3535|5
87
NBOOT\和KERNEL\HAL\ARM\下的map.a的内容基本相同,但有些不同? [复制链接]
他们两者的区别和功效是不是有说分工?
此帖出自ARM技术论坛
请大家关注下面这篇帖子,是个给初级wince/ARM 硬件驱动者的一些基础知识的总结帖子: 关于的OEMAddressTable/g_oalAddressTable和config.bib的全解析--一堆弱弱的问题,送分咯!   http://topic.eeworld.net/u/20081206/14/e68e40e1-6631-40b9-885d-7ba28145a6ea.html?seed=132181214  详情 回复 发表于 2008-12-6 14:20
83
我觉得nboot下的那个是没有用的,因为那时候根本没有必要用。
此帖出自ARM技术论坛
  1. ; Mapped for S3C2400X01
  2.     EXPORT      OEMAddressTable[DATA]
  3. OEMAddressTable
  4.     ;;;-------------------------------------------------------------
  5.     ;;; Virt Addr   Phys Addr   MB
  6.     ;;;-------------------------------------------------------------
  7.     DCD 0x80000000, 0x02000000, 30  ; 30 MB SRAM(SRAM/ROM) BANK 0
  8.     DCD 0x82000000, 0x08000000, 32  ; 32 MB SROM(SRAM/ROM) BANK 1
  9.     DCD 0x84000000, 0x10000000, 32  ; 32 MB SROM(SRAM/ROM) BANK 2
  10.     DCD 0x86000000, 0x18000000, 32  ; 32 MB SROM(SRAM/ROM) BANK 3
  11.     DCD 0x88000000, 0x20000000, 32  ; 32 MB SROM(SRAM/ROM) BANK 4
  12.     DCD 0x8A000000, 0x28000000, 32  ; 32 MB SROM(SRAM/ROM) BANK 5
  13.     DCD 0x8C000000, 0x30000000, 64  ; 64 MB DRAM BANK 0, 1
  14.     DCD 0x90800000, 0x48000000,  1  ; Memory control register
  15.     DCD 0x90900000, 0x49000000,  1  ; USB Host register
  16.     DCD 0x90A00000, 0x4A000000,  1  ; Interrupt Control register
  17.     DCD 0x90B00000, 0x4B000000,  1  ; DMA control register
  18.     DCD 0x90C00000, 0x4C000000,  1  ; Clock & Power register
  19.     DCD 0x90D00000, 0x4D000000,  1  ; LCD control register
  20.     DCD 0x90E00000, 0x4E000000,  1  ; NAND flash control register
  21.     DCD 0x90F00000, 0x4F000000,  1  ; Camera control register
  22.     DCD 0x91000000, 0x50000000,  1  ; UART control register
  23.     DCD 0x91100000, 0x51000000,  1  ; PWM timer register
  24.     DCD 0x91200000, 0x52000000,  1  ; USB device register
  25.     DCD 0x91300000, 0x53000000,  1  ; Watchdog Timer register
  26.     DCD 0x91400000, 0x54000000,  1  ; IIC control register
  27.     DCD 0x91500000, 0x55000000,  1  ; IIS control register
  28.     DCD 0x91600000, 0x56000000,  1  ; I/O Port register
  29.     DCD 0x91700000, 0x57000000,  1  ; RTC control register
  30.     DCD 0x91800000, 0x58000000,  1  ; A/D convert register
  31.     DCD 0x91900000, 0x59000000,  1  ; SPI register
  32.     DCD 0x91A00000, 0x5A000000,  1  ; SD Interface register
  33.     DCD 0x91B00000, 0x5B000000,  1  ; AC97 Interface register
  34.     DCD 0x92000000, 0x00000000, 32  ; 32 MB SROM(SRAM/ROM) BANK 0
  35.     DCD 0x00000000, 0x00000000,  0  ; End of Table (MB MUST BE ZERO!)
  36.     END
复制代码
那这里这么分析呢?
此帖出自ARM技术论坛
84
这个网上到处有,再回答就没有意思了
此帖出自ARM技术论坛
77
对OEMAddressTable以及2440一些硬件连接的疑惑
http://topic.eeworld.net/u/20080919/15/916c5af8-2bc9-400c-9190-c29b2965e529.html
----gooogleman的大作。学习中...
这里也看到了这么多人无私的帮助过ni...
此帖出自ARM技术论坛
66
此帖出自ARM技术论坛
