3727|7
程序列表 [复制链接]
  最近想做一个程序列表,就是显示当前正在运行的所有应用程序列表(不是进程),但不知道怎么获取,有没有直接获取的?进程我知道怎么获取。
  谢谢大家提供信息。
#include #include #include BOOL GetProcessList () {     HANDLE         hProcessSnap = NULL;     BOOL           bRet      = FALSE;     PROCESSENTRY32 pe32      = {0};     //  Take a snapshot of all processes in the system.     hProcessSnap = CreateToolhelp32Snapshot(TH32CS_SNAPPROCESS, 0);     if (hProcessSnap == (HANDLE)-1)         return (FALSE);     //  Fill in the size of the structure before using it.     pe32.dwSize = sizeof(PROCESSENTRY32);     //  Walk the snapshot of the processes, and for each process,     //  display information.     if (Process32First(hProcessSnap, &pe32))     {         DWORD         dwPriorityClass;         BOOL          bGotModule = FALSE;         MODULEENTRY32 me32       = {0};         do         {             bGotModule = GetProcessModule(pe32.th32ProcessID,                 pe32.th32ModuleID, &me32, sizeof(MODULEENTRY32));             if (bGotModule)             {                 HANDLE hProcess;                 // Get the actual priority class.                 hProcess = OpenProcess (PROCESS_ALL_ACCESS,                     FALSE, pe32.th32ProcessID);                 dwPriorityClass = GetPriorityClass (hProcess);                 CloseHandle (hProcess);                 // Print the process's information.                 printf( "\nPriority Class Base\t%d\n",                     pe32.pcPriClassBase);                 printf( "PID\t\t\t%d\n", pe32.th32ProcessID);                 printf( "Thread Count\t\t%d\n", pe32.cntThreads);                 printf( "Module Name\t\t%s\n", me32.szModule);                 printf( "Full Path\t\t%s\n\n", me32.szExePath);             }         }         while (Process32Next(hProcessSnap, &pe32));         bRet = TRUE;     }     else         bRet = FALSE;    // could not walk the list of processes     // Do not forget to clean up the snapshot object.     CloseHandle (hProcessSnap);     return (bRet); }   详情 回复 发表于 2009-4-9 18:36
79
进程包括了程序。
去除系统默认的,去除非exe结尾的,剩下的就是应用程序了。
63
程序无非就是 应用程序和系统程序, 去掉系统程序就是应用程序了.
52
可以参考这个吧:
BOOL CTaskBar::CloseAllWindows(HWND hwndTB)
    LPTBOBJ ptbobj, lptbStart, lptbTray;
    lptbStart = GetItem(hwndTB, (int)HHTB_START);
    lptbTray  = GetItem(hwndTB, (int)HHTB_FIRSTNOTIFY);
    // First, find the currently checked one.
    ptbobj = (LPTBOBJ)m_plistTaskBar->Next(&lptbStart->lpObj);
    while (ptbobj && ptbobj != lptbTray)
        if (IsWindow(ptbobj->ptbi->m_hwndMain))
            SendMessage(ptbobj->ptbi->m_hwndMain, WM_CLOSE, 0, 0);
        ptbobj = (LPTBOBJ)m_plistTaskBar->Next(&ptbobj->lpObj);
    return TRUE;
} /* HHTaskBar_CloseAllWindows()
我用了一下一点代码:
HANDLE g_hProHandle = NULL;
g_hProHandle = CreateToolhelp32Snapshot(TH32CS_SNAPALL,0);
这个API的返回值即hProHandle  == INVALID_HANDLE_VALUE ;
返回的句柄值总是不正确,用这个API有需要注意的没有?
有谁知道的,谢了。
引用 4 楼 xing840817 的回复:
我用了一下一点代码:
这个API的返回值即hProHandle? == INVALID_HANDLE_VALUE ;
有谁知道的,谢了。
定制时要增加Toolhelp组件吧
67
但进程是得到了。
我需要显示和进程相对应的应用程序名称在界面中,怎样能根据进程取得应用程序名称?
85
#include
#include
#include
    BOOL           bRet      = FALSE;
        return (FALSE);
        do
            if (bGotModule)
                HANDLE hProcess;
        bRet = TRUE;
    else
    return (bRet);
