATUS_SUCCESS;
; 146  :     UINT                ArrayIndex;
; 147  :     PMINIPORT_ADAPTER   Adapter;
; 148  :     USHORT              temp;
; 149  :
; 150  :     LPVOID              lpIOBase;
; 151  :     BOOL                RetVal;
; 152  :  DWORD    *ptr = NULL;
; 153  :     WCHAR szFunctionName[]  = L"LAN91C111_MiniportInitialize()";
  00014 e59f1720  ldr         r1, [pc, #0x720]
  00018 e28d0014  add         r0, sp, #0x14
  0001c e3a0203e  mov         r2, #0x3E
  00020 eb000000  bl          memcpy
; 154  :
; 155  :
; 156  :  RETAILMSG( 1, (TEXT("*ptr %X\n"), *ptr ));
  00024 e3a03000  mov         r3, #0
  00028 e5931000  ldr         r1, [r3]
  0002c e59f0704  ldr         r0, [pc, #0x704]
  00030 eb000000  bl          NKDbgPrintfW
The numbers on the left of the assembly code are the Function Offsets, and we can see that at offset 0x28 we have:
Which is dereferencing an indirect address which we can see is the *ptr in the C code above it:
Now the hard part, why is dereferencing the pointer a problem?  In this case, it is because ptr is NULL, but you may need to get out a debugger to find the cause.  But at least we now know where the problem is.
In some cases, you may need to start with the Program Counter (PC) insteaad of the Return Address (RA) to find the source of the problem.
-----------------这些都没有试过,是个比较牛的人写得。
楼主如果弄出来的话,把方法贴出来。
你说的那个Blog我也看到过,就是按上面的去试的。发现无法生成.cod文件。
后来看帮助文档,也就说是set WINCECOD=1。 不过这个值实际上默认就是设
为1的。也没有发现有对应的.cod生成。郁闷。
61
引用 5 楼 gsymichael 的回复:
会不会是你没有找对生成的路径?
89
不是和.obj在一个目录下吗?我看了没有。而且用搜索文件找也没有
84
the COD file from obj\%_TGTCPU%\%WINCEDEBUG%. ----------如果没有,那估计真有问题了。有些文件是搜索不到的。
67
我一直可以的,设置好环境变量后build,然后在obj目录下就是大把的cod了
66
引用 9 楼 songtitan 的回复:
如何设置呢?只是简单的设WINCECOD=1就可以了吗?
还需要设置其他的什么吗?
81
我现在马上试试
81
驱动的source文件里面加个 WINCECOD=1
把debug里面的文件删了
重新编译驱动,里面就有了吧~
反正我这儿好用~~
引用 12 楼 lmlmlmnew 的回复:
把debug里面的文件删了
重新编译驱动,里面就有了吧~
反正我这儿好用~~
我和楼主犯了错误了,哈哈。
我是编译出的是release,
肯定没有这个东西了。
