2860|2
64
在CE中创建动态菜单有点问题,想问一下 [复制链接]
LRESULT DoCreateMain(HWND hWnd, UINT wMsg, WPARAM wParam, LPARAM lParam)
        HWND hwndCB;
        hwndCB = CommandBar_Create(g_hInst, hWnd, IDC_CMDBAR);
        CommandBar_AddAdornments(hwndCB, 0, 0);
        HMENU hMainMenu, hMenu;
        hMainMenu = CreateMenu();
        hMenu = CreateMenu();
        AppendMenu(hMenu, MF_STRING|MF_ENABLED, 100, TEXT("&New"));
        AppendMenu(hMenu, MF_STRING|MF_ENABLED, 101, TEXT("&Open"));
        AppendMenu(hMenu, MF_STRING|MF_ENABLED, 102, TEXT("&Save"));
        AppendMenu(hMenu, MF_STRING|MF_ENABLED, 103, TEXT("E&xit"));
        AppendMenu(hMainMenu, MF_STRING|MF_ENABLED|MF_POPUP, (UINT)hMenu, TEXT("&File"));
        CommandBar_InsertMenubarEx(hwndCB, NULL, hMainMenu, 0);
        //error C2664: 'CommandBar_InsertMenubarEx' : cannot convert parameter 3 from 'HMENU' to 'LPTSTR',不能是菜单句柄吗?
        return 0;
学习一下 LRESULT   DoCreateMain(HWND   hWnd,   UINT   wMsg,   WPARAM   wParam,   LPARAM   lParam) { HWND   hwndCB; hwndCB   =   CommandBar_Create(g_hInst,   hWnd,   IDC_CMDBAR); HMENU   hMainMenu,   hMenu; hMainMenu   =   CreateMenu(); hMenu   =   CreateMenu(); AppendMenu(hMenu,   MF_STRING ?MF_ENABLED,   100,   TEXT("&New")); AppendMenu(hMenu,   MF_STRING ?MF_ENABLED,   101,   TEXT("&Open")); AppendMenu(hMenu,   MF_STRING ?MF_ENABLED,   102,   TEXT("&Save")); AppendMenu(hMenu,   MF_STRING ?MF_ENABLED,   103,   TEXT("E&xit")); AppendMenu(hMainMenu,   MF_STRING ?MF_ENABLED ?MF_POPUP,   (UINT)hMenu,   TEXT("&File")); CommandBar_InsertMenubarEx(hwndCB,   NULL,   hMainMenu,   0);   CommandBar_AddAdornments(hwndCB,   0,   0);                  return   0; }  详情 回复 发表于 2008-2-19 10:41
91
CommandBar_InsertMenubarEx(hwndCB, NULL, (LPTSTR)hMainMenu, 0);
改成这也没有效果。看不到菜单
83
学习一下
HWND   hwndCB;
return   0;
