3134|4
给串口发送数据问题 [复制链接]
我收集了一些GPS数据在t.txt文档中,现在要将这里面的数据通过虚拟串口发给一个PC版的导航软件。
但我这发送有点问题,点一下就发送一部分数据,再点一下又发送一部分
请问下如何才能让程序自动一步一步发啊~~?请赐教
代码如下:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using System.IO.Ports;
using System.Threading;
using System.IO;
namespace WindowsApplication1
    public partial class Form1 : Form
        SerialPort _serialPort;
        string filename = @"E:\t.txt";
        StreamWriter sw = null;
        bool _continue = true;
        public Form1()
            InitializeComponent();
        private void InitPort()
            StringComparer stringComparer = StringComparer.OrdinalIgnoreCase;
            // Create a new SerialPort object with default settings.
            _serialPort = new SerialPort();
            // Allow the user to set the appropriate properties.
            _serialPort.PortName = "COM5";//SetPortName(_serialPort.PortName);
            _serialPort.BaudRate = 4800;// SetPortBaudRate(_serialPort.BaudRate);
            _serialPort.Parity = Parity.None;// SetPortParity(_serialPort.Parity);
            _serialPort.DataBits = 8;//SetPortDataBits(_serialPort.DataBits);
            _serialPort.StopBits = StopBits.One;// SetPortStopBits(_serialPort.StopBits);
            _serialPort.Handshake = Handshake.RequestToSend;// SetPortHandshake(_serialPort.Handshake);
            _serialPort.RtsEnable = true;
            // Set the read/write timeouts
            _serialPort.ReadTimeout = 500;
            _serialPort.WriteTimeout = 500;
            _serialPort.Open();
        public void Read()
            while (_continue)
                try
                    //string message = _serialPort.ReadLine();
                    sw.Write(message);
                    //Console.WriteLine(message);
                catch (TimeoutException) { }
            sw.Close();
        private void Form1_Load(object sender, EventArgs e)
            InitPort();
        private void btnRead_Click(object sender, EventArgs e)
            _continue = true;
            sw = new StreamWriter(filename, true);
            Thread readThread = new Thread(Read);
            readThread.Start();
        private void btnStop_Click(object sender, EventArgs e)
            _continue = false;
        private void btnWrite_Click(object sender, EventArgs e)
            StreamReader sr = new StreamReader(filename);
            while (sr.Peek() != -1)
                string message = sr.ReadLine();
                //try
                    _serialPort.WriteLine(message);
                //catch (TimeoutException) { }
            sr.Close();
msdn中关于WriteLine方法有一段解释: 如果输入缓冲区中的字节数太多,并且 Handshake 设置为 XOnXOff,则 SerialPort 对象可能会在等待设备准备接受更多数据的过程中引发 TimeoutException。 写入的输出包括 NewLine 字符串。 估计就是你发送的太快了吧。没有做过.net的串口,那个Handshake 可能能解决你这个问题,用汇编的时候都是用中断去做的。   详情 回复 发表于 2008-6-16 22:47
66
你怎么知道只发送了一部分?
还有没看到你往写串口的指令
难道.net不用writefile??没玩过.net飘过
写到缓冲区就行了
用_serialPort.WriteLine(message);
66
搞个定时器,定时分析txt是否要发送 ?
81
ADI 有奖直播报名中~
直播时间:3月27日(周四) 上午10:00-11:30
直播主题:易于驱动SAR型ADC的原理、优点及应用介绍
好礼等你拿~
