2937|0
67
jedec_probe探测SST39vf3201的疑问 [复制链接]
CPU:NXP LPC2478
Flash:NOR SST39VF3201:4MB,4k扇区,地址:0x81000000
想在4M的NOR flash上作jffs2根文件系统,自己写了MTD驱动:
#define FLASH_BASE_ADDR                0x81000000
#define FLASH_SIZE                0x400000
#define BUS_WIDTH                2
static struct map_info lpc24xx_map[1] = {
        .name =                "lpc24xx",
        .bankwidth =        BUS_WIDTH,//16bit
        .size =                FLASH_SIZE,//4MB
        .phys =                FLASH_BASE_ADDR,
//分区信息
static struct mtd_partition lpc24xx_partitions[] = {
                .name = "Kernel",
                .size = 0x002A0000,// 2.5M
                .offset = 0,
                .mask_flags = MTD_WRITEABLE,
                .name = "jffs2",
                .size = MTDPART_SIZ_FULL,
                .offset = MTDPART_OFS_APPEND,
将SST39vf3201加入table
#define SST39VF3201        0x235b// add sst39vf3201加入ID信息
               .mfr_id         = MANUFACTURER_SST,     /* should be CFI */
               .dev_id         = SST39VF3201,
               .name           = "SST 39VF3201",
               .uaddr          = {
                       //[0] = MTD_UADDR_0x5555_0x2AAA,  /* x8 */
                       [1] = MTD_UADDR_0x5555_0x2AAA   /* x16 */
               .DevSize        = SIZE_4MiB,
               .CmdSet         = P_ID_AMD_STD,
               .NumEraseRegions= 2,
               .regions        = {
                       ERASEINFO(0x1000,1024),
在使用mymtd = do_map_probe("jedec_probe", &lpc24xx_map);探测flash时,
终端打印以下信息:
Search for id:(58 9f) interleave(2) type(1) //这个interleave应该是1吧,不知道在哪改jedec_match(): ID is not 8bit
reset unlock called 555 aaa
reset unlock called 5555 2aaa
Search for id:(bf 5b) interleave(2) type(1)
MTD jedec_match(): Check fit 0x00000000 + 0x00100000 = 0x00100000
MTD jedec_match(): check unlock addrs 0x5555 0x2aaa
MTD jedec_match(): check ID's disappear when not in ID mode
MTD jedec_match(): return to ID mode
MTD jedec_probe_chip(): matched device 0xbf,0x5b unlock_addrs: 0x5555 0x2aaa
Found: SST 49LF080A //探测出差,应该是39VF3201
lpc24xx: Found 2 x8 devices at 0x0 in 16-bit bank//应该是1片16位 ,怎么搞成2x8 了啊
Chow->devtpt222=1
Chow->bankwith=2
number of JEDEC chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Chow->ret=-1580371808
Chow->owner: THIS_MODULE
Chow->CONFIG_MTD_PARTITIONS
cmdlinepart partition parsing not available
Chow->mtd_parts[0]: offset=0 size=0x2a0000
Using builtin partition table
Creating 2 MTD partitions on "lpc24xx":
0x00000000-0x002a0000 : "Kernel"// 这里不太明白,应该是0x81000000还是0x00
mtd: partition "Kernel" extends beyond the end of device "lpc24xx" -- size truncated to 0x200000
mtd: Giving out device 0 to Kernel
0x002a0000-0x00200000 : "jffs2"//这里为什么不是剩下所有,应该到0x00400000
mtd: partition "jffs2" is out of reach -- disabled
mtd: Giving out device 1 to jffs2
block2mtd: version $Revision: 1.30 $
TCP cubic registered
NET: Registered protocol family 1
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
MTDSB: dev_name "/dev/root"
MTDSB: path_lookup() returned 0, inode a1800284
List of all partitions:
1f00       2048 mtdblock0 (driver?)
No filesystem could mount root, tried:  jffs2
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
一片16位flash怎么探测出2x8的出来了啊,是哪里初始化有问题??
thanks a lot
