2756|3
61
I.MX27片内存贮器是什么样子的? [复制链接]
I.MX27的片内存贮器是什么形式的?有多少?(刚从51转过来,拿着技术手册看了半天也没找到)
支持32位的SDRAM和DDR SDRAM  详情 回复 发表于 2009-3-10 18:48
63
支持32位的SDRAM和DDR SDRAM,比较强悍
47
The ARM926EJ-S core includes a 16-Kbyte level 1 (L1) cache system,
a 6 × 3 multi-layer AHB crossbar switch, and a 16 channel DMA
ARM926EJ-S microprocessor core
— 16K instruction cache and 16K data cache
— High-performance ARM? 32-bit RISC engine
— Thumb? 16-bit compressed instruction set for a leading level of code density
84
