2431|1
那位大哥用过三星的OLCD [复制链接]
我现在用的是三星的OLED,驱动IC是S6E63D6,弄了一周还没弄好,那位用过的大哥能帮帮我,只要能显示,不管显示什么都可以。
下面是我写的一点显示也没有。
#include "config.h"
//#define        M68                                // 8-bit 68XX Parallel
                                        //   BS0=1; BS1=1
#define        I80                                // 8-bit 80XX Parallel
                                        //   BS0=0; BS1=1
//#define        SPI                                // 4-wire SPI
                                        //   BS0=0; BS1=0
                                        //   The unused pins should be connected with VSS mostly or floating (D2).
                                        //   Please refer to the SSD1351 specification for detail.
//  Pin Definition
#define xData            IO2SET                        //P0     Parallel Data Input/Output
#define LED                1<<29                        //P0.29  LED
#define OLED_RES        1<<15                        //P0.15  Reset
#define OLED_CS            1<<25                        //P3.25  Chip Select
#define OLED_DC            1<<2                        //P3.2   A0 Data/Command Control
#define OLED_WR            1<<27                        //P3.27  Read/Write Select
#define OLED_RD            1<<1                        //P1.1   E Select
#define Flash_CS    1<<0            //P1.0
#define SRAM_CS     1<<26           //P3.26
#define OLED_HVEN        1<<24                        //P0.24  ???????í
//  Delay Time
void uDelay(unsigned char l)
        while(l--);
void Delay(unsigned char n)
unsigned char i,j,k;
        for(k=0;k         {
                for(i=0;i<131;i++)
                        for(j=0;j<15;j++)
                                uDelay(203);
//  Read/Write Sequence
#ifdef M68                                        // 8-bit 68XX Parallel
void Write_Command(unsigned short Data)
        IO3CLR=OLED_DC; //DC=0;A0
        IO3CLR=OLED_CS; //CS=0;
        IO3CLR=OLED_WR; //RW=0;
        IO1SET=OLED_RD; //E=1;
        IO2PIN=Data;    //xData=Data;
        IO1CLR=OLED_RD; //E=0;
        IO3SET=OLED_WR; //RW=1;
        IO3SET=OLED_CS; //CS=1;
        IO3SET=OLED_DC; //DC=1;
void Write_Data(unsigned short Data)
{        IO3SET=OLED_DC;//DC=1; A0
        IO3CLR=OLED_CS;//CS=0;
        IO3CLR=OLED_WR;//RW=0;
        IO1SET=OLED_RD;//E=1;
        IO1CLR=OLED_RD;//E=0;
        IO3SET=OLED_WR;//RW=1;
        IO3SET=OLED_CS;//CS=1;
        IO3CLR=OLED_DC;//DC=1; A0
#endif
#ifdef I80                                        // 8-bit 80XX Parallel
    //IO1SET=OLED_RD;//E=1; //???±
        IO3CLR=OLED_DC;//DC=0; A0
        IO3CLR=OLED_WR;//WR=0;
        IO3SET=OLED_WR;//WR=1;
#endif
//  Show Regular Pattern (Full Screen)
void Fill_RAM(unsigned short a)
   unsigned char i,j;
        Write_Command(0x35);                        // Vertical RAM Address
        Write_Data(0x000F);
        Write_Command(0x38);                        // Horizontal RAM Address
        Write_Data(0x000F);
        Write_Command(0x22);                        // Enable MCU to Write into RAM
        for(i=0;i<128;i++)
                for(j=0;j<128;j++)
                        Write_Data(a);
void OLED_Init(void)
        Write_Command(0x0003);
        Write_Data(0x0030); // 16bit mode
        Write_Command(0x0001);
        Write_Data(0x881C); // Set scan line
        Write_Command(0x0002);
        Write_Data(0x0000); //
        //Write_Command(0x0003);
        //Write_Data(0x0030); // 16bit mode
        Write_Command(0x0010);
        Write_Data(0x0000); // IC stand by off
        Write_Command(0x0018);
        Write_Data(0x0028); // Frame Rate=80Hz
        Write_Command(0x00f8);
        Write_Data(0x000F); // VGH=+5V
        Write_Command(0x000f9);
        Write_Data(0x0019); // VGL=-7V
        Write_Command(0x0005);
        Write_Data(0x0001); // Display On
        Write_Command(0x0035);
        Write_Data(0x0000); // window display
        Write_Command(0x0036);
        Write_Data(0x00DB); //
        Write_Command(0x0037);
        Write_Data(0x20CF); //
        Write_Command(0x0020);
        Write_Data(0x0020); //
        Write_Command(0x0021);
        Write_Command(0x0070);
        Write_Data(0x3300); //
        Write_Command(0x0071);
        Write_Data(0x3900); //
        Write_Command(0x0072);
        Write_Data(0x3800); //
        Write_Command(0x0073);
        Write_Data(0x2924); //
        Write_Command(0x0074);
        Write_Data(0x261C); //
        Write_Command(0x0075);
        Write_Data(0x3125); //
        Write_Command(0x0076);
        Write_Data(0x271C); //
        Write_Command(0x0077);
        Write_Data(0x352A); //
        Write_Command(0x0078);
        Write_Data(0x2A1E); //
        Fill_RAM(0x0000);                        // Clear Screen
//  Main Program
int main()
        PINSEL0=0x00000005;
        PINSEL1=0x00000000;
        PINSEL2=0x00000030;
         IO0DIR =0xffffffff;
        IO1DIR =0xffffffff;
        IO2DIR =0xffffffff;
        IO3DIR =0xffffffff;
        IO0SET =LED;
        IO0SET =OLED_HVEN;
        IO1SET =Flash_CS;
        IO3SET =SRAM_CS;
        OLED_Init();
        while(1)
          Fill_RAM(0x55FF);
          Delay(50);
MCU程序?难懂!  详情 回复 发表于 2010-3-18 18:41
MCU程序?难懂!
