3463|4
66
展讯平台下的播放器(mpg4模块)问题 [复制链接]
现在就是在6600D下,lcd_main.c里面有一些关于播放器全屏的问题,就是正常播放的时候可以,但是当点击全屏的时候画面变花了,看不清楚,不是全屏的样而且屏幕应该变横着的了的,好象是有关的储存器设置有问题,有没有相关的经验人士帮忙解决一下
6600D+ST7669V+cstn的屏
void lcd_main_mpg4_refresh
uint16 left,  //the left value of the rectangel
uint16 top,  //top of the rectangle
uint16 right,  //right of the rectangle
uint16 bottom, //bottom of the rectangle
uint16 *buf_ptr,
uint8  is_invert
uint16 i,j;
uint16 address = 0;
//add by lw 2008-01-07
#ifdef CMI_CSTN_st7669vLCD
st7669lcd_main_region(left,top,right,bottom);
#else
/*set Address Direction*/
if (is_invert)
  lcd_main_reg_write(0x0005,0x0028);
else
  lcd_main_reg_write(0x0005,0x0030);
/*1:set horizon address and vertical address*/
address = (uint16) (((right & 0xFF) << 8) | (left & 0xFF ));
lcd_main_reg_write(g_lcd_main_region_table[0].addr, address);  // set horizon address
address = (uint16) (((bottom & 0xFF) << 8) | (top & 0xFF));
   lcd_main_reg_write(g_lcd_main_region_table[1].addr, address);  //  set vertical  address position
/*set ram address*/
if (is_invert)
  address = (uint16) (((top & 0xFF) << 8) | (right & 0xFF));
  lcd_main_reg_write(g_lcd_main_region_table[2].addr, address); // Set start RAM address (AC register)
else
  address = (uint16) (((top & 0xFF) << 8) | (left & 0xFF));
/*write data*/
lcd_main_reg_cmd_write(g_lcd_main_region_table[3].addr);
#endif
if (is_invert)
  /*write data*/
  for (i= left;  i<= right; i++)
   for (j = top; j <= bottom; j++) // real write
    lcd_main_reg_data_write( *(buf_ptr + i * LCD_MAIN_MP4_WIDTH + j) );
else
  /*write data*/
  uint rTmp = LCD_MAIN_WIDTH;//((right - left + 1) * (bottom - top + 1)) / LCD_MAIN_MP4_WIDTH + 1;
  //SCI_TRACE_LOW(" lcd_main_mpg4_refresh(): left= %d,right = %d,top= %d,bottom = %d\n",left,right,top,bottom);
  if (bottom > rTmp)
   bottom = rTmp;
  for (i= top;  i<= bottom; i++)
   for (j = left; j <= right; j++) // real write
  lcd_main_mpg4_icon_refresh(0,
   0,
   (LCD_MAIN_WIDTH - 1),
   (LCD_MAIN_HEIGHT -LCD_MAIN_WIDTH - 2),
   (uint16*)g_mpg4_bmp[g_mpg4_bmp_index].map->bitmap);
#ifndef CMI_CSTN_st7669vLCD
#endif
return;
帮忙看一下,什么地方要改的,谢谢了
看来是没人回答了  详情 回复 发表于 2008-2-19 08:24
59
怎么没人给解疑一下呢
79
找展讯公司吧,他们公司支持做的不错
79
他们公司的网站上面也没什么东西啊,找不到什么好的
看来是没人回答了
