mrc p15, 0, r2, c1, c0, 0 ; load r2 with MMU Control
ldr r0, =MMU_CTL_MASK ; mask off the undefined bits
bic r2, r2, r0
str r2, [r3], #4 ; store MMU Control data
mrc p15, 0, r2, c2, c0, 0 ; load r2 with TTB address.
ldr r0, =MMU_TTB_MASK ; mask off the undefined bits
bic r2, r2, r0
str r2, [r3], #4 ; store TTB address
mrc p15, 0, r2, c3, c0, 0 ; load r2 with domain access control.
str r2, [r3], #4 ; store domain access control
str sp, [r3], #4 ; store SVC stack pointer
mrs r2, spsr
str r2, [r3], #4 ; store SVC status register
mov r1, #Mode_FIQ:OR:I_Bit:OR:F_Bit ; Enter FIQ mode, no interrupts
msr cpsr, r1
mrs r2, spsr
stmia r3!, {r2, r8-r12, sp, lr} ; store the FIQ mode registers
mov r1, #Mode_ABT:OR:I_Bit:OR:F_Bit ; Enter ABT mode, no interrupts
msr cpsr, r1
mrs r0, spsr
stmia r3!, {r0, sp, lr} ; store the ABT mode Registers
mov r1, #Mode_IRQ:OR:I_Bit:OR:F_Bit ; Enter IRQ mode, no interrupts
msr cpsr, r1
mrs r0, spsr
stmia r3!, {r0, sp, lr} ; store the IRQ Mode Registers
mov r1, #Mode_UND:OR:I_Bit:OR:F_Bit ; Enter UND mode, no interrupts
msr cpsr, r1
mrs r0, spsr
stmia r3!, {r0, sp, lr} ; store the UND mode Registers
mov r1, #Mode_SYS:OR:I_Bit:OR:F_Bit ; Enter SYS mode, no interrupts
msr cpsr, r1
stmia r3!, {sp, lr} ; store the SYS mode Registers
mov r1, #Mode_SVC:OR:I_Bit:OR:F_Bit ; Back to SVC mode, no interrupts
msr cpsr, r1
; 3. do Checksum on the Sleepdata
ldr r3, =SLEEPDATA_BASE_VIRTUAL ; get pointer to SLEEPDATA
ldr r2, =0x0
ldr r0, =(SLEEPDATA_SIZE-1) ; get size of data structure (in words)
ldr r1, [r3], #4
and r1, r1, #0x1
mov r1, r1, ROR #31
add r2, r2, r1
subs r0, r0, #1
bne %b30
ldr r0, =vGPIOBASE
;;;add r2, r2, #1 ; test checksum of the Sleep data error
str r2, [r0, #oGSTATUS3] ; Store in Power Manager Scratch pad register
ldr r2, =vMISCCR
ldr r3, [r2]
orr r3, r3, #(3<<17) ; Make sure that SCLK0:SCLK->0, SCLK1:SCLK->0, SCKE=L during boot-up
bic r3, r3, #(7<<20)
orr r3, r3, #(6<<20)
ldr r4, =vCLKCON
ldr r5, =0x1ffff8 ; Power Off Mode
; Sometimes it is not working in cache mode. So I modify to jump to ROM area.
;;; ldr r6, =0x92000000 ; make address to 0x9200 0020
;;; add r6, r6, #0x20 ;
;;; mov pc, r6 ; jump to Power off code in ROM
b SelfRefreshAndPowerOff
ALIGN 32 ; for I-Cache Line(32Byte, 8 Word)
SelfRefreshAndPowerOff ; run with Instruction Cache's code
str r1, [r0] ; Enable SDRAM self-refresh
str r3, [r2] ; MISCCR Setting
str r5, [r4] ; Power Off !!
b .
;;; LTORG
; This point is called from EBOOT's startup code(MMU is enabled)
; in this routine, left information(REGs, INTMSK, INTSUBMSK ...)
0001:00036058 DPA_Sort 10037058 f coredll_ALL:dynarray.obj
0001:00036098 DSA_Sort 10037098 f coredll_ALL:dynarray.obj
0001:000360e8 xxx_GetSystemPowerState 100370e8 f coredll_ALL:tpm.obj
0001:00036138 xxx_SetSystemPowerState 10037138 f coredll_ALL:tpm.obj
0001:000361e8 xxx_SetPowerRequirement 100371e8 f coredll_ALL:tpm.obj
0001:00036258 xxx_ReleasePowerRequirement 10037258 f coredll_ALL:tpm.obj
0001:00036298 xxx_RequestPowerNotifications 10037298 f coredll_ALL:tpm.obj
0001:000362ec xxx_StopPowerNotifications 100372ec f coredll_ALL:tpm.obj
