你是在基于对话框的上面添加的菜单吧?
对话框没有ON_WM_INITMENUPOPUP()这个消息,所以你要添加这个消息才能处理。
函数体:
void CTestDlg::OnInitMenuPopup(CMenu *pPopupMenu, UINT nIndex,BOOL bSysMenu)
ASSERT(pPopupMenu != NULL);
// Check the enabled state of various menu items.
// Determine if menu is popup in top-level menu and set m_pOther to
// it if so (m_pParentMenu == NULL indicates that it is secondary popup).
HMENU hParentMenu;
if (AfxGetThreadState()->m_hTrackingMenu == pPopupMenu->m_hMenu)
state.m_pParentMenu = pPopupMenu; // Parent == child for tracking popup.
else if ((hParentMenu = ::GetMenu(m_hWnd)) != NULL)
CWnd* pParent = this;
// Child windows don't have menus--need to go to the top!
if (pParent != NULL &&
(hParentMenu = ::GetMenu(pParent->m_hWnd)) != NULL)
int nIndexMax = ::GetMenuItemCount(hParentMenu);
for (int nIndex = 0; nIndex < nIndexMax; nIndex++)
if (::GetSubMenu(hParentMenu, nIndex) == pPopupMenu->m_hMenu)
// When popup is found, m_pParentMenu is containing menu.
state.m_pParentMenu = CMenu::FromHandle(hParentMenu);
break;
state.m_nIndexMax = pPopupMenu->GetMenuItemCount();
for (state.m_nIndex = 0; state.m_nIndex < state.m_nIndexMax;
state.m_nIndex++)
state.m_nID = pPopupMenu->GetMenuItemID(state.m_nIndex);
if (state.m_nID == 0)
continue; // Menu separator or invalid cmd - ignore it.
ASSERT(state.m_pOther == NULL);
ASSERT(state.m_pMenu != NULL);
if (state.m_nID == (UINT)-1)
// Possibly a popup menu, route to first item of that popup.
state.m_pSubMenu = pPopupMenu->GetSubMenu(state.m_nIndex);
if (state.m_pSubMenu == NULL ||
(state.m_nID = state.m_pSubMenu->GetMenuItemID(0)) == 0 ||
continue; // First item of popup can't be routed to.
state.DoUpdate(this, TRUE); // Popups are never auto disabled.
else
// Normal menu item.
// Auto enable/disable if frame window has m_bAutoMenuEnable
// set and command is _not_ a system command.
state.m_pSubMenu = NULL;
state.DoUpdate(this, FALSE);
// Adjust for menu deletions and additions.
UINT nCount = pPopupMenu->GetMenuItemCount();
if (nCount < state.m_nIndexMax)
state.m_nIndex -= (state.m_nIndexMax - nCount);
while (state.m_nIndex < nCount &&
pPopupMenu->GetMenuItemID(state.m_nIndex) == state.m_nID)
state.m_nIndex++;
state.m_nIndexMax = nCount;
这样再处理就可以了
