4306|4
LOCATING CONSTANT (CODE) VARIABLES IN A CODE BANK [复制链接]
[url=[/url]]原文:
Applies to: LX51 Linker/Locator
Information in this article applies to:
    * C51 Version 6.32a and Later
QUESTION
How do I locate a constant variable in a code bank using the Extended Linker ( LX51 ) ? I have a source file with a table declared as follows:
unsigned char const code table [10] =
  { 'a', 'b', 'c', 'd', 'e', 'f', 'g', 'h', 'i', 'j' };
When I compile and link, the functions in this source file are located in the correct bank, but the table is located in the common area.
ANSWER
When you compile a source file (for example FBANK1.C), the compiler creates program segments for your functions and code segments for your code-based variables. Each function is located in a segment named ?PR?function_name?source_file_name. All code variables are located in a segment named ?CO?source_file_name. This is also true for literal strings.
The linker has commands that let you automatically locate all of the program code from a source file in a code bank. However, the code segments from that file are NOT located in the code bank. You must do that manually.
To locate the code variables in a particular bank, link using a similar command line:
LX51 FBANK1.OBJ,B.OBJ SEGMENTS (?CO?FBANK1(B1:0x8000)) ...
If you use the uVision IDE, enter the following in the User Segment box in the LX51 Locate dialog box.
?CO?FBANK1 (B1:0x8000)
This locates the code variables and string literals from FBANK1.C in BANK1.
他就不知道用_at_+code吗? 个人觉得: BANK是一块一块存放程序的地方,COMMON是程序的其中一块地方 由编译器,连接器根据不同的存储设置决定怎么放。  详情 回复 发表于 2010-7-1 15:32
   大家来说说这个问题是为了说明什么的?
   我是在比较common area 和code bank的时候搜到的。
当需要超过64K的程序存储器的时候,会用到分BANK的存储器.通常它是从地址0到某个地址为公用区,这个地址范围像通常的存储器一样.而在那个地址以上,可能会分若干BANK,要访问指定的BANK,你需要对特定寄存器写入相应控制字. 如果你的程序在一个高地址的BANK中,而要访问的数据却在另一个高地址的BANK,访问就无法进行了.你要采取某种措施来确保它们在同一个BANK里面.
82
他就不知道用_at_+code吗?
个人觉得:
