94|1
424
【Follow me第二季第4期】Arduino Nano Connect 作业提交 [复制链接]
一.视频展示
1.1 物料展示
1 ARDUINO NANO RP2040 CONNECT
2 RASPBERRY PI PICO 2 RP2350
3 64 MBIT FLASH MODULE
4 MICROSD MODULE
1.2 视频演示
Total
二.任务实现详情
2.1 入门任务(必做):搭建环境并开启第一步Blink三色LED / 串口打印Hello DigiKey & EEWorld!
2.1.1 物料准备
Arduino IDE /Arduino Nano Connect 开发板/ USB 连接线
设计思路
初始化 RGB 模块和串口模块,在loop 中用状态机切换不同颜色显示;通过串口打印上传 Hello DigiKey & EEWorld!
硬件详解:【Follow me第二季第4期】1.Nano RP2040 Connect 硬件分析
任务详解:【Follow me第二季第4期】2.必做任务之点灯+串口打印
2.1.2 软件流程
2.1.3 代码片段
#include "WiFiNINA.h"
//宏定义数据
#define LED1 LEDR
#define LED2 LEDG
#define LED3 LEDB
//全局变量
byte u8RedColor_i =0;
byte u8GreenColor_i =0;
byte u8BlueColor_i =0;
byte u8Step =1;
// the setup function runs once when you press reset or power the board
void setup()
  //LED 初始化
  pinMode(LED_BUILTIN, OUTPUT);
  //RGB 初始化
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  //串口初始化
  Serial.begin(9600);
// the loop function runs over and over again forever
void loop()
  digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(500);                      // wait for a second
  digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
  Serial.println("Hello DigiKey & EEWorld!");
//状态机形式点灯
  switch(u8Step)
    case 1:
      u8RedColor_i =255;
      u8GreenColor_i =0;
      u8BlueColor_i =0;
      u8Step =2;
      break;
    case 2:
      u8RedColor_i =0;
      u8GreenColor_i =255;
      u8BlueColor_i =0;
      u8Step =3;
      break;
    case 3:
      u8RedColor_i =0;
      u8GreenColor_i =0;
      u8BlueColor_i =255;
      u8Step =4;
      break;
    case 4:
      u8RedColor_i =0;
      u8BlueColor_i =255;
      u8Step =5;
      break;
    case 5:
      u8RedColor_i =255;
      u8GreenColor_i =0;
      u8BlueColor_i =255;
      u8Step =6;
      break;
    case 6:
      u8RedColor_i =255;
      u8BlueColor_i =0;
      u8Step =1;
      break;
    default:
      u8RedColor_i =0;
      u8GreenColor_i =0;
      u8BlueColor_i =0;
  RgbSetColor(u8RedColor_i,u8GreenColor_i,u8BlueColor_i);
//函数名称:RgbSetColor
//函数功能:设置RGB 颜色亮度
//传入参数:红色数值, 绿色数值, 蓝色数值
//传出参数:无
//特别说明:数据范围 0~255
void RgbSetColor(byte u8RedValue, byte u8GreenValue, byte u8BlueValue)
  analogWrite(LEDR,  (255-u8RedValue));
  analogWrite(LEDG,  (255-u8GreenValue));
  analogWrite(LEDB,  (255-u8BlueValue));
2.2 入门任务(必做):学习IMU基础知识,调试IMU传感器,通过串口打印六轴原始数据
2.2.1 物料准备
设计思路
setup 函数中初始化串口模块和 IMU 模块,然后在 loop 函数中查询 IMU 是否有新数据产生,通过串口打印
2.2.2 软件流程
2.2.3 代码片段
#include "Arduino_LSM6DSOX.h"
//宏定义数据
#define LED1 LEDR
#define LED2 LEDG
#define LED3 LEDB
//全局变量
byte u8Step =1;
float Ax, Ay, Az;
float Gx, Gy, Gz;
void setup()
  //LED 初始化
  //RGB 初始化
  //串口初始化
  Serial.begin(9600);
  //IMU 初始化
  if(!IMU.begin())
    Serial.println("Fail to initialize IMU!");
  Serial.print("Accelerometer sample rate = ");
  Serial.print(IMU.accelerationSampleRate());
  Serial.println("Hz");
  Serial.println();
  Serial.print("Gyroscope sample rate = ");
  Serial.print(IMU.gyroscopeSampleRate());
  Serial.println();
void loop()
  //打印加速度数据
  if (IMU.accelerationAvailable())
    IMU.readAcceleration(Ax, Ay, Az);
    Serial.println("Accelerometer data: ");
    Serial.print(Ax);
    Serial.print('\t');
    Serial.print(Ay);
    Serial.print('\t');
    Serial.println(Az);
    Serial.println();
//打印陀螺仪数据
  if (IMU.gyroscopeAvailable())
    IMU.readGyroscope(Gx, Gy, Gz);
    Serial.println("Gyroscope data: ");
    Serial.print(Gx);
    Serial.print('\t');
    Serial.print(Gy);
    Serial.print('\t');
    Serial.println(Gz);
    Serial.println();
delay(500);
2.3 入门任务(必做):学习PDM麦克风技术知识,调试PDM麦克风,通过串口打印收音数据和音频波形
2.3.1 物料准备
设计思路
setup 函数中初始化串口模块和 PDM 模块,然后在 loop 函数中查询 PDM 新数据,通过串口打印
2.3.2 软件流程
2.3.3 代码片段
#include <WiFiNINA.h>
#include <PDM.h>
bool LED_SWITCH = false;
// 设置输出通道数, 1 为单声道, 2 为立体声
static const char channels = 1;
// 设置采样频率, 单位 Hz
static const int frequency = 20000;
// 缓存采样数据,数据长度为 16bit
short sampleBuffer[512];
// 读取个数
volatile int samplesRead;
void setup()
  //串口初始化
  Serial.begin(9600);
  //LED 灯初始化
  pinMode(LEDB, OUTPUT);
  // 设置 PDM 检测到新数据时的回调函数
  PDM.onReceive(onPDMdata);
  // 设置 PDM 增益,数据在 0 到 255 之间,默认为 20
  PDM.setGain(30);
  // 初始化 PDN 模块:
  // - 单声道模式
  // - 采样率 20KHz
  // 等待 PDM 初始化完成
  if (!PDM.begin(channels, frequency))
    Serial.println("Failed to start PDM!");
    while (1);
void loop()
  // 有新数据产生
  if (samplesRead)
    // 串口打印接收数据
    for (int i = 0; i < samplesRead; i++)
      Serial.println(sampleBuffer[i]);
      if (sampleBuffer[i] > 5000 || sampleBuffer[i] <= -5000)  //数据大于 5000 或小于 -5000, 闪灯
        LED_SWITCH = !LED_SWITCH;
        if (LED_SWITCH)
          digitalWrite(LEDB, HIGH);
          delay(1000);
        else
          digitalWrite(LEDB, LOW);
          delay(1000);
    // 清零数据,等待下一次数据
    samplesRead = 0;
//   处理 PDM 模块的回调函数,底层用 ISR 实现,因此不可在其中使用串口打印数据
void onPDMdata()
  // 读取 PDM 缓存数据
  int bytesAvailable = PDM.available();
  // 将 PDM 缓存数据存入定义数组中
  PDM.read(sampleBuffer, bytesAvailable);
  // 每次采样 2Byte 数据
  samplesRead = bytesAvailable / 2;
2.3 选做任务:通过RGB LED不同颜色、亮度显示PDM麦克风收到的声音大小
2.3.1 物料准备
设计思路
setup 函数中初始化 RGB 模块、串口模块和 PDM 模块,然后在 loop 函数中查询 PDM 新数据,通过 map 函数映射为 RGB 数值
2.3.2 软件流程
2.3.3 代码片段
#include <PDM.h>
//宏定义数据
#define LED1 LEDR
#define LED2 LEDG
#define LED3 LEDB
// 设置采样频率, 单位 Hz
// 读取个数
byte PDM_DataRemap =0;
void setup()
  //串口初始化
  Serial.begin(4800);
  //LED 灯初始化
  PDM.setGain(30);
  // 初始化 PDN 模块:
  // - 单声道模式
  // - 采样率 20KHz
  // 等待 PDM 初始化完成
    while (1);
void loop()
  // 有新数据产生
  if (samplesRead)
    PDM_DataRemap =map(sampleBuffer[0],-500, 500, 0, 255);
    RgbSetColor(0, 0, PDM_DataRemap);
    // Serial.println(sampleBuffer[0]);
    delay(100);
    // 清零数据,等待下一次数据
    samplesRead = 0;
void onPDMdata()
  // 读取 PDM 缓存数据
  // 每次采样 2Byte 数据
//函数名称:RgbSetColor
//函数功能:设置RGB 颜色亮度
//传出参数:无
//特别说明:数据范围 0~255,数值越小,亮度越小
三.可下载代码
20241229231141134.7z (2.2 KB, 下载次数: 0)
四.心得体会
感谢 EE和 DigiKey 再一次提供的玩板子的机会。很久前就有听过 RP2040 的高i性价比,特别是今年官方还出了升级版本的 2350;本次的 Nano 板卡也称得上是麻雀虽小五脏俱全,尤其板载 ST 的 MESE 加速度和陀螺仪传感器,以及 PDM 录音模块,可联动机器学习和语音引擎,加上小尺寸体积,十分适合用在可穿戴设备上。遗憾的一点是年尾事多时间有限,本次活动只能匆匆掠过,更出彩的玩法还得补课学学机器学习和惯性导航内容,毕竟学无止境,趁年轻,多折腾。
选了这么多模块吗?     详情 回复 发表于 3 天前
个人签名君应有语,渺万里层云,千山暮雪,知向谁边?
6345
选了这么多模块吗?
在爱好的道路上不断前进,在生活的迷雾中播撒光引
站长推荐上一条 1/5 下一条
