2624|0
75
关于AT^SCFG命令问题,望高手指点 [复制链接]
AT^SCFG中可以进行URC destination interface 设置。以下为发送命令格式:
Write Command
Configure URC destination interface:
AT^SCFG="URC/DstIfc"[, ]
Response(s)
^SCFG: "URC/DstIfc",
OK
ERROR
+CME ERROR
URC destination interface 有4种
1. "mdm"             Use modem interface to output URCs
2. "app"             Use application interface to output URCs
3.“usb0-mdm“       这里就不介绍了
4.“usb0-app“       这里就不介绍了
通过 AT^SCFG? 命令读取出现在处于 "mdm"接口
这里还有一段介绍
If the AT^SUSB startup mode "None" is active, then the powerup value is "mdm", otherwise "app".
If the multiplexer is started with AT+CMUX and the AT^SUSB startup mode "None" is active, then automatically
the value "app" will be selected.
Parameter is global for all interfaces, volatile and will not be reset by AT&F.
If the modem interface is used, keep in mind, that if the interface is blocked by an active data connection, then this connection should be periodically suspended to check for pending URCs!
我先通过 AT^SUSB 命令设置momdem的startup mode 为"None"
同时也设置了多通道模式 AT+CMUX=0。
这个设置完以后,通过AT^SCFG? 发现还是处于"mdm"接口。
于是又进行了AT^SCFG="URC/DstIfc","app" 设置。
但是始终返回的是"+CME ERROR: operation not allowed" 错误。
望高人指点下,具体是哪里的错误?谢谢了。
