3744|13
82
XXX_init函数加载不成功? [复制链接]
dll入口函数BOOL WINAPI
DllEntryPoint(HANDLE hinstDLL,
     DWORD dwReason,
     LPVOID lpvReserved)
switch (dwReason)
case DLL_PROCESS_ATTACH:
  RETAILMSG(1,(TEXT("STRINGS:***@@****DLL_PROCESS_ATTACH******\n")));
  return TRUE;
case DLL_THREAD_ATTACH:
  RETAILMSG(1,(TEXT("STRINGS:***@@***DLL_THREAD_ATTACH*******\n")));
  break;
case DLL_THREAD_DETACH:
  RETAILMSG(1,(TEXT("STRINGS:***@@***DLL_THREAD_DETACH******\n")));
   break;
case DLL_PROCESS_DETACH:
  RETAILMSG(1,(TEXT("STRINGS:**@@**DLL_PROCESS_DETACH******\n")));
  break;
     return true;
该函数也没有打印信息。
XXX_init()函数
DWORD ITT_Init(DWORD dwContext)
{ // if you drive a idiographic device,add oter code ep: int,hardwareinit and so on
        DWORD   IDINTThread;
        RETAILMSG(1,(TEXT("MYSTRINGGS:**@@*******InitKey_Init***********\n")));
        //clear the ram which is used for this dll
        InitializeAddresses();
        Key_Key_Thread = CreateThread(0,0,(LPTHREAD_START_ROUTINE)Key_KeyThread_Fun,0,0,&IDINTThread);
        if(!Key_Key_Thread)
                RETAILMSG(1,(TEXT("@CreateThread  faile \r\n")));
                return FALSE;
        else
                RETAILMSG(1,(TEXT("@CreateThread  OK \r\n")));
        return TRUE;
static DWORD Key_KeyThread_Fun()
        INTInit();
        Key_KeyIntr_Event = CreateEvent(NULL,false,false,NULL);
        if(!Key_KeyIntr_Event)
                RETAILMSG(1,(TEXT("@CreateEvent  faile \r\n")));
                return FALSE;
        else
                RETAILMSG(1,(TEXT("@CreateEvent  OK \r\n")));
        if(!KernelIoControl(IOCTL_HAL_REQUEST_SYSINTR,&INTIrq,sizeof(INTIrq),&INTIntr,sizeof(INTIntr),NULL))
                RETAILMSG(1,(TEXT("@ERROR:kerneliocontrol.\r\n")));
                return(FALSE);
        else
                RETAILMSG(1,(TEXT("@KernelioControl OK\r\n")));
        if(!InterruptInitialize(INTIntr,Key_KeyIntr_Event,NULL,0))
                RETAILMSG(1,(TEXT("@Interruptinitialize failed \r\n")));
                return FALSE;
        else
                RETAILMSG(1,(TEXT("@Interruptinitialize OK \r\n")));
        while(1)
                WaitForSingleObject(Key_KeyIntr_Event,INFINITE);
                RETAILMSG(1,(TEXT("@Thread id running :times == %d\r\n"),i1));
                i1++;
                InterruptDone(INTIntr);
导出函数有问题么?我是指ITT_Init会不会没有导出呀?  详情 回复 发表于 2009-9-28 19:34
DLL干脆没有加载?或者DLL加载的是老版本的?
就是没有加载啊,怎么才能让他加载?
65
要在platform.reg和platform.bib加上你DLL的信息,如果是在6。0上,还要加上K的flag
65
platform.reg
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\XXX]
   "DLL"="ITT.dll"
   "Prefix"="ITT"
   "Index"=dword:1
   "Order"=dword:1
   "FriendlyName"="XXXDriver"
platform.bib
  XXX.dll                                $(_FLATRELEASEDIR)\XXX.dll              NK  SH
67
要么是注册表写的有问题。。再就是你的bib文件写的有问题
引用 3 楼 wlc311 的回复:
还要加上K的flag,是什么意思
77
引用 3 楼 wlc311 的回复:
   同意!!!
wincd6.0 注册表。
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\INTl]
        "Dll"="INTkey.dll"
        "Prefix"="ITT"
            "Index"=dword:1
            "Order"=dword:0
bib文件:InitKey.dll $(_FLATRELEASEDIR)\InitKey.dll          NK  SH
有错吗?
这句是做什么的
没有看出来什么问题,楼主可以先用下面的方法确定是否最终build到image中,以及注册表是否生效:
1. viewbin -o -nk.bin(这个要看你用你最终生成image的名字)
2. 看一下release目录下的rege***.ini里有没有你刚才提到的注册项
CE6.0不是SH吧  SHK
引用 8 楼 jiereliyi 的回复:
wincd6.0 注册表。
"Dll"="INTkey.dll"? ?
"Prefix"="ITT"?
? ? "Index"=dword:1
? ? "Order"=dword:0
bib文件:InitKey.dll $(_FLATRELEASEDIR)\InitKey.dll? ? ? ? ? NK? SH
有错吗?
这句是做什么的
这里有个错误,已改正还是不可以
78
引用 9 楼 guopeixin 的回复:
都被包含进去了。
92
引用 12 楼 jiereliyi 的回复:
都被包含进去了。
