2372|0
83
贴一段代码出来,对上面的6,7,12,28...等数字不理解,请大家帮忙解释下.谢谢
int IssueCommand_CH0( U16 uCmd, U32 uArg, U32 uIsAcmd)
        U32 uSfr;
        while ((rHM0_PRNSTS&0x1)); // Check CommandInhibit_CMD
        if (!uIsAcmd)//R1b type commands have to check CommandInhibit_DAT bit
                if((uCmd==6&&ThisIsMmc_ch0)||uCmd==7||uCmd==12||uCmd==28||uCmd==29||uCmd==38||((uCmd==42||uCmd==56)&&(!ThisIsMmc_ch0)))
                        do        {
                                uSfr = rHM0_PRNSTS;
                        } while((uSfr&0x2)); // Check CommandInhibit_DAT
        // Argument Setting
        if (!uIsAcmd)// <------------------- Normal Command (CMD)
                if(uCmd==3||uCmd==4||uCmd==7||uCmd==9||uCmd==10||uCmd==13||uCmd==15||uCmd==55)
                        rHM0_ARGUMENT = uArg<<16;
                else
                        rHM0_ARGUMENT = uArg;
        else// <--------------------------- APP.Commnad (ACMD)
        SetCommandReg_CH0(uCmd,uIsAcmd);
        if (!WaitForCommandComplete_CH0())
                        printf(("Command NOT Complete\n"));
        else
                ClearCommandCompleteStatus_CH0();
        if (!(rHM0_NORINTSTS&0x8000))
                if(((rHM0_CMDREG>>8) == 0x8) &&(ThisIsMmc_ch0 !=1))
                        printf("\nCMD8 Support");
                        SDSpecVer_ch0 = 2;
                return 1;
        else
                if(OCRcheck_ch0 == 1)
                        return 0;
                else
                        printf("Command = %d, Error Stat = %x\n",(rHM0_CMDREG>>8),rHM0_ERRINTSTS);
                        rHM0_ERRINTSTS = rHM0_ERRINTSTS;
                        rHM0_NORINTSTS =rHM0_NORINTSTS;
                        if((rHM0_CMDREG>>8) == 0x8)
                                printf("\nThis Card version is NOT SD 2.0\n");
                        return 0;
