3502|4
急!!!Win32编程(CE) [复制链接]
#include
#define IDI_APPLICATION     MAKEINTRESOURCE(32512)
#define WS_OVERLAPPEDWINDOW (WS_OVERLAPPED     | \
                             WS_CAPTION        | \
                             WS_SYSMENU        | \
                             WS_THICKFRAME     | \
                             WS_MINIMIZEBOX    | \
                             WS_MAXIMIZEBOX)
LONG WINAPI WndProc(HWND,UINT,WPARAM,LPARAM);
int WINAPI WinMain(HINSTANCE hInstance,HINSTANCE hPrevInstance,LPWSTR lpCmdLine,int nCmdShow)
        WNDCLASS wc;
        HWND hwnd;
        MSG msg;
        BOOL bReg;
        wc.style = CS_HREDRAW|CS_VREDRAW;
        wc.lpfnWndProc = (WNDPROC)WndProc;
        wc.cbClsExtra = 0;
        wc.cbWndExtra = 0;
        wc.hInstance = hInstance;
        wc.hIcon = LoadIcon(NULL,IDI_APPLICATION);
        wc.hCursor = LoadCursor(NULL, IDC_ARROW);
        wc.hbrBackground = (HBRUSH)(COLOR_WINDOW+1);
        wc.lpszMenuName = NULL;
        wc.lpszClassName = L"First Window Class";
        RegisterClass(&wc);
        hwnd = CreateWindow(
                                  L"First Window Class",
                                  L"第一个Windows应用程序",
                                                  WS_OVERLAPPEDWINDOW,
                                                  CW_USEDEFAULT,
                                                  CW_USEDEFAULT,
                                                  200,
                                                  300,
                                                  HWND_DESKTOP,
                                                  NULL,
                                                  hInstance,
                                                  NULL
        ShowWindow(hwnd,nCmdShow);
        UpdateWindow(hwnd);
        int bRet;
        while((bRet=GetMessage(&msg,NULL,0,0))!=0)
                if(bRet == -1)
                else
                        TranslateMessage(&msg);
                        DispatchMessage(&msg);
        return msg.wParam;
LRESULT CALLBACK WndProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam)
        PAINTSTRUCT ps;
        HDC hdc;
        LPCWSTR szHello = L"欢迎使用VC++2005";
        switch(message)
        case WM_PAINT:
                hdc = BeginPaint(hWnd, &ps);
                RECT rc;
                GetClientRect(hWnd, &rc);
                DrawText(hdc, szHello, 12, &rc, DT_CENTER);
                EndPaint(hWnd,&ps);
                return 0;
        case WM_DESTROY:
                PostQuitMessage(0);
                return 0;
        return DefWindowProc(hWnd, message, wParam, lParam);
因为开始时,出现错误:
.\Win32Project.cpp(15) : error C2065: 'IDI_APPLICATION' : undeclared identifier
.\Win32Project.cpp(35) : error C2065: 'WS_OVERLAPPEDWINDOW' : undeclared identifier
所以我只能在文件开始处,自己定义:
                             WS_CAPTION        | \
                             WS_SYSMENU        | \
                             WS_THICKFRAME     | \
                             WS_MINIMIZEBOX    | \
                             WS_MAXIMIZEBOX)
这样定义好以后,编译是通过了,但是运行的时候出现连接错误:
Linking...
Win32Project.obj : error LNK2019: unresolved external symbol __security_cookie referenced in function "long __cdecl WndProc(struct HWND__ *,unsigned int,unsigned int,long)" (?WndProc@@YAJPAUHWND__@@IIJ@Z)
Win32Project.obj : error LNK2019: unresolved external symbol __security_check_cookie referenced in function "long __cdecl WndProc(struct HWND__ *,unsigned int,unsigned int,long)" (?WndProc@@YAJPAUHWND__@@IIJ@Z)
Pocket PC 2003 (ARMV4)\Debug/Win32Project.exe : fatal error LNK1120: 2 unresolved externals
问题1:是不是需要加什么头文件,就可以不用自己定义IDI_APPLICATION和WS_OVERLAPPEDWINDOW了啊?
问题2:连接错误的话应该怎么解决?
注意:我用的是VS2005,在Win32 Smart Device Project中新建项目并添加的C++文件里编译的。(我在Win32 Project中新建项目添加的C++文件里编译和运行都可以通过的。不知道为什么?)
谢谢帮忙!
谢谢!原因是没有加stdafx.h文件。  详情 回复 发表于 2008-8-27 09:36
1,IDI_APPLICATION应该是icon,搜索IDI_APPLICATION看在哪个头文件里定义的;
2,vs2005我不懂,但是查到http://blog.eeworld.net/tonxi/archive/2007/04/09/1557863.aspx
59
1、 WS_OVERLAPPEDWINDOW在ce下不支持,可以通过
WS_OVERLAPPED | WS_CAPTION | WS_SYSMENU | WS_THICKFRAME | WS_MINIMIZEBOX | WS_MAXIMIZEBOX
这个组合来实现。
2、IDI_APPLICATION:应该包含在 Winuser.h 中。
3、链接错误:
1)可能是有些cpp文件没有包含在项目中。
通过加入存在的文件加入进来就行了。
2)可能是没有包含库文件
你检查一下提示的函数是在什么库中定义的,把该库加入就搞定了。
mark
