366|5
爆肝24小时,用 (Micro)Python 做了个墨水屏桌面摆件!【附源码】 [复制链接]
储备了不少墨水屏,一直没派上用场,继【用三色墨水屏显示哪吒】之后,又摆弄了一下 7.5 寸 7 色墨水屏(悬空放了两个小时,弯了-。-),换了个 3.7 寸双色继续折腾。
由于之前大致摸清楚了图像抖动算法,突发奇想,只需要将网页转换为图片,不就可以在墨水屏上显示任何内容了?毕竟网页界面制作起来工作量可小多了,而且有丰富的库可以使用,说干就干!
首先,确定技术方案:服务端:Python + Playwright 负责提供接口渲染网页;客户端:MicroPython 连接 WiFi,定期请求网页更新屏幕。
服务端源码:
  • import asyncio
  • import logging
  • import time
  • import os
  • import uuid
  • from io import BytesIO
  • from urllib.parse import urljoin
  • from secrets import compare_digest
  • from aiohttp import web
  • from dotenv import load_dotenv
  • from playwright.async_api import async_playwright
  • from PIL import Image
  • logger = logging.getLogger(__name__)
  • load_dotenv()
  • HOST = os.environ.get('HTTP_HOST')
  • PORT = int(os.environ.get('HTTP_PORT'))
  • RENDER_TIMEOUT = int(os.environ.get('RENDER_TIMEOUT', 30))
  • TEMPLATE_PATH = os.path.join(os.path.dirname(__file__), os.environ.get('TEMPLATE_PATH', 'templates/hello.html'))
  • UPDATE_INTERVAL = int(os.environ.get('UPDATE_INTERVAL', 60 * 15))
  • IMAGE_URL = str(uuid.uuid4())
  • def _get_mac():
  • mac = uuid.getnode()
  • return ':'.join(("%012X" % mac)[i:i + 2] for i in range(0, 12, 2))
  • _device = {
  • 'model': 'matters-370-opensource',
  • 'firmware': '0.0.1',
  • 'key': os.environ.get('API_KEY'),
  • # ignored!
  • 'mac': _get_mac(),
  • 'battery': 0.0,
  • 'rssi': 0,
  • 'ota': '',
  • # server only!
  • 'width': 416,
  • 'height': 240,
  • _image = None
  • _last_update = 0
  • _task = None
  • _task_lock = asyncio.Lock()
  • async def render(wait_for=UPDATE_INTERVAL):
  • global _image, _last_update
  • if wait_for:
  • logger.info(f'Waiting for {wait_for} seconds...')
  • await asyncio.sleep(wait_for)
  • logger.info('Rendering...')
  • async with async_playwright() as p:
  • try:
  • browser = await p.chromium.launch()
  • context = await browser.new_context()
  • page = await context.new_page()
  • await page.set_viewport_size({'width': _device['width'], 'height': _device['height']})
  • # TODO: Jinja2 template?
  • html = open(TEMPLATE_PATH).read()
  • await page.set_content(html, timeout=RENDER_TIMEOUT * 1000, wait_until='networkidle')
  • png_bytes = await page.screenshot(type='png')
  • img = Image.open(BytesIO(png_bytes))
  • img = img.convert('1', dither=Image.Dither.FLOYDSTEINBERG)
  • img_bytes = BytesIO()
  • img.save(img_bytes, format='BMP')
  • _image = img_bytes.getvalue()
  • _last_update = int(time.time())
  • except Exception as e:
  • logger.error('Render failed:', exc_info=e)
  • return
  • logger.info('Render √')
  • @web.middleware
  • async def auth_middleware(req, handler):
  • if req.method == 'POST':
  • if not compare_digest(req.headers.get('Access-Token', ''), _device['key']):
  • raise web.HTTPForbidden(reason='Invalid API key')
  • return await handler(req)
  • async def ping(req: web.Request) -> web.Response:
  • global _task
  • if _image:
  • image_url = urljoin(f'{req.scheme}://{req.host}{req.path}', IMAGE_URL)
  • else:
  • image_url = ''
  • res = {
  • 'status': 200,
  • 'message': 'OK',
  • 'display': image_url,
  • 'last_update': _last_update,
  • # unused!
  • 'key': '',
  • 'ota': '',
  • res['next_update'] = UPDATE_INTERVAL if _image else RENDER_TIMEOUT
  • async with _task_lock:
  • if not _task or _task.done():
  • _task = asyncio.create_task(render(max(res['next_update'] - RENDER_TIMEOUT, 0)))
  • return web.json_response(res)
  • def image(req: web.Request) -> web.Response:
  • if not _image:
  • raise web.HTTPNotFound()
  • return web.Response(body=_image, content_type='image/bmp')
  • def create_app() -> web.Application:
  • app = web.Application(middlewares=[auth_middleware])
  • app.add_routes([
  • web.post('/ping', ping),
  • web.get(f'/{IMAGE_URL}', image),
  • return app
  • if __name__ == '__main__':
  • logging.basicConfig(level=logging.INFO)
  • if not _device['key']:
  • _device['key'] = uuid.uuid4().hex
  • logger.info('API key generated: %s', _device['key'])
  • logger.info('Starting server...')
  • app = create_app()
  • web.run_app(app, host=HOST, port=PORT)
为了方便测试,还用 Python + tkinter  实现了一个简单的模拟器,效果如下:
模拟器源码:
  • import threading
  • import time
  • import tkinter as tk
  • import uuid
  • from datetime import datetime, timedelta
  • from tkinter import ttk
  • import requests
  • from PIL import ImageTk, Image
  • API_HOST = 'http://127.0.0.1:1988'
  • API_KEY = ''
  • def _get_mac():
  • return ':'.join(('%012X' % mac)[i:i + 2] for i in range(0, 12, 2))
  • _device = {
  • 'battery': 0.0,
  • 'rssi': 0,
  • 'ota': '',
  • 'width': 416,
  • 'height': 240,
  • 'key': API_KEY,
  • 'last_update': 0,
  • _req = {
  • 'model': _device['model'],
  • 'firmware': _device['firmware'],
  • 'mac': _device['mac'],
  • 'battery': 0.0,
  • 'rssi': 0,
  • class Simulator:
  • def __init__(self, master):
  • self.master = master
  • master.title(f'Simulator: {_device["model"]}')
  • master.resizable(0, 0)
  • self.frame = ttk.Frame(master, width=_device['width'], height=_device['height'])
  • self.frame.pack_propagate(0)
  • self.frame.pack()
  • self.img_label = ttk.Label(self.frame)
  • self.img_label.pack(expand=1)
  • self.status = ttk.Label(master, text='Initializing...',
  • relief=tk.SUNKEN, anchor=tk.W)
  • self.status.pack(side=tk.BOTTOM, fill=tk.X)
  • threading.Thread(target=self.upate, daemon=True).start()
  • def upate(self):
  • global _device
  • while True:
  • self.update_status('Connecting...')
  • try:
  • resp = requests.post(url=f'{API_HOST}/ping', json=_req, timeout=10, headers={
  • 'Access-Token': _device['key'],
  • resp.raise_for_status()
  • data = resp.json()
  • self.update_status(data['message'])
  • if data['key']:
  • _device['key'] = data['key']
  • if data['last_update'] != _device['last_update']:
  • resp = requests.get(data['display'], timeout=10)
  • img_io = BytesIO(resp.content)
  • pil_img = Image.open(img_io).resize((_device['width'], _device['height']))
  • self.tk_img = ImageTk.PhotoImage(pil_img)
  • self.master.after(0, self.show_image)
  • _device['last_update'] = data['last_update']
  • next_update = datetime.now() + (timedelta(seconds=data['next_update']))
  • self.update_status(f'Next update: {next_update}')
  • time.sleep(data['next_update'])
  • self.master.after(0, lambda: self.show_error(str(e)))
  • time.sleep(30)
  • def show_image(self):
  • self.img_label.configure(image=self.tk_img)
  • def update_status(self, message):
  • self.status.config(text=message)
  • self.status.update_idletasks()
  • def show_error(self, message):
  • self.update_status(f'Error: {message}')
  • root = tk.Tk()
  • root.geometry(f'{_device["width"]}x{_device["height"]+20}')
  • app = Simulator(root)
  • root.mainloop()
最后,把模拟器逻辑,移植到 MicroPython,最终效果:
先到这,过几天整理发布到 GitHub 上。
这个秒级显示来的级刷新吗?      详情 回复 发表于 3 天前
点赞 关注(2)
7020
移植到 MicroPython,效果挺好
  做了个简单的外壳,过两天 PCB 到了,一起开源~
5004
好东西学习了,电子墨水屏可玩性很高啊
7793
还有模拟仿真器哦?这玩意是个什么东西?
默认摸鱼,再摸鱼。2022、9、28
6891
这个秒级显示来的级刷新吗?
在爱好的道路上不断前进,在生活的迷雾中播撒光引
有奖直播 | AI之眼——安森美图像传感器 报名中
直播主题:AI之眼——安森美图像传感器
报名观看直播、直播间提问、填写问卷均有机会获得精美礼品!
