2626|1
54
java 调用DLL 读串口,不久就死了,请帮忙看看什么原因? [复制链接]
经过仔细分析问题出这dll这里,但始终找不到解决办法,请大家帮忙看看,谢谢!
dll代码如下:
JNIEXPORT jstring JNICALL Java_getGPS
(JNIEnv * env, jobject obj)
    char * cIpAddress =compressWideChar((LPCWSTR)L"empty value!");
  int baud     = 9600;//BaudTbl[1];
int parity   = 0;//ParityTbl[1];
int databit  = 8;//DataBitTbl[1];
int stopbit  = 0;//StopBitTbl[1];
    //打开串口
if(m_hComm==INVALID_HANDLE_VALUE)
  m_hComm=CreateFile(TEXT("COM3:"),GENERIC_READ|GENERIC_WRITE,0,0,OPEN_EXISTING,0,0);
  if(m_hComm==INVALID_HANDLE_VALUE )
      cIpAddress =compressWideChar((LPCWSTR)L"COM3 open error!");
      ClosePort();
   return WindowsTojstring(env, cIpAddress);
  GetCommState(m_hComm,&dcb);
  dcb.BaudRate=baud;//BaudRate;
  dcb.ByteSize=databit;//DataBits;
  dcb.Parity=parity;//Parity;
  dcb.StopBits=stopbit;//StopBits;
  dcb.fParity=FALSE;
  dcb.fBinary=TRUE;
  dcb.fDtrControl=0;
  dcb.fRtsControl=0;
  dcb.fOutX=dcb.fInX=dcb.fTXContinueOnXoff=0;
  //设置状态参数
  SetCommMask(m_hComm,EV_RXCHAR);
  SetupComm(m_hComm,16384,16384); //old
  //SetupComm(m_hComm,4096,4096); //new my add
  if(!SetCommState(m_hComm,&dcb))
   //AfxMessageBox(_T("无法按当前参数配置端口,请检查参数!"));
   cIpAddress =compressWideChar((LPCWSTR)L"setup com3 error!");
   PurgeComm(m_hComm,PURGE_TXCLEAR|PURGE_RXCLEAR);
   ClosePort();
  // bOpen = FALSE;
  //设置超时参数
  GetCommTimeouts(m_hComm,&CommTimeOuts);
  CommTimeOuts.ReadIntervalTimeout=100;//old
   CommTimeOuts.ReadTotalTimeoutMultiplier=1;//old
   CommTimeOuts.ReadTotalTimeoutConstant=100;//old
  CommTimeOuts.WriteTotalTimeoutMultiplier=0;
  CommTimeOuts.WriteTotalTimeoutConstant=0;
  if(!SetCommTimeouts(m_hComm,&CommTimeOuts))
   cIpAddress =compressWideChar((LPCWSTR)L"setup Timeout error!");
   ClosePort();
//读数据
//下边的代码转化中有出问题
while(m_hComm!=INVALID_HANDLE_VALUE)
  BOOL fReadState;
  DWORD dwLength;//,dwBytesRead;
  char* buf=new char[256];//256
     int length=256;//256
   fReadState=ReadFile(m_hComm,buf,length,&dwLength,NULL);//从串口读数
   if(fReadState)
       cIpAddress = NULL;
       cIpAddress = buf;
     jstring str = WindowsTojstring(env, cIpAddress);//我估计问题出在这里 WindowsTojstring()是用于UNICODE转ANSI    delete []buf;
    delete buf;
    delete cIpAddress;
   // ClosePort();
    return str;
   else
    delete []buf;
    delete buf;
    delete cIpAddress;
   // ClosePort();
    return str;
ClosePort();
//UNICODE转ANSI
jstring WindowsTojstring( JNIEnv* env, char* str )
jstring rtn = 0;
int slen = strlen(str);
wchar_t* buffer = 0;
if( slen == 0 )
  rtn = env->NewStringUTF( str ); //UTF ok since empty string
else
  int length = MultiByteToWideChar( CP_ACP, 0, (LPCSTR)str, slen, NULL, 0 );//old
  buffer = (wchar_t*)malloc( length*2 + 1 );//old
  if( MultiByteToWideChar( CP_ACP, 0, (LPCSTR)str, slen, (LPWSTR)buffer, length ) >0 )
   rtn = env->NewString( (jchar*)buffer, length );
if( buffer )
  free( buffer );
        delete buffer;
return rtn;
本文来自Tony嵌入式论坛,原文地址:http://www.cevx.com/bbs/viewthread.php?tid=20228
没人回答!  详情 回复 发表于 2009-6-2 14:20
78
没人回答!
