2982|0
65
关于SDIO设备设置clock [复制链接]
各位,我想设置SDIO的clock。以下是ntddsd.h中的一段。
    // Definitions for properties used in Get/Set Property requests
    // The bus driver version where any given property was introduced is
    // indicated as a comment to the right of the property. Note that the
    // property to retrieve the version was not introduced until v2.0.
    // Callers can determine the bus driver is at version 1.0 by looking
    // for a STATUS_INVALID_PARAMETER return from an get property call on
    // SDP_BUS_DRIVER_VERSION.
    typedef enum {
        SDP_MEDIA_CHANGECOUNT = 0,          // v1.0  ULONG
        SDP_MEDIA_STATE,                    // v1.0  SDPROP_MEDIA_STATE
        SDP_WRITE_PROTECTED,                // v1.0  BOOLEAN
        SDP_FUNCTION_NUMBER,                // v1.0  UCHAR
        SDP_FUNCTION_TYPE,                  // v2.0  SDBUS_FUNCTION_TYPE
        SDP_BUS_DRIVER_VERSION,            // v2.0  USHORT
        SDP_BUS_WIDTH,                      // v2.0  UCHAR
        SDP_BUS_CLOCK,                      // v2.0  ULONG
        SDP_BUS_INTERFACE_CONTROL,          // v2.0  UCHAR
        SDP_HOST_BLOCK_LENGTH,              // v2.0  USHORT
        SDP_FUNCTION_BLOCK_LENGTH,          // v2.0  USHORT
        SDP_FN0_BLOCK_LENGTH,              // v2.0  USHORT
        SDP_FUNCTION_INT_ENABLE,            // v2.0  BOOLEAN
    } SDBUS_PROPERTY;
我的SDP_BUS_CLOCK,SDP_BUS_WIDTH,SDP_BUS_DRIVER_VERSION都没有请求成功。但 SDP_FUNCTION_NUMBER请求成功。我不太明白这里的1.0和2.0是什么意思,是不是我的host controller是1.0的,怎么改成2.0的。我怎么设置SDIO设备的clock呢??
谢谢!!
