用DDKXPSP1+DS3.1+VC6自动生成USB BULK驱动,2个EP一个IN 一个OUT,用WRITEFILE READFILE读写操作,驱动的READ部分程序如下:
NTSTATUS Usb4Device::Read(KIrp I)
t << "Entering Usb4Device::Read, " << I << EOL;
// TODO: Check the incoming request. Replace "FALSE" in the following
// line with a check that returns TRUE if the request is not valid.
if (FALSE) // If (Request is invalid)
// Invalid parameter in the Read request
I.Information() = 0;
return I.PnpComplete(this, STATUS_INVALID_PARAMETER);
// Always ok to read 0 elements.
if (I.ReadSize() == 0)
return I.PnpComplete(this, STATUS_SUCCESS);
// If the total requested read size is greater than the Maximum Transfer
// Size for the Pipe, request to read only the Maximum Transfer Size since
// the bus driver will fail an URB with a TransferBufferLength of greater
// than the Maximum Transfer Size.
if (dwTotalSize > dwMaxSize)
ASSERT(dwMaxSize);
dwTotalSize = dwMaxSize;
// Allocate a new context structure for Irp completion
USB_COMPLETION_INFO* pCompInfo = new (NonPagedPool) USB_COMPLETION_INFO;
if (pCompInfo == NULL)
return I.PnpComplete(this, STATUS_INSUFFICIENT_RESOURCES);
// TODO: Select the correct pipe to read from
// Create an URB to do actual Bulk read from the pipe
PURB pUrb = m_Endpoint1IN.BuildBulkTransfer(
Mem, // Where is data coming from?
dwTotalSize, // How much data to read?
TRUE, // direction (TRUE = IN)
NULL, // Link to next URB
TRUE // Allow a short transfer
