2839|0
ZwSetInformationFile问题 [复制链接]
NTSTATUS CoreyDDKDriverControl(IN PDEVICE_OBJECT pDevObj,
        IN PIRP pIrp)
        NTSTATUS ntStatus = STATUS_SUCCESS;
__try
        KdPrint(("[CoreyFileKiller]Enter HelloDDKDeviceIOControl\n"));
        //得到当前堆栈
        PIO_STACK_LOCATION stack = IoGetCurrentIrpStackLocation(pIrp);
        //得到输入缓冲区大小
        ULONG cbin = stack->Parameters.DeviceIoControl.InputBufferLength;
        //得到输出缓冲区大小
        ULONG cbout = stack->Parameters.DeviceIoControl.OutputBufferLength;
        //得到IOCTL码
        ULONG code = stack->Parameters.DeviceIoControl.IoControlCode;
        PDEVICE_EXTENSION pDevExt = (PDEVICE_EXTENSION)
                pDevObj->DeviceExtension;
        ULONG info = 0;
        DEVICE_RETN drRetn;
        switch(code)
                case IOCTL_BEGIN_KILL:
                                //得到输入数据
                                HANDLE hFile;
                                OBJECT_ATTRIBUTES objectAttributes;
                                PUNICODE_STRING pPath = (PUNICODE_STRING)pIrp->AssociatedIrp.SystemBuffer;
                                KdPrint(("[CoreyFileKiller]File:%ws %d %d",pPath->Buffer,pPath->Length,pPath->MaximumLength));
                                IO_STATUS_BLOCK ioStatus;
                                InitializeObjectAttributes(&objectAttributes,
        pPath,
        OBJ_CASE_INSENSITIVE,
        NULL,
        NULL);
                                ntStatus = ZwCreateFile(&hFile,
                                        GENERIC_READ|GENERIC_WRITE
                                        &objectAttributes,
                                        &ioStatus,
                                        NULL,
                                        FILE_ATTRIBUTE_NORMAL,
                                        0,
                                        FILE_OPEN,
                                        FILE_SYNCHRONOUS_IO_NONALERT,
                                        NULL,
                                        0);
                                if(NT_SUCCESS(ntStatus))
                                        KdPrint(("[CoreyFileKiller]Open file sucessfully.\n"));
                                }else
                                        KdPrint(("[CoreyFileKiller]Open file faily.%x\n",ioStatus.Information));
                                        pIrp->IoStatus.Status = ntStatus;
                                        pIrp->IoStatus.Information = info;        // bytes xfered
                                        IoCompleteRequest( pIrp, IO_NO_INCREMENT );
                                        return ntStatus;
                        FILE_BASIC_INFORMATION fbi;
                        FILE_STANDARD_INFORMATION fsi;
                        ntStatus = ZwQueryInformationFile(hFile,
        &ioStatus,
        &fbi,
        sizeof(fbi),
        FileBasicInformation
                                        KdPrint(("[CoreyFileKiller]Read file basic sucessfully.\n"));
                                }else
                                        KdPrint(("[CoreyFileKiller]Read file basic faily.\n"));
                                        return ntStatus;
        &ioStatus,
        &fsi,
        sizeof(FILE_STANDARD_INFORMATION),
        FileStandardInformation
                                        KdPrint(("[CoreyFileKiller]Read file attribute sucessfully.%d\n",fsi.DeletePending));
                                else
                                        KdPrint(("[CoreyFileKiller]Read file attribute faily.\n"));
                                        return ntStatus;
                        fsi.DeletePending = TRUE;
                        ntStatus = ZwSetInformationFile(hFile,
        &ioStatus,
        &fsi,
                                        KdPrint(("[CoreyFileKiller]Set file attribute sucessfully.\n"));
                                        drRetn.IsSucessed = 1;
                                else
                                        KdPrint(("[CoreyFileKiller]Set file attribute faily.%x\n",ioStatus.Information));
                                        drRetn.IsSucessed = 0;
                        drRetn.ChangeTime          =        fbi.ChangeTime;
                        drRetn.CreationTime          =        fbi.CreationTime;
                        drRetn.FileAttributes = fbi.FileAttributes;
                        drRetn.LastAccessTime = fbi.LastAccessTime;
                        drRetn.LastWriteTime  =        fbi.LastWriteTime;
                        info = sizeof(drRetn);
                        ZwClose(hFile);
        memcpy(pIrp->AssociatedIrp.SystemBuffer,&drRetn,sizeof(drRetn));
        // 完成IRP
                __except(EXCEPTION_EXECUTE_HANDLER)
                        KdPrint(("[CoreyFileKiller]Catch a BSOD\n"));
                        return ntStatus;
        return ntStatus;
ZwSetInformation函数总是调用不成功,调用后ioStatus的Information是18。请问是什么问题啊?大家帮帮我啊。
福禄克有奖直播:高精度测温赋能电子制造 报名中!
直播时间:2025年2月28日(周五)上午10:00
直播主题:高精度测温赋能电子制造
小伙伴们儿快来报名直播吧~好礼等你拿!
