4031|5
81
关于USB overrun [复制链接]
26.0  CTL    80 06 00 01  00 00 12 00        GET DESCRIPTOR           1.1.0        2010/05/10  22:11:11.016  3.8sc
  26.0  DO     12 01 10 01  00 00 00 08  03 06 f2 00  12 01 01 02  00 01                                               ................         1.2.0        2010/05/10  22:11:11.016   10us
  26.0  CTL    80 06 00 02  00 00 09 00        GET DESCRIPTOR           2.1.0        2010/05/10  22:11:11.016    8us
  26.0  DO     09 02 22 00  01 01 00 a0  32        ..".....2                2.2.0        2010/05/10  22:11:11.016    5us
  26.0  CTL    80 06 00 02  00 00 22 00        GET DESCRIPTOR           3.1.0        2010/05/10  22:11:11.016    9us
  26.0  DO     09 02 22 00  01 01 00 a0  32 09 04 00  00 01 03 01  01 00 09 21  10 01 00 01  22 41 00 07  05 81 03 08  ..".....2.......         3.2.0        2010/05/10  22:11:11.016    3us
  26.0  CTL    00 09 01 00  00 00 00 00        SET CONFIG               4.1.0        2010/05/10  22:11:11.016    9us
  26.0  CTL    21 0a 00 00  00 00 00 00        SET IDLE                 5.1.0        2010/05/10  22:11:11.016    8us
  26.0  CTL    81 06 00 22  00 00 81 00        GET DESCRIPTOR           6.1.0        2010/05/10  22:11:11.019  3.0ms
  26.0  DI     05 01 09 06  a1 01 05 07  19 e0 29 e7  15 00 25 01  75 01 95 08  81 02 95 01  75 08 81 01  95 05 75 01  ..........)...%.         6.2.0        2010/05/10  22:11:11.032   12ms
  26.0  CTL    21 09 00 02  00 00 01 00        SET REPORT               7.1.0        2010/05/10  22:11:12.569  1.5sc
  26.0  DO     00        .                        7.2.0        2010/05/10  22:11:12.572  3.2ms
  28    DO     00 00        ..                       8.1.0        2010/05/10  22:11:12.572    9us
  26.1  DI     00 00 1e 00  00 00 00 00        ........                 9.1.0        2010/05/10  22:11:18.708  6.1sc
  28    DI     00 00 00 1e  00 00 00 00  00        .........               10.1.0        2010/05/10  22:11:18.708   18us
  26.1  DI     00 00 00 00  00 00 00 00        ........                11.1.0        2010/05/10  22:11:18.716  7.9ms
  28    DI     00 00 00 00  00 00 00 00  00        .........               12.1.0        2010/05/10  22:11:18.716    6us
  26.1  DI     00 00 1e 00  00 00 00 00        ........                13.1.0        2010/05/10  22:11:20.348  1.6sc
  28    DI     00 00 00 1e  00 00 00 00  00        .........               14.1.0        2010/05/10  22:11:20.348   12us
  26.1  DI     00 00 00 00  00 00 00 00        ........                15.1.0        2010/05/10  22:11:20.356  7.9ms
  28    DI     00 00 00 00  00 00 00 00  00        .........               16.1.0        2010/05/10  22:11:20.356   12us
  26.0  CTL    21 09 00 02  00 00 01 00        SET REPORT              17.1.0        2010/05/10  22:15:19.158  3.9mn
  26.0  DO     00        .                       17.2.0        2010/05/10  22:15:19.158   14us
  26.0  NSTS   d3 02 00 c0        error                   17.3.0        2010/05/10  22:15:19.158    3us
  26.0  CTL    21 0a 00 00  00 00 00 00        SET IDLE                18.1.0        2010/05/10  22:15:19.228   69ms
  26.0  USTS   05 00 00 c0        no response             18.2.0        2010/05/10  22:15:19.232  3.9ms
  26    RSET        19.1.0        2010/05/10  22:15:19.293   61ms
  26    NSTS   00 00 00 00        success                 19.2.0        2010/05/10  22:15:19.679  385ms
  26.1  RSET        20.1.0        2010/05/10  22:15:19.679   11us
  26.1  USTS   05 00 00 c0        no response             20.2.0        2010/05/10  22:15:21.307  1.6sc
  26    RSET        21.1.0        2010/05/10  22:15:22.362  1.0sc
  26    NSTS   00 00 00 00        success                 21.2.0        2010/05/10  22:15:22.518  155ms
  26.1  RSET        22.1.0        2010/05/10  22:15:22.518   11us
  26.1  USTS   0c 00 00 c0        buffer overrun          22.2.0        2010/05/10  22:15:22.521  2.9ms
  26    RSET        23.1.0        2010/05/10  22:15:24.578  2.0sc
  26    NSTS   00 00 00 00        success                 23.2.0        2010/05/10  22:15:24.734  155ms
  26.1  RSET        24.1.0        2010/05/10  22:15:24.734   23us
  26.1  USTS   0c 00 00 c0        buffer overrun          24.2.0        2010/05/10  22:15:24.737  3.0ms
  26    RSET        25.1.0        2010/05/10  22:15:26.490  1.7sc
  26    NSTS   00 00 00 00        success                 25.2.0        2010/05/10  22:15:26.648  157ms
  26.1  RSET        26.1.0        2010/05/10  22:15:26.648   17us
  26.1  USTS   0c 00 00 c0        buffer overrun          26.2.0        2010/05/10  22:15:26.651  2.9ms
  26    RSET        27.1.0        2010/05/10  22:15:27.786  1.1sc
  26    NSTS   00 00 00 00        success                 27.2.0        2010/05/10  22:15:27.943  156ms
  26.1  RSET        28.1.0        2010/05/10  22:15:27.943   16us
  26.1  USTS   0c 00 00 c0        buffer overrun          28.2.0        2010/05/10  22:15:27.946  2.9ms
USB键盘唤醒以后出现以上问题,请问有那位大侠知道原因
现在我通过USB分析仪分析以后,发现是在我唤醒以后没有对端点做 clear endpoint feature的动作,在对其重新clear endpoint feature以后,发现问题解决。 以上信息供大家学习交流  详情 回复 发表于 2010-6-1 09:05
85
是你的USB键盘有问题吧?换个键盘还会这样吗?
86
因為鍵盤使自己做的,我也不知道為什么一直會出現這個問題,不知道是端點0溢出還是端點1溢出,而且我端點1最大可接收包為64,而我的端點0卻只能是8,端點0不能改,所以我現在非常郁悶。。。
如果是溢出,
是你键盘的枚举描述符问题,我也遇到过溢出问题,
修改描述符就ok
我修改了以后,發現這個現象還是存在的,我已經把端點0和1能夠接收到的最大包都改成了64。
我現在開始懷疑是不是不是FIFO溢出,而是端點之間為了爭奪緩存器而發生了OVERRUN。
還請高手們指點一下
謝謝啦。。。
61
以上信息供大家学习交流
