4960|4
75
wince上 怎么样PNG转成bmp呀? [复制链接]
void LoadPngImage(HDC hdc, DWORD ImgID)    {            IImagingFactory* pImageFactory = 0;            IImage* pImage = 0;            ImageInfo imageInfo;            CoInitializeEx(0, COINIT_MULTITHREADED);            HBITMAP hBitmap = 0;            LPBYTE lpByte;            if (SUCCEEDED(CoCreateInstance(CLSID_ImagingFactory, 0, CLSCTX_INPROC_SERVER,                 IID_IImagingFactory, (void**)&pImageFactory)))            {                 HRSRC hr;//资源句柄                 hr = FindResource(AfxGetResourceHandle(),MAKEINTRESOURCE(ImgID),_T("PNG"));                 HGLOBAL hglobal= LoadResource(AfxGetResourceHandle(), hr );                 LockResource(hglobal);                 int nSize = 0;                 nSize = (UINT)SizeofResource(AfxGetResourceHandle(), hr);                 //if (SUCCEEDED(pImageFactory->CreateImageFromFile(filename, &pImage))&& SUCCEEDED(pImage->GetImageInfo(&imageInfo)))                    if(SUCCEEDED(pImageFactory-> CreateImageFromBuffer((BYTE*)hglobal, nSize, BufferDisposalFlagNone ,&pImage))&& SUCCEEDED(pImage->GetImageInfo(&imageInfo)))                 {                            HDC bmpDC = CreateCompatibleDC(hdc);                            //LPBYTE lpByte;                            BITMAPINFO *pbinfo ;                            pbinfo = (BITMAPINFO *)calloc(1,sizeof(BITMAPINFO) + 4 * sizeof(INT)) ;                            if(!pbinfo)                                    return FALSE ;                            pbinfo->bmiHeader.biSize = sizeof (BITMAPINFOHEADER);                            pbinfo->bmiHeader.biWidth = imageInfo.Width ;                            pbinfo->bmiHeader.biHeight = imageInfo.Height ;                            pbinfo->bmiHeader.biPlanes = 1;                            pbinfo->bmiHeader.biBitCount = 32;                            pbinfo->bmiHeader.biCompression = BI_ALPHABITFIELDS;                            pbinfo->bmiHeader.biSizeImage = 0 ;                            pbinfo->bmiHeader.biXPelsPerMeter = 11811;                            pbinfo->bmiHeader.biYPelsPerMeter = 11811;                            pbinfo->bmiHeader.biClrUsed = 0;                            pbinfo->bmiHeader.biClrImportant = 0;                            int *pMask = (int*)&(pbinfo->bmiColors[0]) ;                            *pMask++ = 0x00FF0000 ;                            *pMask++ = 0x0000FF00 ;                            *pMask++ = 0x000000FF ;                            *pMask++ = 0xFF000000 ;                            hBitmap = CreateDIBSection(NULL, pbinfo, DIB_RGB_COLORS, (void **)&lpByte, NULL, 0) ;                            free(pbinfo) ;                            if(!hBitmap || !lpByte)                                    return FALSE ;                            RECT rect = {0, 0, imageInfo.Width, imageInfo.Height};                            IBitmapImage *pBitmapImage;                            BitmapData bitmapData;                            bitmapData.Width = imageInfo.Width;                            bitmapData.Height = imageInfo.Height;                            bitmapData.PixelFormat = imageInfo.PixelFormat;                            pBitmapImage = NULL;                            pImageFactory->CreateBitmapFromImage(pImage, imageInfo.Width, imageInfo.Height,                                 PIXFMT_32BPP_ARGB,InterpolationHintDefault, &pBitmapImage);                            pBitmapImage->LockBits(&rect, ImageLockModeRead,PIXFMT_32BPP_ARGB, &bitmapData);                            //transferring the pixels                            memcpy(lpByte, bitmapData.Scan0, imageInfo.Width * imageInfo.Height * 4);                            pBitmapImage->UnlockBits(&bitmapData);                         UnlockResource(hglobal);                         pBitmapImage->Release();                            pImage->Release();                            DeleteDC(bmpDC);                    }                    pImageFactory->Release();            }            CoUninitialize();            //ProcessThePixelsWithAlphaChannel Here                 // vertical flip and ProcessThePixelsWithAlphaChannel here            for (UINT y=0; y  详情 回复 发表于 2009-9-17 14:27
81
先用 IImage 把 png 读到内存,然后创建个设备无关的位图,把 png 画到位图上,最后再写到文件里
84
我这边不需要生成bmp文件 只是想得到bmp的位图句柄 然后就放到ddraw的 surface上来显示的!
Really 可以再具体说说吧?
我先试试 看看 然后再请教你吧!
92
谢谢 真的可以!搞定了 结婚!
83
        IImage* pImage = 0;
        LPBYTE lpByte;
                HRSRC hr;//资源句柄
                int nSize = 0;
                        //LPBYTE lpByte;
                        if(!pbinfo)
                                return FALSE ;
                        free(pbinfo) ;
                                return FALSE ;
                        pImage->Release();
                        DeleteDC(bmpDC);
        CoUninitialize();
        for (UINT y=0; y         {
                BYTE * pPixel = (BYTE *) lpByte + imageInfo.Width * 4 * y;
                BYTE * pDstPixel = (BYTE*) lpByte + imageInfo.Width * 4 * (imageInfo.Height-y-1);
                for (UINT x=0; x                 {
                        pPixel[0] = pPixel[0] * pPixel[3] / 255;
                        pPixel[1] = pPixel[1] * pPixel[3] / 255;
                        pPixel[2] = pPixel[2] * pPixel[3] / 255;
                        pDstPixel[0] = pDstPixel[0] * pDstPixel[3] / 255;
                        pDstPixel[1] = pDstPixel[1] * pDstPixel[3] / 255;
                        pDstPixel[2] = pDstPixel[2] * pDstPixel[3] / 255;
                        INT* pOrigin = (INT*)pPixel;
                        INT* pDst    = (INT*)pDstPixel;
                        INT temp = *pOrigin;
                        *pOrigin = *pDst;
                        *pDst = temp;
                        pPixel += 4;
                        pDstPixel += 4;
        return hBitmap;
