3234|4
63
請問WINCE OV511的SOURCE CODE問題 [复制链接]
不知網上的各位大大有沒有人去讀過WINCE OV511的SOURCE CODE,我看裡面的CODE並沒有對OV7620 SENSOR下值???這樣對嗎???因為我身邊沒有網眼V2000的攝像頭,所以也無法確定這網絡上載下來的驅動能不能動。
int Ov511ModeInitRegs(PDRVCONTEXT pDrv,int width, int height, int sub_flag) {         int hsegs, vsegs;         if (!Ov51xStop(pDrv))         {                 return 0;         }                         RegisterWrite(pDrv, R511_CAM_UV_EN, 0x01);         RegisterWrite(pDrv, R511_SNAP_UV_EN, 0x01);         RegisterWrite(pDrv, R511_SNAP_OPTS, 0x03);                 /* Here I'm assuming that snapshot size == image size.          * I hope that's always true. --claudio          */         hsegs = (width >> 3) - 1;         vsegs = (height >> 3) - 1;         RegisterWrite(pDrv, R511_CAM_PXCNT, hsegs);         RegisterWrite(pDrv, R511_CAM_LNCNT, vsegs);         RegisterWrite(pDrv, R511_CAM_PXDIV, 0x00);         RegisterWrite(pDrv, R511_CAM_LNDIV, 0x00);         /* YUV420, low pass filter on */         RegisterWrite(pDrv, R511_CAM_OPTS, 0x03);         /* Snapshot additions */         RegisterWrite(pDrv, R511_SNAP_PXCNT, hsegs);         RegisterWrite(pDrv, R511_SNAP_LNCNT, vsegs);         RegisterWrite(pDrv, R511_SNAP_PXDIV, 0x00);         RegisterWrite(pDrv, R511_SNAP_LNDIV, 0x00);         /*         if (ov->compress) {                 /* Enable Y and UV quantization and compression */                 /*RegisterWrite(pDrv, R511_COMP_EN, 0x07);                 RegisterWrite(pDrv, R511_COMP_LUT_EN, 0x03);                 ov51x_reset(ov, OV511_RESET_OMNICE);         }*/         if (!Ov51xRestart(pDrv))         {                 return 0;         }         return 1; } //给OV511寄存器赋初始值(在OV511初始化时调用) int WriteRegvals(PDRVCONTEXT pDrv) {         RegisterWrite(pDrv,R51x_SYS_RESET,0x7f);         RegisterWrite(pDrv,R51x_SYS_INIT,0x01);         RegisterWrite(pDrv,R51x_SYS_RESET,0x7f);         RegisterWrite(pDrv,R51x_SYS_INIT,0x01);         RegisterWrite(pDrv,R51x_SYS_RESET,0x3f);         RegisterWrite(pDrv,R51x_SYS_INIT,0x01);         RegisterWrite(pDrv,R51x_SYS_RESET,0x3d);                 return 1; }   详情 回复 发表于 2008-5-10 04:29
83
???怎么会没有?我读过...有滴..你自己好好研究以下,他们是iic来操作的。。。
79
看datasheet吧
67
引用 1 楼 0001cxg 的回复:
0001cxg你好,我在USBVedio.h只有看到OV511 define 的這些值,但是沒有看到Sensor 寄存器的Define,可以麻煩告知我在哪裡嘛???謝謝
/* Camera interface register numbers */
#define R511_CAM_DELAY                0x10
#define R511_CAM_EDGE                0x11
#define R511_CAM_PXCNT                0x12
#define R511_CAM_LNCNT                0x13
#define R511_CAM_PXDIV                0x14
#define R511_CAM_LNDIV                0x15
#define R511_CAM_UV_EN                0x16
#define R511_CAM_LINE_MODE        0x17
#define R511_CAM_OPTS                0x18
/* Snapshot mode camera interface register numbers */
#define R511_SNAP_FRAME                0x19
#define R511_SNAP_PXCNT                0x1A
#define R511_SNAP_LNCNT                0x1B
#define R511_SNAP_PXDIV                0x1C
#define R511_SNAP_LNDIV                0x1D
#define R511_SNAP_UV_EN                0x1E
#define R511_SNAP_OPTS                0x1F
/* DRAM register numbers */
#define R511_DRAM_FLOW_CTL        0x20
#define R511_DRAM_ARCP                0x21
#define R511_DRAM_MRC                0x22
#define R511_DRAM_RFC                0x23
#define R51x_SYS_RESET                0x50
#define R51x_SYS_INIT       0x53
#define OV511_NUMSBUF                2
#define FRAMES_PER_DESC                10
75
        int hsegs, vsegs;
                return 0;
        if (ov->compress) {
                return 0;
        return 1;
        return 1;
