3370|4
75
求CRC校验程序 [复制链接]
现有电脑与单片机串口通讯数据
请大侠求证CRC校验方法 多谢
发送:
A5 A5 00 1E 00 00 01 35 CA EC
A5 A5 00 1E 00 01 01 35 FA DB
A5 A5 00 1E 00 02 01 35 AA 82
A5 A5 00 1E 00 03 01 35 9A B5
A5 A5 00 1E 00 04 01 35 0A 30
A5 A5 00 1E 00 05 01 35 3A 07
A5 A5 00 1E 00 06 01 35 6A 5E
A5 A5 00 1E 00 07 01 35 5A 69
接收:
A5 A5 00 1E 01 00 02 35 00 A3 05
A5 A5 00 1E 00 01 02 35 00 46 D9
A5 A5 00 1E 00 02 02 35 00 CB E8
A5 A5 00 1E 00 03 02 35 00 2E 34
A5 A5 00 1E 00 04 02 35 00 03 65
A5 A5 00 1E 00 05 02 35 00 B7 13
A5 A5 00 1E 00 06 02 35 00 3A 22
A5 A5 00 1E 00 07 02 35 00 8E 54
mark  详情 回复 发表于 2008-1-7 16:12
没看明白是什么意思!
就是要程序 ,是吧?
UBYTE const code auchCRCHi[] =
        0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
        0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
        0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
        0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
        0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
/* CRC低位字节值表*/
UBYTE const code auchCRCLo[] =
        0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7,
        0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E,
        0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09, 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9,
        0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC,
        0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
        0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32,
        0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D,
        0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A, 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38,
        0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF,
        0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
        0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1,
        0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4,
        0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F, 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB,
        0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA,
        0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
        0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0,
        0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97,
        0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C, 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E,
        0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89,
        0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
        0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83,
        0x41, 0x81, 0x80, 0x40
UWORD crc16(UBYTE xdata* puchMsg, UBYTE usDataLen)
        unsigned char uchCRCHi = 0xFF ; /* 高CRC字节初始化 */
        unsigned char uchCRCLo = 0xFF ; /* 低CRC 字节初始化 */
        unsigned uIndex ; /* CRC循环中的索引 */
        while (usDataLen--) /* 传输消息缓冲区 */
                uIndex = uchCRCHi ^ *puchMsg; /* 计算CRC */
                puchMsg++;
                uchCRCHi = uchCRCLo ^ auchCRCHi[uIndex];
                uchCRCLo = auchCRCLo[uIndex] ;
        return (uchCRCHi << 8 | uchCRCLo) ;
这就是CRC校验程序
84
mark
电源解决方案和技术 | DigiKey 应用探索站
