4362|5
62
EDMA中的内存块大小问题 [复制链接]
我们开发一个大硬盘的驱动程序,使用EDMA与内存传输数据,每次只能传输4K个数据量,如果我把传输值增加到8K,用WinDbg调试出现内存错误,目标机死机。信息如下:
Fatal System Error: 0x000000c2
                 (0x00000007,0x00001153,0x00000000,0x865205D8)
Break instruction exception - code 80000003 (first chance)
如果我把数据分两次传,每次4K,然后拷到缓冲区,还有这样的问题。请问有没有方法解决这个问题?
  详情 回复 发表于 2008-3-26 16:17
63
This is your code. Generally, you would want to recompile with perhaps GetLastError() and print it out. However, you do not have to do that. Although in this case it may be simple to, if you're stepping through code and a function fails, wouldn't you want to know what happened on the spot? Let's try to debug this. First, we'll start the debugger and break on our function. Since we have symbols, this is easy. If we didn't, we could just break on CreateFile as it is an exported symbol and would always be available.
58
我在kd>下敲入命令!analyze -v,出现:
Cannot get _POOL_TRACKER_BIG_PAGES type size
MODULE_NAME:  nt
FAULTING_MODULE: 804e0000 nt
DEBUG_FLR_IMAGE_TIMESTAMP:  3e8015c6
POOL_ADDRESS:  863ec800
BUGCHECK_STR:  0xc2_7
DEFAULT_BUCKET_ID:  DRIVER_FAULT
LAST_CONTROL_TRANSFER:  from 80545108 to 804e11c0
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
f7899fd8 80545108 00000003 00000000 863ec7f8 nt!DbgBreakPointWithStatus+0x20
f789a340 805455b9 000000c2 00000007 00001153 nt!KeRegisterBugCheckReasonCallback+0x688
f789a360 8056aa72 000000c2 00000007 00001153 nt!KeBugCheckEx+0x19
f789a3c0 80625e5a 863ec800 00000000 00000000 nt!ExFreePool+0x1642
f789a3dc 80627258 00000000 00000000 f789a61c nt!IoReadPartitionTable+0x73a
f789a3f8 8062914d 00000002 f789a61c f7722080 nt!IoReadPartitionTableEx+0x68
f789a5b8 00240023 80f64d90 00240023 80f64dc8 nt!IoGetBootDiskInformation+0x14d
00002000 00000000 00000000 00000000 00000000 0x240023
STACK_COMMAND:  .bugcheck ; kb
FOLLOWUP_NAME:  MachineOwner
BUCKET_ID:  WRONG_SYMBOLS
Followup: MachineOwner
什么原因?
66
支持一下
64
楼上两位说的都很有道理,我要补充的是,
你可以检查一下驱动里的IRP串行化处理是否处理对了
EDMA是有一个一次性搬运的上限的,而多次搬运出错,极可能是互斥访问的冲突问题。
56
引用 3 楼 szmuma 的回复:
支持一下
