4318|9
86
【求助】ARM控制SED1330LCD320*240出现这种现象是什么原因? [复制链接]
正常现象应该是:■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■填满一行
实际的现象是:  ■  ■■■■■■■■■    ■■■■■■■■■■■■■■  ■■■■随机的消失几个出现到其他地方了
液晶没坏(我特意用while(1)多次扫描发现方块是随机消失的)
单步调试的时候  请大家看dsp1子函数红色部分,光标地址无故成CDCD了(同样也是随机的,郁闷~~)
设置BCFG3寄存器LDR     R1, =0x1000ffef
一些参数的定义.......
#ifndef Graphics_h
#define Graphics_h
#define LCD_WC_PORT    (*(volatile uint16*)(0x83000002))
#define LCD_WD_PORT    (*(volatile uint16*)(0x83000000))
#define SYSTEM_SET     0x40
#define SCROLL         0x44
#define HDOT_SCROLL    0x5a
#define LAYER_SYN      0x5b
#define CURSOR_SET     0x5d
#define CURSOR_RIGHT   0x4c
#define CURSOR_DOWN    0x4f
#define DISPLAY_ON     0x59
#define ALL_LAYER      0x07
#define LAYER1         0x01
#define LAYER2         0x02
#define LAYER3         0x04
#define SET_CURSOR_ADR 0x46
#define DSMEM_WRITE    0x42
#define _lcd_write_command(x)   LCD_WC_PORT=x
#define _lcd_write_data(x)      LCD_WD_PORT=x
extern void GraphicsInit(void);
extern void cleardevice(uint8 layer);
extern void dsp4(uint16 row_num,uint16 col_num);
extern void dsp1(uint16 row_num,uint16 col_num);
#endif
初始化LCD子函数.....
  _lcd_write_command(SYSTEM_SET);
  _lcd_write_data(0x30);  /*1 PKT=0: 64 bit packers*/
                              /*IV=1: no offset*/
                              /*W/S=0: 1-screen drive*/
                              /*M2-M0: select CG ram&rom*/
  _lcd_write_data(7);     /*2 FX: character width = 8*/
  _lcd_write_data(7);     /*3 FY: character height = 8*/
  _lcd_write_data(39);    /*4 C/R: max number of mem adr per line = 40*/
  _lcd_write_data(52);    /*5 TC/R: length of 1 line, inc horizontal blank*/
  _lcd_write_data(239);   /*6 L/F: the height in lines of screen = 240*/
  _lcd_write_data(40);    /*7 APL: with in adrress units of virtual screen*/
  _lcd_write_data(0);     /*8 APH: AP=40*/
  _lcd_write_command(SCROLL);
  _lcd_write_data(0x00);  /*1 SAD1L: 1st screen start adr at 0000h*/
  _lcd_write_data(0x00);  /*2 SAD1H*/
  _lcd_write_data(239);   /*3 SL1: 1st screen has 240 lines*/
  _lcd_write_data(0x80);  /*4 SAD2L: 2nd screen start adr at 2580h*/
  _lcd_write_data(0x25);  /*5 SAD2H*/
  _lcd_write_data(239);   /*6 SL2: 2nd screen has 240 lines */
  _lcd_write_data(0x00);  /*7 SAD3L: 3rd screen start adr at 4b00h */
  _lcd_write_data(0x4b);  /*8 SAD3H*/
  _lcd_write_data(0x80);  /*9 SAD4L: 4rd screen start adr at 7080h */
  _lcd_write_data(0x70);  /*10 SAD4H*/
  _lcd_write_command(HDOT_SCROLL);
  _lcd_write_data(0);     /*zero horizontal pixel shift*/
  _lcd_write_command(LAYER_SYN);
  _lcd_write_data(0x1d);  /*1st&2nd&3rd graphics, three layer syn*/
  _lcd_write_command(CURSOR_SET);
  _lcd_write_data(0x04);  /*CRX=4: cursor x is 5*/
  _lcd_write_data(0x86);  /*CM=1: block cursor*/
                          /*CRY=6: cursor y is 7*/
  _lcd_write_command(CURSOR_RIGHT);  /*cursor right shift*/
清屏子函数.......
  uint16  i;
  if(layer&LAYER1) {
    _lcd_write_command(SET_CURSOR_ADR);
    _lcd_write_command(DSMEM_WRITE);
    for(i=0; i<0x2580; i++) {
  if(layer&LAYER2) {
  if(layer&LAYER3) {
  _lcd_write_command(DISPLAY_ON);
  _lcd_write_data(0x54);
光标像下移动写16字节画一个8*16的小方块.......
uint8 i,x_site,y_site;                 //光标起始点的地址
x_site = (row_num*640+col_num)%256;
y_site = (row_num*640+col_num)/256;
_lcd_write_command(CURSOR_DOWN);//LCD_COM=0x4f;
_lcd_write_command(SET_CURSOR_ADR);//LCD_COM=0x46;
_lcd_write_data(x_site);
_lcd_write_data(y_site);
_lcd_write_command(0x42);//LCD_COM=0x42;
  for(i=0;i<16;i++)
    _lcd_write_data(0xff);//LCD_DAT=0xff;
#include "config.h"
#define LED_Con   1<<22
void DelayNS(uint32 dly)
uint32 i;
for(;dly>0;dly--)
    for(i=50000;i>0;i--);
主程序.....
int main(void)
uint16 i;
PINSEL2=PINSEL2|(~LED_Con);
IO1DIR=IO1DIR|LED_Con;
GraphicsInit();
DelayNS(100);
cleardevice(ALL_LAYER);
DelayNS(2000);
while(1){
IO1SET=LED_Con;
for(i=0;i<40;i++)
   dsp1(7,i);
DelayNS(10);
i=0;
IO1CLR=LED_Con;
DelayNS(100);
while(1);
return(0);
此帖出自ARM技术论坛
会持续到你下次改变IO的电平前,中间有多少个机器周期和多长时间,那么你就要根据指令周期和占用了多少个指令来算了。呵呵  详情 回复 发表于 2010-5-27 11:19
78
处理器/Memory配置有没有问题?
怀疑是Memory访问时序有问题.
此帖出自ARM技术论坛
65
用51的时候我没发现过这问题晶振11.0592M,现在ARM还是11.0592M,为什么51可以,ARM不行? 我刚将频率跳到晶振频率的3/4时,就没有这现象了....
此帖出自ARM技术论坛
83
那应该是时序问题吧,51比较慢,arm比较快,很多的延时时间不足,可能是。
此帖出自ARM技术论坛
那我试试能否加延时到LCD显示程序中满足这一要求
此帖出自ARM技术论坛
请大家提供建议到哪地方加延时??????
此帖出自ARM技术论坛
不知道屏初始化的代码可见不?它里面应该在设置很多寄存器的时候,都有延时的。可以适当延长,根据51和ARM的主频差别来算。
还有很多像cs,we rd之类的 控制线和数据线,你也要看看他的datasheet,要求多长的持续时间,然后看看你的arm的控制IO速度,看看是否是ARM的速度过快,造成时序电平的持续时间不够长。
此帖出自ARM技术论坛
78
Peasant_Lee:
你的话对我有很大的启发,我在连续2次写地址数据的时候加了一个小小的延时,就OK了,请教你一个问题:
当ARM连续写2个数据出来,第一个数据能在总线上持续多长的时间?
譬如,第一次写 0x55   马上第2次写0xAA  是否就是连续的2VPB个时钟周期呢?
此帖出自ARM技术论坛
66
for(i=1;i>0;i--);
就加了这个延时....
此帖出自ARM技术论坛
77
引用 7 楼 hexian288 的回复:
Peasant_Lee:
此帖出自ARM技术论坛
