4578|8
驱动项目编译无法生成DLL文件 [复制链接]
我的SPI驱动项目编译无法生成DLL文件,纠结中。。。
我在项目文件夹运行命令Build,显示如下信息:
C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\SPI>build
Build for Windows CE (Release 601) (Built on Aug 17 2006 15:18:52)
File names: Build.log Build.wrn Build.err Build.dat
BUILD: [Thrd:Sequence:Type  ] Message
BUILD: [00:0000000000:PROGC ] Build started with parameters:
BUILD: [00:0000000001:PROGC ] Build started in directory: C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\SPI
BUILD: [00:0000000002:PROGC ] Checking for C:\WINCE600\sdk\bin\i386\srccheck.exe.
BUILD: [00:0000000003:PROGC ] Running passes WCEFILES0, MIDL, MC, ASN, THUNK, PR
ECOMPHEADER, COMPILE, LIB, LINK, MANAGEDRESX, MANAGEDMOD, MANAGEDDLL, MANAGEDEXE, MANAGEDWIN for ARM.
BUILD: [00:0000000004:PROGC ] Loading database "C:\WINCE600\PLATFORM\SMDK6410\Build.dat".
BUILD: [00:0000000005:PROGC ] Done.
BUILD: [00:0000000006:PROGC ] Computing include file dependencies:
BUILD: [00:0000000007:PROGC ] Checking for SDK include directory: C:\WINCE600\sdk\CE\inc.
BUILD: [00:0000000008:PROGC ] Scan C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\SPI\
BUILD: [00:0000000009:PROGC ] Saving C:\WINCE600\PLATFORM\SMDK6410\Build.dat.
BUILD: [00:0000000012:PROGC ] Building COMPILE Pass in C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\SPI\ directory.
BUILD: [00:0000000022:WARNN ] File: C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\SPI\obj\ARMV4I\retail\spi.obj does not exist (2).
BUILD: [00:0000000026:PROGC ] Building LIB Pass in C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\SPI\ directory.
BUILD: [00:0000000036:WARNN ] File: C:\WINCE600\platform\SMDK6410\lib\ARMV4I\retail\s3c6410_spi.lib does not exist (2).
BUILD: [00:0000000037:WARNN ] C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\SPI\: Missing source file: C:\WINCE600\public\common\sdk\lib\ARMV4I\retail\coredll.lib.
BUILD: [00:0000000038:WARNN ] C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\SPI\: Missing source file: C:\WINCE600\public\common\oak\lib\ARMV4I\retail\ceddk.lib.
BUILD: [00:0000000046:PROGC ] Building LINK Pass in C:\WINCE600\PLATFORM\SMDK6410\SRC\DRIVERS\SPI\ directory.
BUILD: [00:0000000056:PROGC ] Saving C:\WINCE600\PLATFORM\SMDK6410\Build.dat.
BUILD: [00:0000000058:PROGC ] Done.
BUILD: [00:0000000059:PROGC ]                        Files  Warnings  Errors
BUILD: [00:0000000060:PROGC ] Midl                       0         0       0
BUILD: [00:0000000061:PROGC ] Message                    0         0       0
BUILD: [00:0000000062:PROGC ] Precomp Header             0         0       0
BUILD: [00:0000000063:PROGC ] Resource                   0         0       0
BUILD: [00:0000000064:PROGC ] MASM                       0         0       0
BUILD: [00:0000000065:PROGC ] SHASM                      0         0       0
BUILD: [00:0000000066:PROGC ] ARMASM                     0         0       0
BUILD: [00:0000000067:PROGC ] MIPSASM                    0         0       0
BUILD: [00:0000000068:PROGC ] C++                        0         0       0
BUILD: [00:0000000069:PROGC ] C                          0         0       0
BUILD: [00:0000000070:PROGC ] Static Libraries           0         0       0
BUILD: [00:0000000071:PROGC ] Exe's                      0         0       0
BUILD: [00:0000000072:PROGC ] Dll's                      0         0       0
BUILD: [00:0000000073:PROGC ] Preprocess deffile         0         0       0
BUILD: [00:0000000074:PROGC ] Resx                       0         0       0
BUILD: [00:0000000075:PROGC ] CSharp Compile             0         0       0
BUILD: [00:0000000076:PROGC ] Other                      0         0       0
BUILD: [00:0000000077:PROGC ]
BUILD: [00:0000000078:PROGC ] Total                      0         0       0
BUILD: [00:0000000079:PROGC ]
BUILD: [00:0000000080:PROGC ] 0 Warnings,  0 Errors
BUILD: [00:0000000081:PROGC ] GetSystemTimes (seconds): Idle: 0     Kernel: 1  User: 0
BUILD: [00:0000000082:PROGC ] Elapsed  time  (seconds): 1
我找到了,里面设置的是 set BSP_NOSPI=1 改成 set BSP_NOSPI 就可以了 多谢  详情 回复 发表于 2009-12-15 10:54
77
DIR文件没错,SOURCE文件如下:
!if "$(BSP_NOSPI)" == "1"
SKIPBUILD=1
!endif
RELEASETYPE=PLATFORM
PREPROCESSDEFFILE=1
TARGETNAME=s3c6410_spi
TARGETTYPE=DYNLINK
DEFFILE=s3c6410_spi.def
DLLENTRY=DllEntry
INCLUDES= \
    $(INCLUDES);$(_TARGETPLATROOT)\src\drivers\DMA\s3c6410_dma_lib;. \
TARGETLIBS=\
    $(_COMMONSDKROOT)\lib\$(_CPUINDPATH)\coredll.lib    \
    $(_COMMONOAKROOT)\lib\$(_CPUINDPATH)\ceddk.lib    \
    $(_TARGETPLATROOT)\lib\$(_CPUINDPATH)\DriverLib.lib
SOURCELIBS=\
    $(_TARGETPLATROOT)\lib\$(_CPUINDPATH)\s3c6410_dma_lib.lib    \
SOURCES=\
    spi.c
s3c6410_spi.def内容:
LIBRARY spi
EXPORTS
    SPI_Init
    SPI_Deinit
    SPI_Open
    SPI_Close
    SPI_Read
    SPI_Write
    SPI_Seek
    SPI_IOControl
    SPI_PowerDown
    SPI_PowerUp
platform.reg里:
IF BSP_NOSPI !
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\spi]
        "Prefix"="SPI"
        "Dll"="s3c6410_spi.dll"
        "Index"=dword:1
        "Order"=dword:30
ENDIF BSP_NOSPI !
platform.bib里:
IF BSP_NOSPI !
    s3c6410_spi.dll        $(_FLATRELEASEDIR)\s3c6410_spi.dll                NK            SHK
ENDIF BSP_NOSPI !
请教为什么得不到DLL文件,好像他就没编译源文件,直接找的.obj文件,但不存在。
BSP_NOSPI设置的是多少?
57
IF BSP_NOSPI ! 要设置的  你可以可以先把SPI驱动里面的obj文件夹给删了 重新编译 生成OBJ文件
66
尝试将source文件中:
SKIPBUILD=1
!endif
先屏蔽掉再编译看看!
82
引用 4 楼 zhoukq 的回复:
尝试将source文件中:
SKIPBUILD=1
!endif
先屏蔽掉再编译看看!
去掉再编译就ok了,但我不明白这个BSP_NOSPI是在哪里设置的,我怎么修改它的值,谢谢!
78
闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾剧懓顪冪€n亝鎹i柣顓炴閵嗘帒顫濋敐鍛婵°倗濮烽崑鐐烘偋閻樻眹鈧線寮撮姀鐘栄囨煕閳╁啨浠︾紒顔瑰墲娣囧﹪鎮欓鍕ㄥ亾閺嶎厼绀夌憸蹇曞垝婵犳艾绠i柣妯烘▕濡粓姊虹粔鍡楀濞堟洟鏌i幘瀛樼闁哄瞼鍠栭弻鍥晝閳ь剟鎮橀柆宥嗙厱闁靛牆鎷嬮崕鏃堟煛鐏炶鈧繂顕i崼鏇炵閹肩补鈧弶妯婇梻鍌欑閹碱偊寮甸鍌滅煓闁硅揪绠戦悡鈥愁熆鐠哄彿鍫ュ几鎼淬劍鐓欓梺顓ㄧ畱閺嬨倝鏌嶇拠鑼婵﹨娅i幏鐘诲箵閹烘繂濡烽梻浣哄帶缂嶅﹦绮婚弽顒侇棨濠电偞娼欓崥瀣缚濞嗘劦鏀伴梻鍌欑閹测€趁洪敃鍌氬瀭闁规鍠氭稉宥夋煙閹澘袚闁绘挻娲熼弻宥夊煛娴e憡娈ф繛瀵稿缁犳垿鈥︾捄銊﹀枂闁告洦鍓涢ˇ顓犵磽娴d粙鍝洪柟鐟版搐閻g兘骞掗幋鏃€鐎婚梺鐟扮摠缁诲倿鈥栨径瀣╃箚闁绘劦浜滈埀顒佸灴瀹曟繄浠︽潪鎸庣☉閳规垹鈧綆浜濋悗顒勬⒑閸涘﹤濮﹂柛鐘崇墵閿濈偤宕ㄧ€涙ḿ鍘藉┑鈽嗗灥濞咃絾绂掑☉娆戠闁割偆鍠庨崝銈夋煃鐟欏嫬鐏︽鐐诧躬閺屾稒绻濋崘鈺冾槹濡ょ姷鍋涢敃銉╁箚閺冨牆顫呴柣妯诲絻椤﹪姊婚崒姘偓鎼佸磹妞嬪海鐭嗗〒姘e亾闁诡喖娼″畷鎯邦檨婵炲瓨鐗犻弻鏇熺箾瑜嶉幊鎰版倿閸忚偐绠鹃弶鍫濆⒔缁夘剚銇勯銏╂█鐎规洩缍€缁犳稑鈽夊▎鎴濆妇闂備礁澹婇崑鍛崲瀹ュ憘锝堛亹閹烘挾鍘介梺瑙勫礃濞夋盯寮稿☉銏$厸鐎光偓鐎n剙鍩屽銈庡亝缁捇宕洪埀顒併亜閹哄秷鍏屾い鈺傜叀閹娼幏宀婂妳闂佽楠搁悥濂稿蓟閿濆绠i柨婵嗘啗閹剧粯鐓熼柟鎯х摠缁€瀣煛瀹€瀣瘈鐎规洘甯掗埞鎴﹀炊閳瑰簱鍋撴繝鍕=濞达絽鎼暩缂備緡鍣崹鑸典繆閻㈢ǹ绀嬫い鏍ㄥ嚬濞煎﹪姊洪幐搴b槈閻庢凹鍙冨畷鎶藉级鐠囩偓妫冮幃鈺呮濞戞鎹曟俊鐐€栭崹鐢杆囬棃娑卞殨妞ゆ劧绠戠壕濂告煟閹邦厽缍戞繛鍫㈠枛濮婃椽妫冨☉杈€嗘繝纰樷偓铏┛闁靛洦鍔欐俊鎼佸煛閸屾瀚奸梺鑽ゅТ濞诧箓鎮¢敓鐙€鏁佹俊銈呮噺閻撴洘淇婇婵嗗惞闁活厽甯為埀顒冾潐濞叉﹢宕归崸妤冨祦婵☆垵鍋愮壕鍏间繆椤栨粌甯舵鐐茬墦濮婄粯鎷呴崫銉ㄩ梺绋款儏閿曨亜鐣烽姀锛勯檮缂佸娉曢ˇ顕€姊洪棃娑氬婵☆偅绋撶划缁樸偅閸愨晝鍘卞銈嗗姦閸嬪嫭鏅堕鐐村€垫慨妯煎亾鐎氾拷闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾惧湱鈧懓瀚崳纾嬨亹閹烘垹鍊炲銈嗗笂缁€渚€宕滈鐑嗘富闁靛牆妫楁慨褏绱掗悩鍐茬伌闁绘侗鍣f慨鈧柕鍫濇閸樻捇鏌℃径灞戒沪濠㈢懓妫濆畷婵嗩吋閸℃劒绨婚梺鍝勫€搁悘婵嬵敂椤愩倗纾奸弶鍫涘妽瀹曞瞼鈧娲樼敮鎺楋綖濠靛鏁勯柦妯侯槷婢规洟姊洪崨濠勭細闁稿孩濞婇幆灞解枎閹惧鍘遍梺鍝勬储閸斿矂鎮橀悩鐢电<闁绘瑢鍋撻柛銊ョ埣瀵濡搁埡鍌氫簽闂佺ǹ鏈粙鎴︻敂閿燂拷闂傚倸鍊搁崐鎼佸磹閹间礁纾归柟闂寸绾惧綊鏌i幋锝呅撻柛銈呭閺屾盯顢曢敐鍡欘槬缂備胶濮锋繛鈧柡宀€鍠栧畷婊嗩槾閻㈩垱鐩弻娑氣偓锝冨妼閳ь剚绻堝濠氬即閻旇櫣顔曢梺缁樺姦閸撴岸鎮甸弴銏♀拺缂佸顑欓崕蹇斻亜閹存繍妯€鐎殿喖顭烽弫鎰緞婵犲嫮鏉告俊鐐€栫敮濠囨倿閿曞倸纾块柟鍓х帛閳锋垹绱撴担濮戭亞绮幒妤佺厽闊洦鏌ㄩ崫鍝勨攽閿涘嫭鏆€规洜鍠栭、娑橆潩妲屾牕鏁介梻鍌欐祰椤骞嗗畝鍕瀭闂侇剙绉撮弸浣肝旈敐鍛殲闁绘挾鍠栭獮鏍庨鈧悘顕€鏌涢悢鍝ュ弨闁哄瞼鍠栧畷娆撳Χ閸℃浼�婵犵數濮烽弫鍛婃叏閻戣棄鏋侀柛娑橈攻閸欏繘鏌i幋锝嗩棄闁哄绶氶弻鐔兼⒒鐎靛壊妲紒鎯у⒔缁垳鎹㈠☉銏犵闁哄啠鍋撻柛銈呯Ч閺屾盯濡烽鐓庘拻闂佽桨绀佸ú顓㈠蓟閺囷紕鐤€闁哄洨鍊妷锔轰簻闁挎棁顕у▍宥夋煙椤旂瓔娈滅€规洘顨嗗鍕節娴e壊妫滈梻鍌氬€风粈渚€骞夐垾瓒佹椽鏁冮崒姘憋紱婵犮垼鍩栭崝鏇㈠及閵夆晜鐓熼柟閭﹀枛閸斿鏌嶉柨瀣伌闁诡喖缍婇獮渚€骞掗幋婵愮€虫繝鐢靛仜閹冲繘宕濆▎鎾宠摕闁绘梻鍘х粈鍕煏閸繃顥滄い蹇ユ嫹
81
78
电源解决方案和技术 | DigiKey 应用探索站
