3580|6
98
C51汇编语言交通灯模拟程序,求指教。 [复制链接]
请问下面这个程序定时器定时的时间是怎么算的,这是一个用模拟交通灯变化的程序。请高手指点一下,定时器的用法。
ORG   000BH
LJMP  T0_INT
ORG   0100H
MAIN:
   MOV SP, #60H
   LCALL  INIT
   LCALL   T0_INIT
LOOP:
         JNB    SECOND_FLAG,LOOP
         LCALL  STATUS_CHANGE
         CLR    SECOND_FLAG
         SJMP   LOOP
STATUS_CHANGE :
      MOV   A, STATUS_FLAG
      ADD   A,STATUS_FLAG
          MOV          DPTR,#STATUS_PROC_TABLE
          JMP   @A+DPTR
STATUS_PROC_TABLE:
      AJMP   STATUS1
          AJMP   STATUS2
          AJMP   STATUS3
          AJMP   STATUS4
          AJMP   STATUS5
          AJMP   STATUS6
STATUS1:
     DJNZ  SECOND_COUNT,STATUS1_EXIT
         MOV    SECOND_COUNT,#6
         MOV    STATUS_FLAG,#01H
STATUS1_EXIT:
     RET
STATUS2:
     DJNZ   SECOND_COUNT, STATUS2_EXIT
         MOV    SECOND_COUNT,#4
         MOV    STATUS_FLAG,#02H
         SETB   SOUTH_RED
         CLR    SOUTH_YELLOW
         SETB   SOUTH_GREEN
         CLR    EAST_RED
         SETB   EAST_YELLOW
         SETB   EAST_GREEN
         RET
STATUS2_EXIT:
     CPL           SOUTH_GREEN
         RET
STATUS3:
     DJNZ   SECOND_COUNT, STATUS3_EXIT
         MOV    SECOND_COUNT,#40
         MOV    STATUS_FLAG,#03H
         CLR    SOUTH_RED
         SETB   SOUTH_YELLOW
         SETB   SOUTH_GREEN
         SETB   EAST_RED
         SETB   EAST_YELLOW
         CLR    EAST_GREEN
STATUS3_EXIT:
     RET
STATUS4:
     DJNZ  SECOND_COUNT,STATUS4_EXIT
         MOV    SECOND_COUNT,#6
         MOV    STATUS_FLAG,#04H
STATUS4_EXIT:
     RET
STATUS5:
     DJNZ   SECOND_COUNT, STATUS5_EXIT
         MOV    SECOND_COUNT,#4
     MOV    STATUS_FLAG,#05H
         CLR   SOUTH_RED
     SETB    SOUTH_YELLOW
         SETB   SOUTH_GREEN
         SETB   EAST_RED
         CLR   EAST_YELLOW
         SETB   EAST_GREEN
         RET
STATUS5_EXIT:
     CPL           SOUTH_GREEN
         RET
STATUS6:
     DJNZ   SECOND_COUNT, STATUS6_EXIT
         MOV    STATUS_FLAG,#06H
         SETB  SOUTH_RED
     SETB    SOUTH_YELLOW
         CLR  SOUTH_GREEN
         CLR   EAST_RED
         SETB  EAST_YELLOW
         SETB   EAST_GREEN
STATUS6_EXIT:
         RET
INIT:
    SETB SOUTH_RED
        SETB  SOUTH_YELLOW
        CLR  SOUTH_GREEN
        CLR   EAST_RED
        SETB  EAST_YELLOW
        SETB  EAST_GREEN
        MOV   TIME_COUNT0,#250
        MOV   TIME_COUNT1,#8
        MOV   SECOND_COUNT, #40
    MOV    STATUS_FLAG,#00H
        CLR   SECOND_FLAG
        RET
T0_INT:
    DJNZ   TIME_COUNT0, T0_INT_EXIT
        DJNZ   TIME_COUNT1,T0_INT_EXIT
        MOV    TIME_COUNT1,#8
        SETB   SECOND_FLAG
T0_INT_EXIT:
   RETI
T0_INIT:
    MOV   TMOD,#00000010B
        MOV    TL0,#06H
        MOV    TH0,#06H
        MOV    TCON,#00010000B
        SETB   EA
        SETB   ET0
        RET
END
具體的定時間隔要看你的晶體的頻率的 看看手冊上關於定時器的幾個工作模式部分應該可以得出答案  详情 回复 发表于 2009-11-22 13:25
改用Keil C吧
64
就是keil编出来的。个人打算先把汇编学好了。以后比较有用
57
后面3段就是计算时间的.用定时器0.
85
用一个功能模块通用的过程都是这样的:
设置控制寄存器
设置相关寄存器
启动
中断请求或查询工作状态
用CPLD做最简单.
