2850|4
79
p3.3模拟串口接收 救命呀 [复制链接]
这样子是可以的,没有用到中断口,如果程序外的理事多点就会出问题的,那么需要用到外部中断
#include
#include
#include
#include
#define uint unsigned int
#define uchar unsigned char
//#define REN_485 P21  //为0则可以接受,否则发送
#define TIMER0_ENABLE TL0=TH0; TR0=1;
#define TIMER0_DISABLE TR0=0;
unsigned char  S485_SEND_BUFFER[80] ,rev_num;
code unsigned char C51BOX2[3]_at_ 0x43 ;
bit          REN_485         ;
//#define F_TM F0
bit F_TM;
uchar time_count;
sbit BT_SND =P1^0;
sbit BT_REC =P3^3;
sbit ACC0= ACC^0;
sbit ACC1= ACC^1;
sbit ACC2= ACC^2;
sbit ACC3= ACC^3;
sbit ACC4= ACC^4;
sbit ACC5= ACC^5;
sbit ACC6= ACC^6;
sbit ACC7= ACC^7;
void IntTimer0() interrupt 1 using 1
F_TM=1;
time_count++;
//发送一个字符
void PSendChar(uchar inch)
  uchar ii;
  time_count=0;
  REN_485=1;
  ii=0;
  F_TM=0;
  BT_SND=0; //start bit
  TIMER0_ENABLE; //启动
  while(!F_TM);
  while(ii<8)
      if(inch&1)
         BT_SND=1;
      else
         BT_SND=0;
       F_TM=0;
      while(!F_TM);
      ii++;
      inch>>=1;
  BT_SND=1;
  F_TM=0;
  while(!F_TM);
  TIMER0_DISABLE; //停止timer
//接收一个字符
uchar PGetChar()
uchar rch,ii;
TIMER0_ENABLE;
F_TM=0;
ii=0;
rch=0;
while(!F_TM); //等过起始位
while(ii<8)
  rch>>=1;
  if(BT_REC)
   rch|=0x80;
  ii++;
  F_TM=0;
  while(!F_TM);
F_TM=0;
while(!F_TM)
  if(BT_REC)
   break;
return rch;
//检查是不是有起始位
bit StartBitOn()
return (BT_REC==0);
void main()
uchar gch,i;
TMOD=0x22; //定时器1为工作模式2(8位自动重装),0为模式2(8位8位自动重装)
PCON=00;
TR0=0; //在发送或接收才开始使用
TF0=0;
TH0=0xA0;
TL0=0xA0;
ET0=1;
EA=1;
rev_num=0 ;
while(1)
    REN_485=0;
  if(StartBitOn())
         gch=PGetChar();
         if (gch>0)
            S485_SEND_BUFFER[rev_num]        = gch ;
            rev_num++  ;
         if  (rev_num>= 10 )
        for (i=0;i<= rev_num;i++)
                   PSendChar(S485_SEND_BUFFER);
                   S485_SEND_BUFFER=0 ;
           rev_num =0;
请兄弟们解难呀,我用外部中断去处理了,总是收不到数呢,
#include
#include
#include
#include
bit          REN_485,Rev_falg         ;
//#define F_TM F0
bit F_TM;
uchar time_count;
sbit BT_SND =P1^0;
sbit BT_REC =P3^3;
sbit ACC0= ACC^0;
sbit ACC1= ACC^1;
sbit ACC2= ACC^2;
sbit ACC3= ACC^3;
sbit ACC4= ACC^4;
sbit ACC5= ACC^5;
sbit ACC6= ACC^6;
sbit ACC7= ACC^7;
void PGetChar() ;
void PSendChar(uchar inch) ;
        F_TM=1;
void S485_ini1(void) interrupt 2 using 3
     EX1=0;                      //关闭中断口1
          Rev_falg =1 ;
        BT_REC=0  ;
        PGetChar() ;
//发送一个字符
  uchar ii;
  time_count=0;
   rev_num=0 ;
  REN_485=1;
  ii=0;
  F_TM=0;
  TIMER0_ENABLE; //启动
  while(!F_TM);
  while(ii<8)
      if(inch&1)
         BT_SND=1;
      else
         BT_SND=0;
       F_TM=0;
      while(!F_TM);
      ii++;
      inch>>=1;
  BT_SND=1;
  F_TM=0;
  while(!F_TM);
//接收一个字符
void PGetChar()
uchar rch,ii;
//TIMER0_ENABLE;
F_TM=0;
ii=0;
rch=0;
while(ii<8)
  rch>>=1;
  if(BT_REC)
   rch|=0x80;
  ii++;
  F_TM=0;
  while(!F_TM);
F_TM=0;
while(!F_TM)
  if(BT_REC)
   break;
  S485_SEND_BUFFER[rev_num]        = rch;
  rev_num++  ;
EX1=1;
//检查是不是有起始位
bit StartBitOn()
return (BT_REC==0);
void main()
uchar gch,i;
PCON=00;
TF0=0;
TH0=0xA0;
TL0=0xA0;
ET0=1;
   EX1=1;                      //开中断口1
EA=1;
rev_num=0 ;
          Rev_falg=0 ;
while(1)
怎么办呀
先改这个看效果再说 void PGetChar() { uchar rch,ii; //TIMER0_ENABLE;    详情 回复 发表于 2008-7-9 16:23
81
你可以先拿示波器量一下看外部中断脚有没有中断信号 ,如果连中断信号都没有,当然不会有数据的
有外部中断信号 但是不能执行到定时器中断,好奇怪呢
79
有外部中断信号,但你能确定它进int1中断程序了吗?
还有:
//接收一个字符
void PGetChar()
uchar rch,ii;
//TIMER0_ENABLE; >>>>>>>>>这句为什么要注释掉呢?这样不是没人启动定时器了吗?
F_TM=0;
ii=0;
rch=0;
先改这个看效果再说
void PGetChar()
uchar rch,ii;
//TIMER0_ENABLE;  <----这个被注释掉了。
你的程序架构比较混乱。
在外1里面调用PGetChar(),在PGetChar里面等定0中断。这里面的中断优先级和中断嵌套都很复杂呀。怎么想起来的?
调试方法:用一个按键,按照串口协议来模拟串口输入,这样时序很长,你可以用调试器跟踪,也可以输出个什么来判断。其实就是波特率特别特别小而已。
