Only Plug and Play drivers can issue IOCTL_STORAGE_QUERY_PROPERTY requests. Legacy drivers should use IOCTL_SCSI_GET_INQUIRY_DATA and IOCTL_SCSI_GET_CAPABILITIES to get inquiry and capabilities data.
这里说的plug and play drivers 是什么驱动?即插即用?和storage有关系,是指的usb设备的吗?
还有在IOCTL_SCSI_GET_INQUIRY_DATA 说明里面,提到:
This IOCTL is for use with older host bus adapters. In Windows Server 2003 and later operating systems, the storage stack will reject this IOCTL and return an error.
You are tossing an exception because you are walking off the end of your output buffer. You only made it big enough for a STORAGE_DEVICE_DESCRIPTOR, and did not allocate any room (other than the one byte that is contained in the variable length array at RawDeviceProperties ) for the inquiry data such as the serial number.
Typically 1024 is big enough for the output buffer.
