3974|3
看看有没有高手指点 ezusb->cyusb [复制链接]
bool ReadData(int count,unsigned char *buf)
    bool                                    Success ;
    BULK_TRANSFER_CONTROL                   BR;
    VENDOR_OR_CLASS_REQUEST_CONTROL         VR;
    unsigned long                           nBytes;
        int                        bc,bout;
        unsigned char* inbuf=buf;
    if (hUsbDevice != INVALID_HANDLE_VALUE )
      VR.direction = 0;   // (0=host to device, 1=device to host)
      VR.requestType = 2;
      VR.recepient = 0;
      VR.request = VX_GPIFREAD;
      VR.requestTypeReservedBits = 0;
      VR.value = *((unsigned short*)(&count));
      VR.index = *(((unsigned short*)(&count))+1);        //SETUPDAT[5:4]
       Success = DeviceIoControl (hUsbDevice,
                    IOCTL_EZUSB_VENDOR_OR_CLASS_REQUEST,
                    &VR,
                    sizeof(VENDOR_OR_CLASS_REQUEST_CONTROL),
                    NULL,
                    0,
                    &nBytes,
                    NULL);
      BR.pipeNum = 1;
                bout=count*2;
                while (bout){
                        if(bout>0x8000)bc=0x8000;
                        else bc=bout;
                                         IOCTL_EZUSB_BULK_READ,
                                         &BR,
                                         sizeof(BULK_TRANSFER_CONTROL),
                                         inbuf,
                                                bc,
                                         &nBytes,
                                         NULL);
                          if(bc>nBytes)bc=nBytes;
                          bout-=bc;
                          inbuf+=bc;
    return Success;
上边是以前的程序,由于要用cyusb,我把它改成了下边的样子:
        bool    Success ;
        //BULK_TRANSFER_CONTROL                   BR;
        //VENDOR_OR_CLASS_REQUEST_CONTROL         VR;
        long bc;
        int bout;
//      PUCHAR outbuf = new UCHAR[count];
//      ZeroMemory(outbuf,count);
        //PUCHAR inbuf = new UCHAR[count];
        //ZeroMemory(inbuf,count);
        //inbuf = buf;
        OVERLAPPED inOvLap;//,outOvLap;
        //outOvLap.hEvent = CreateEvent(NULL,false,false,"CYUSB_OUT");
        inOvLap.hEvent = CreateEvent(NULL,false,false,"CYUSB_IN");
//                VR.direction = 0;   // (0=host to device, 1=device to host)
//                VR.requestType = 2;
//                VR.recepient = 0;
//                VR.request = VX_GPIFREAD;
//                VR.requestTypeReservedBits = 0;
//                VR.value = *((unsigned short*)(&count));
                                        &VR,
                                        NULL,
                                        0,
                                        &nBytes,
                                        NULL);
//                BR.pipeNum = 1;
                ept->Direction = DIR_TO_DEVICE;
                ept->ReqType = REQ_VENDOR;
                    ept->Target = TGT_DEVICE;
                ept->ReqCode = VX_GPIFREAD;
                ept->Value = *((unsigned short*)(&count));
                ept->Index = *(((unsigned short*)(&count))+1); //SETUPDAT[5:4]
                //PUCHAR readbuf = new char[2];
                //Success = ept->Read(readbuf,2);
                Success = ept->Write(NULL,0);
                ept->Address = 0x01;
                bout=count*2;
                while (bout)
                        if(bout>0x8000) bc=0x8000;
                        else bc=bout;
                                        &BR,
                                        inbuf,
                                        bc,
                                        &nBytes,
                                        NULL);
                  UCHAR *inContext = USBDevice->BulkInEndPt->BeginDataXfer(inbuf,bc,&inOvLap);
                  //UCHAR *outContext = USBDevice->BulkOutEndPt->BeginDataXfer(outbuf,bc,&outOvLap);
                  //USBDevice->BulkOutEndPt->WaitForXfer(&outOvLap,100);
                  USBDevice->BulkInEndPt->WaitForXfer(&inOvLap,100);
                  //Success = USBDevice->BulkOutEndPt->FinishDataXfer(outbuf,bc,&outOvLap,outContext);
                  Success = USBDevice->BulkInEndPt->FinishDataXfer(inbuf,bc,&inOvLap,inContext);
                  //if(bc>nBytes)bc=nBytes;
                  bout-=bc;
                  inbuf+=bc;
                //CloseHandle(outOvLap.hEvent);
                CloseHandle(inOvLap.hEvent);
        return Success;
可就是卡死在这里,请指教。
这从usb设备中读不到数据,老返回false,是为什么呢?  详情 回复 发表于 2010-1-26 10:06
帮顶下。
64
仍在研究中。。。
