在timer4的中断服务程序中调用的哈
OSTimeTick的程序如下
void OSTimeTick (void)
OS_TCB *ptcb;
#if OS_TICK_STEP_EN > 0
BOOLEAN step;
#endif
#if OS_CRITICAL_METHOD == 3 /* Allocate storage for CPU status register */
OS_CPU_SR cpu_sr;
cpu_sr = 0; /* Prevent compiler warning */
#endif
#if OS_TIME_TICK_HOOK_EN > 0
OSTimeTickHook(); /* Call user definable hook */
#endif
#if OS_TIME_GET_SET_EN > 0
OS_ENTER_CRITICAL(); /* Update the 32-bit tick counter */
OSTime++;
OS_EXIT_CRITICAL();
#endif
if (OSRunning == TRUE) {
switch (OSTickStepState) { /* Determine whether we need to process a tick */
case OS_TICK_STEP_DIS: /* Yes, stepping is disabled */
step = TRUE;
break;
case OS_TICK_STEP_WAIT: /* No, waiting for uC/OS-View to set ... */
step = FALSE; /* .. OSTickStepState to OS_TICK_STEP_ONCE */
break;
case OS_TICK_STEP_ONCE: /* Yes, process tick once and wait for next ... */
step = TRUE; /* ... step command from uC/OS-View */
OSTickStepState = OS_TICK_STEP_WAIT;
break;
default: /* Invalid case, correct situation */
step = TRUE;
OSTickStepState = OS_TICK_STEP_DIS;
break;
if (step == FALSE) { /* Return if waiting for step command */
return;
#endif
ptcb = OSTCBList; /* Point at first TCB in TCB list */
while (ptcb->OSTCBPrio != OS_IDLE_PRIO) { /* Go through all TCBs in TCB list */
if (ptcb->OSTCBDly != 0) { //?÷??..........................
Uart_Printf("\ntick\n"); /* No, Delayed or waiting for event with TO */
if (--ptcb->OSTCBDly == 0) { /* Decrement nbr of ticks to end of delay */
/* Check for timeout */
if ((ptcb->OSTCBStat & OS_STAT_SUSPEND) == OS_STAT_RDY) { /* Is task suspended? */
OSRdyGrp |= ptcb->OSTCBBitY; /* No, Make ready */
OSRdyTbl[ptcb->OSTCBY] |= ptcb->OSTCBBitX;
ptcb = ptcb->OSTCBNext; /* Point at next TCB in TCB list */
OS_EXIT_CRITICAL();
