skyeye linux2.6.24 smdk2410
[root@yuyin ff]# skyeye -e vmlinux -c skyeye.conf
big_endian is false.
arch: arm
cpu info: armv4, arm920t, 41009200, ff00fff0, 2
mach info: name s3c2410x, mach_init addr 0x806b100
uart_mod:0, desc_in:, desc_out:, converter:
SKYEYE: use arm920t mmu ops
Loaded RAM initrd.img
exec file "vmlinux"'s format is elf32-little.
load section .text.head: addr = 0xc0008000 size = 0x000003c0.
load section .init: addr = 0xc00083c0 size = 0x00020c40.
load section .text: addr = 0xc0029000 size = 0x002bbce0.
load section __ksymtab: addr = 0xc02e5000 size = 0x00004670.
load section __ksymtab_gpl: addr = 0xc02e9670 size = 0x00001440.
load section __ksymtab_gpl_future: addr = 0xc02eaab0 size = 0x00000018.
load section __ksymtab_strings: addr = 0xc02eaac8 size = 0x0000d128.
load section __param: addr = 0xc02f7bf0 size = 0x00000578.
load section .data: addr = 0xc02fa000 size = 0x00022408.
not load section .bss: addr = 0xc031c420 size = 0x0002cff8 .
not load section .comment: addr = 0x00000000 size = 0x0000314a .
not load section .debug_line: addr = 0x00000000 size = 0x0015761d .
not load section .debug_info: addr = 0x00000000 size = 0x0161946e .
not load section .debug_abbrev: addr = 0x00000000 size = 0x000bed98 .
not load section .debug_aranges: addr = 0x00000000 size = 0x000072e8 .
not load section .debug_pubnames: addr = 0x00000000 size = 0x000203ff .
not load section .debug_str: addr = 0x00000000 size = 0x00092b81 .
not load section .debug_frame: addr = 0x00000000 size = 0x0005fdc4 .
not load section .debug_loc: addr = 0x00000000 size = 0x0021bcf6 .
not load section .debug_ranges: addr = 0x00000000 size = 0x0006afd0 .
start addr is set to 0xc0008000 by exec file.
arch: arm
Linux version 2.6.24 (root@yuyin) (gcc version 4.2.1) #1 Wed Apr 7 11:46:53 CST 2010
CPU: ARM920T [41009200] revision 0 (ARMvundefined/unknown), cr=00003177
Machine: SMDK2410
Warning: bad configuration page, trying to continue
Memory policy: ECC disabled, Data cache writeback
CPU S3C2410 (id 0x32410000)
MM: CPU does not support supersection mapping for 0x19000000000 at 0xe0000000
S3C2410: core 62.400 MHz, memory 62.400 MHz, peripheral 62.400 MHz
S3C24XX Clocks, (c) 2004 Simtec Electronics
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line: mem=32M console=ttySAC0 root/dev/ram initrd=0xc0800000 ramdisk_size=8192 rw
PID hash table entries: 128 (order: 7, 512 bytes)
timer tcon=00000000, tcnt cb1f, tcfg 00000200,00000000, usec 0000189e
Console: colour dummy device 80x30
console [ttySAC0] enabled
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 32MB = 32MB total
Memory: 29112KB available (2880K code, 317K data, 132K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 64 bytes
NET: Registered protocol family 16
S3C2410 Power Management, (c) 2004 Simtec Electronics
S3C2410: Initialising architecture
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c2800000, irq 33
DMA channel 1 at c2800040, irq 34
DMA channel 2 at c2800080, irq 35
DMA channel 3 at c28000c0, irq 36
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
JFFS2 version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
s3c2410-lcd s3c2410-lcd: no platform data for lcd, cannot attach
s3c2410-lcd: probe of s3c2410-lcd failed with error -22
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
s3c2410-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2410
s3c2410-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2410
s3c2410-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2410
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
loop: module loaded
dm9000 Ethernet Driver
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
BAST NOR-Flash Driver, (c) 2004 Simtec Electronics
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2410-nand s3c2410-nand: Tacls=2, 32ns Twrph0=4 64ns, Twrph1=2 32ns
ERROR: s3c2410x_io_write_word(0x4e000000) = 0x00008131
ERROR: s3c2410x_io_write_word(0x4e000000) = 0xfffff7ff
ERROR: s3c2410x_io_write_word(0x4e000004) = 0x00000090
ERROR: s3c2410x_io_write_word(0x4e000008) = 0x00000000
No NAND device found!!!
ERROR: s3c2410x_io_write_word(0x4e000000) = 0xffffffff
usbmon: debugfs is not available
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
ERROR: s3c2410x_io_write_word(0x49000010) = 0x40000000
ERROR: s3c2410x_io_write_word(0x49000008) = 0x00000008
s3c2410-ohci s3c2410-ohci: USB HC takeover failed! (BIOS/SMM bug)
s3c2410-ohci s3c2410-ohci: startup error -16
s3c2410-ohci s3c2410-ohci: USB bus 1 deregistered
s3c2410-ohci: probe of s3c2410-ohci failed with error -16
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
ERROR: s3c2410x_io_write_word(0x54000008) = 0x00000010
s3c2410-i2c s3c2410-i2c: slave address 0x10
s3c2410-i2c s3c2410-i2c: bus frequency set to 390 KHz
ERROR: s3c2410x_io_write_word(0x54000000) = 0x000000a9
s3c2410-i2c s3c2410-i2c: i2c-0: S3C I2C adapter
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
TCP cubic registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Root-NFS: No NFS server available, giving up.
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
ock(2,0
请问该如何修改呢???
